FridgeFreezer Posted January 16, 2018 Share Posted January 16, 2018 Just a little public service reminder of what happens Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted January 16, 2018 Share Posted January 16, 2018 When he said old lights I didn't realise he mean't petrol coated rags on sticks. Quote Link to comment Share on other sites More sharing options...
TSD Posted January 16, 2018 Share Posted January 16, 2018 Wasn't called Vince by any chance? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 16, 2018 Share Posted January 16, 2018 Link seems to not work. Mike Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 17, 2018 Share Posted January 17, 2018 Seems not to work for me either 🙁 Mo Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 17, 2018 Share Posted January 17, 2018 Works for me (iPhone - Safari) That’s quite horrific. Quote Link to comment Share on other sites More sharing options...
Davo Posted January 17, 2018 Share Posted January 17, 2018 Hmmm, maybe I should put a big fuse in that brown wire on the Rangie . . . Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 17, 2018 Author Share Posted January 17, 2018 2 hours ago, Davo said: Hmmm, maybe I should put a big fuse in that brown wire on the Rangie . . . I did on the 127 - Defender main feed isn't fused! Quote Link to comment Share on other sites More sharing options...
Davo Posted January 17, 2018 Share Posted January 17, 2018 It's amazing, isn't it? It will be a bit of a pain to do, so it's on the list . . . Quote Link to comment Share on other sites More sharing options...
Peaklander Posted January 17, 2018 Share Posted January 17, 2018 (edited) Isn’t there a set of four big fuses under the bonnet? Or do you mean the main feed into there from the alternator? (Defender 300 TDi) Edited January 17, 2018 by Peaklander Added vehicle Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 17, 2018 Author Share Posted January 17, 2018 Not sure about 300-era but the 127 (1988) the entire dashboard / main fusebox is fed with two un-fused brown wires. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 17, 2018 Share Posted January 17, 2018 Every thing land rover up to about 300tdi doesn't have a fuse in the main feed to dash etc. Discoverys from 92ish to 94 had fuseable links (thin wire designed to burn out if overloaded). I've replaced these on my ibex with an under bonnet fuse box from a td5. Mike Quote Link to comment Share on other sites More sharing options...
