jimconline Posted June 22, 2019 Share Posted June 22, 2019 Did my first oil change today after having the timing belt replaced by a local independent Land Rover shop. They also replaced the push rods, rocker arms, tappet adjusters,... as some of the rods were bent. I noticed some thin metal shavings, enough to just clog the funnel I was using to pour the old oil from tray into a storage can. All is running fine but this is a first for me. Thoughts? Quote Link to comment Share on other sites More sharing options...
western Posted June 22, 2019 Share Posted June 22, 2019 Which engine? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 22, 2019 Share Posted June 22, 2019 Colour? If it blocked a funnel, I'd suggest you are likely to need to open up the bottom of the engine, that amount of material, and obviously size, can only really be crank main or big end bearings. Possibly cam, but unlikely. Rockers/pushrods destroying themselves would just produce glitter and not flakes. At this point, I don't think it will be anything to do with the work the garage has done, but need to know more really. Quote Link to comment Share on other sites More sharing options...
western Posted June 22, 2019 Share Posted June 22, 2019 Agreed, would be looking at the oil pump internals as well. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 22, 2019 Share Posted June 22, 2019 Yep, likely it hasn't enjoyed ingesting metal of any sort. Quote Link to comment Share on other sites More sharing options...
cackshifter Posted June 22, 2019 Share Posted June 22, 2019 On a 300 could be off the fuel pump or vacuum pump (straw grasping). A picture might help. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 22, 2019 Share Posted June 22, 2019 Jim, a picture of the debris, size and amount with something for size reference would be useful. Mo Quote Link to comment Share on other sites More sharing options...
mmgemini Posted June 22, 2019 Share Posted June 22, 2019 6 hours ago, cackshifter said: On a 300 could be off the fuel pump or vacuum pump (straw grasping). A picture might help. It could also be the fingers off the oil pump on a 300Tdi Quote Link to comment Share on other sites More sharing options...
jimconline Posted June 22, 2019 Author Share Posted June 22, 2019 It's a 300Tdi. I didn't take any photos; though I could filter them out of the waste container and take some. Before doing that, I could better describe them not as shavings but rather strands of steel wool. The amount that I saw gathered in the funnel could be held loosely in a thimble. One piece I did extract was maybe 3cm long. Quote Link to comment Share on other sites More sharing options...
steve b Posted June 22, 2019 Share Posted June 22, 2019 Could it be a mashed up oil seal spring? I found pieces of oil seal spring about 2 - 3 cm in the sump of a 300 Tdi last week , although it wasn't mashed , just short sections that had sprung straight . cheers Steve b Quote Link to comment Share on other sites More sharing options...
jimconline Posted July 15, 2019 Author Share Posted July 15, 2019 Curiosity, getting the better of me, found me filtering the old oil through some cheesecloth this morning. Was a bit of a lengthy process (fine mesh would have been better but I didn't have any). Did not find any more metal. Yes, I did even inspect the bottom of the original waste oil container. Decided it might be rather excessive to cut open the oil filter, so I left it at that. All is running Defender smooth, though I haven't put many kilometers on it. Unless I have some problems, I shall do an early oil change next and see if anything other than oil appears. Though I didn't notice it at the time, perhaps, Steve, it was the oil seal spring. Quote Link to comment Share on other sites More sharing options...
steve b Posted July 15, 2019 Share Posted July 15, 2019 Maybe , your curiosity is worthwhile though , it's what I would have done just to settle my mind . As you say , an early oil change into a clean catch tray will seal the deal " Defender smooth " = great , we all know that description cheers Steve b Quote Link to comment Share on other sites More sharing options...
Snagger Posted July 17, 2019 Share Posted July 17, 2019 I’d drop the sump, give it a good clean and then run it until the next service and have a close look again. It could just be something that got in during a previous oil change or tapped adjustment and fell down the push rod tubes to the sump, never passing around the oil system. I think a FilterMag is always a good investment and a simple addition - it’s just a big, curved, very strong magnet that sticks to the side of the oil filter to pull out any small ferritic particles too small for the filter to catch. It’s amazing how much they collect, though is suspect much of it would be caught by the filter element anyway, but at least it keeps the element that much cleaner and oil flow that much less restricted. Quote Link to comment Share on other sites More sharing options...
jimconline Posted August 21, 2019 Author Share Posted August 21, 2019 I did a 1000kms run without issue and when I got back I drained the oil. Not a sign of any metal. Will check this one off as unknown. Quote Link to comment Share on other sites More sharing options...
