Jon W Posted June 19, 2018 Share Posted June 19, 2018 I had a facet red top gold flo fuel pump in my V8 series on SU carbs and this has only lasted 2 years and very little mileage. Pump got very hot and expired letting out smoke and blowing the fuse. Leaving me stranded at the side of the road. Have opened the pump and there is no blockages so not sure what went wrong. When I brought this pump I didn’t realise it was too high pressure for carbs so put a fuel pressure regulator and filter on after the pum and before the carbs. Is this restriction likely to have caused issues? I also have an in-line filter before the pump as didn’t want any gunk getting into the pump and it’s filter. Tank is clean as it was new 2 years ago along with fuel line, so I’m pretty sure it’s not things blocking up causing the pump to burn out. So which pump do I fit now to replace it, and do I carry a spare to prevent being stranded? Thanks Jon Quote Link to comment Share on other sites More sharing options...
lo-fi Posted June 19, 2018 Share Posted June 19, 2018 I've had my silver top in the same setup for four years and still going strong, though I'm not running a filter ahead of it. I suspect the filter may have caused your failure, I'm sure I remember an app note saying not to do that. You could have just been unlucky, of course. No problem running the regulator though, they're designed to be run that way. Quote Link to comment Share on other sites More sharing options...
Quagmire Posted June 19, 2018 Share Posted June 19, 2018 (edited) My early 90 was a 2.25 petrol from the factory and had a facet style pump fitted, along with a filter ona bracket mounted the to outrigger behind the fuel tank and ahead of the drivers side rear wheel, it is still working to this day- so I'd say it might be worth a Google to see what the factory setup was (it's since been rehomed to a different vehicle and replaced with a V8 and efi stuff). Like this: *Edit- well that was a rubbish screenshot! Not sure why it looks blurry on here, when it's crystal clear on my phone... Edited June 19, 2018 by Quagmire Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 19, 2018 Share Posted June 19, 2018 There's a factory external Facet-type pump fitted to some models as mentioned, and there's a factory in-tank pump for carbs too. My facet has lasted years on the 109 (about 15 years so far in fact!) feeding an EFI pump. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted June 22, 2018 Share Posted June 22, 2018 I have a Huco on my P6 and it works great. Quote Link to comment Share on other sites More sharing options...
missingsid Posted June 23, 2018 Share Posted June 23, 2018 I've used an SU pump for years then upgraded to a new electronic version (same but no points). I did try a Facet but it leaked like a sieve! At least with the SU I can hear it prime before starting. Quote Link to comment Share on other sites More sharing options...
Paul Woodward Posted June 24, 2018 Share Posted June 24, 2018 The quality of the new Facet pumps seem very poor. We have had trouble with 3 or 4 at work. Probably not made in the USA anymore. If you have an old one, hang onto it! We are trying these now. https://www.demon-tweeks.co.uk/performance/fuel-pumps/holley-external-electric-fuel-pump Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 25, 2018 Share Posted June 25, 2018 I think if you have the 6-screw fittin on top of the tank you can shorten a RRC/D1/110 in-tank pump and use that. Just don't use the EFI type for carbs! Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 25, 2018 Share Posted June 25, 2018 2 minutes ago, FridgeFreezer said: I think if you have the 6-screw fittin on top of the tank you can shorten a RRC/D1/110 in-tank pump and use that. Just don't use the EFI type for carbs! Or even the in-tank pump from a carb'd V8 90. That's probably about the correct depth of pickup already. Quote Link to comment Share on other sites More sharing options...
Jon W Posted June 30, 2018 Author Share Posted June 30, 2018 Well i brought a bearmach pump for £28 or something like that designed for car V8 land rover of some sort. This seems to do the job, have fitted it and it runs. Just need to test or adjust the pressure on my filter pressure regulator thing yet (fitted because the last pump was too high pressure for the carbs.. So will do that next before taking it out on a test drive. Have also removed the filter before the pump in case this was causing any problems. Thanks all Jon Quote Link to comment Share on other sites More sharing options...
