Daan
Croatia trophy 2019; new location, new classes.
9 hours ago, Ozzy50 said:
All good stuff. The weather hasn’t been kind to them that’s for sure .Thanks again  Daan 👍🏻. Did I spot team Gigglepin in an earlier video or is it another ORA Offender ?
Yeah, Gigglepin are racing out there :)
Share this post
Link to post
.. and leading the race at the moment.
Share this post
Link to post
10 hours ago, Ed Poore said:
Or would that risk punctures too much and therefore not worth the time in the long run?
I think this and the tyre coming off the rim where double beadlocks are not in use. No point gaining a bit of speed if you can't finish the event.
Share this post
Link to post
There is a bit of fast stuff, say 80mph said jim in the video. But to be fair its only minutes untill the next tough section and you need low tyre pressures again. I ran on 5 PSI the entire event in 2016.
The Russians and estonians run central tyre inflation for this reason.
The event has now ended and Jim Won.
Daan
Share this post
Link to post
8 hours ago, landroversforever said:
I’d still like to see Jim take on Ladoga :D
I don't think he has a hope in the swamps; his car is at least a ton heavier than the Russian/Estonian cars.
But at the Croatia trophy, it doesn't seem to matter much.
That said the blue Estonian car was leading until he had a flat tyre and injured himself while dealing with it.
Share this post
Link to post
Thank you Daan and everyone else for keeping us up to date , a great event and one I hope to attend in the next couple of years , hopefully it will be drier than this years running .
Share this post
Link to post
The almost winning car is for sale:
It would be marriage limiting buying this thing, but 😎.
Share this post
Link to post
Ooow nice!
Things to note:
Titanium caliper brackets! :o
The front winch holds 85m of rope! :blink:
Steve
  • Like 1
Share this post
Link to post
Aluminium portal boxes and weight is 1300 kg. My preferred truck for this kind of thing. Hydro steer would prevent you from getting it road legal in the UK though.
Share this post
Link to post
not quite
Share this post
Link to post
no?
quoted from the IVA manual
" Vehicles fitted with complex drive by wire or hydraulic steering systems cannot be assessed by inspection, therefore documentary evidence must be provided "
other than that
" If the vehicle is fitted with power assisted steering, the steering must still operate with the assistance disabled "
"When the vehicle is driven at speeds above 10mph, there must be a degree of steering “self centring” evident"
which my full hydro does
Edited by RedLineMike
Share this post
Link to post
I thought at the very least there was a speed limit applied to hydraulic steering?
Share this post
Link to post
cant see any mention in the IVA manual
Share this post
Link to post
On ‎5‎/‎2‎/‎2019 at 12:56 PM, Daan said:
That's a very old conversation which has been gone over many times; No, it is not in the manual, but it needs a solid link, no car is road legal without it.
The speed restriction is I think 30 MPH for diggers etc, but if you show up with a car with over 300HP, that argument ain't going to fly I reckon.
The first rule refers to Nissan steer by wire and the Citroen CX which had full hydro steering. Both have still a mechanical connection which is temporarily disconnected when the engine is started. The connection is spring loaded, so will drop back in once the engine is off, or the system stops working.
Still, this car has a Panhard rod, so adding the PSC 4500 steering system would be fairly easy to do and would give hydraulic steering with a mechanical link.
I would be keen on doing this, just the 60K euros to buy the car prevents me from it!
  • Like 1
Share this post
Link to post
Forum group buy? :ph34r:
Share this post
Link to post
I suppose it has the right colour for LR4x4 livery. Anyone feeling like kicking of some crowd fund raising?
Daan
  • Like 2
Share this post
Link to post
