trickydicky Posted September 19, 2018 Share Posted September 19, 2018 hi all the clutch plate on my 200tdi has developed a chatter and I think its time to sort it .can anybody tell me the best make I can buy as its not something I want to do again for a while . Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 19, 2018 Share Posted September 19, 2018 I'd go to Clutchfix if I wasn't going to be running an auto. Clutches are what they do. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted September 19, 2018 Author Share Posted September 19, 2018 ill be doing it myself but thanks for the imfo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 19, 2018 Share Posted September 19, 2018 They make clutches rather than fit then, it's all they do and they've got decades of experience. From classic cars to lorries and beyond. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted September 19, 2018 Share Posted September 19, 2018 Do you mean a chatter while driving along, or on taking up drive? If the latter I'd suggest you may have broken springs in the clutch plate. Alternatively as with my own experience of a heavy judder when letting the clutch up from stand still. This was due to a glazed flywheel surface, which required refacing at my local gearbox specialist to sort out, plus new clutch pressure and friction plates. Quote Link to comment Share on other sites More sharing options...
Eightpot Posted September 19, 2018 Share Posted September 19, 2018 Have fitted many Valeo clutches, would certainly recommend them. If it's chattering with the clutch released its more likely the release bearing. Chattering can also come from the input shaft bearing so check for play on that when you've whipped everything off. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted September 19, 2018 Author Share Posted September 19, 2018 it chatters normaly when you depress the clutch to change in to second .the people who rebuilt my gearbox said the clutch was a valio clutch plate and was much better than the one they were going to fit so they didn't replace it .400 miles later it started chattering and its now 5 years later and its time to get it sorted . Quote Link to comment Share on other sites More sharing options...
trickydicky Posted September 19, 2018 Author Share Posted September 19, 2018 so do you guys think valio or beck and borg ? Quote Link to comment Share on other sites More sharing options...
western Posted September 19, 2018 Share Posted September 19, 2018 Valeo defender 130 300tdi plate & cover, if you do a search, you should find the part numbers as I've posted these before. Quote Link to comment Share on other sites More sharing options...
trickydicky Posted September 19, 2018 Author Share Posted September 19, 2018 thanks for that Quote Link to comment Share on other sites More sharing options...
cackshifter Posted September 19, 2018 Share Posted September 19, 2018 Borg and Beck I think are not the same as they once were Quote Link to comment Share on other sites More sharing options...
Yostumpy Posted September 26, 2018 Share Posted September 26, 2018 dont forget the spigot bush as well!! Quote Link to comment Share on other sites More sharing options...
DC_ Posted September 27, 2018 Share Posted September 27, 2018 Valeo one went in mine a year ago, even looking at the difference between the one that came off and the valeo one going on, you could see quality was in the valeo one. I’d do the clutch bearing too as it’ll probably be ready to start jangling when you’re sitting in neutral with engine running. 😊👍 Quote Link to comment Share on other sites More sharing options...
