Regarding the bumpstops.... how did you set the positions of the top and bottom of the shocks? If you take the bump stops out (springs too for ease) and lift the axle up to the chassis you'll see when the shocks are bottomed out. Normally it's a good idea to mount the shocks fully closed with no bumpstops and the axles metal-to-metal against the chassis.
  • Like 1
This is what happened  ^^^^
If you remember I had a few issues with fitting the engine and box due to physical size of front diff and axle, engine could not be moved far enough over to the left, the problem was cured with fitting extended bump stops and extensions. Probably a compromise in hindsight, realistically I lack the offroad  knowledge involved with building a good off road vehicle, most of my build has been a gut feeling that it feels right and obviously excellent contributions and advice from your good selves.
If lack of uphill travel becomes an issue, I will as mentioned previously, try the +2" springs first. Lack of uphill travel or not this is just a toy, if it was a competition vehicle it would be a different matter
The proof of the pudding will be at  Summer Sisters, who knows, it may fall apart, the welded diffs might give way or I might get over a few obstacles with ease and have no breakages, one thing for sure we will find out this month if it is capable of not, if it is the latter then it will be back to the drawing board....lol
Regards Stephen
  • Like 4
Sorry Stephen, I missed tagging whoever asked about the bumpstop.
I lost a spring at Seven sisters a (good) few years back when it missed the relocation cone and damaged the retainer. There was a handy rock for making enough suspension movement to pop it back in :lol:
What's the spring rate like on the shorter springs? Not to stiff and come from some fast-road type setup? Off the top of my head a standard Defender has about 80mm travel to the bumpstop.
Might that rock be down at the washing machine area which is now sadly closed.....
Steve
1 hour ago, Stellaghost said:
Hadn't planned on it, they need a good clean up, however if I have room I might bring them, it's not like I need to pack spring compressors is it.......
Regards Stephen
You might not need spring compressors but you do need a crane...
Offer still stands of tools / workshop stuff from me, e.g. got a set of compressors if you do desperately need them.
Regards Stephen
Well they won't take up much space, and cab swapped over wholesale in about half an hour... As long as we have a tree.
  • Like 1
Just to keep @Bowie69 happy been wiring my lockers in, it's not the tidiest as I've moved from original position, but after a bit of head scratching I've sussed it out, working now although not piped in yet
Mess of wires
Tesa taping heavy duty power cables
better but not great
head hurting now....
regards Stephen
  • Like 3
2 hours ago, Stellaghost said:
Just been to see about getting them plastic coated but guy got full books until end of August
Regards Stephen
Bring them anyway, at the end of the weekend you will know which set you are keeping and can powder coat appropriately.
Or are you worried about aesthetics?
