Madcowz Posted September 11, 2019 Share Posted September 11, 2019 Hi, I'm now in charge of looking after two TDCI's. 2010 and 2011 plate which have both done less than 35K but are now 8 & 9 years old. What are your thoughts on timing chain renewal? Also, any idea of the (sensible) schedules for gearbox, transfer box and diff oils? This maintenance check sheet shows the following:Gearbox: 200kTransfer box and diffs: 80k I'm very light on any info or service log books and don't know anything about new fangled engines and would prefer to play it very safe. Thanks and sorry for the noddy questions. ) Quote Link to comment Share on other sites More sharing options...
Badger110 Posted December 27, 2020 Share Posted December 27, 2020 Some people have had failures of the chain at 110k, some are on 250k plus and not changed it. I'm on 160k and it's being done now along with rocker gaskets, injection seals, crankshaft seal and a new clutch. It'll be like new i tell thee Quote Link to comment Share on other sites More sharing options...
monkie Posted November 13, 2022 Share Posted November 13, 2022 Sorry to resurrect an old thread... I'm checking out a bunch of Puma powered Defenders with a view to replace my 110. Routine replacement of a timing chain is news to me. Are there any obvious signs of a worn chain I can look for whilst inspecting a prospective 110? I take it that if I buy one with no known history of chain replacement then I should budget for getting it sorted? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted November 13, 2022 Share Posted November 13, 2022 I only know about Honda CRVs and on these CDTi engines you can see the tensioner through an inspection hole. If it’s too far extended then it’s time for a new chain. That’s assuming it isn’t already clattering. Quote Link to comment Share on other sites More sharing options...
monkie Posted November 14, 2022 Share Posted November 14, 2022 Ah, so they make a clattery kind of noise if they are suspect? Quote Link to comment Share on other sites More sharing options...
Peaklander Posted November 14, 2022 Share Posted November 14, 2022 My daughter bought a very cheap 250K mile CRV diesel without any service history, contrary to all advice she had received from me. After a few months this was the sound... It was a learning curve for me and I replaced the cam and oil pump chains and a whole load of other parts. Plus I stripped the VNT turbo which at the same time had started to get stuck and give over boost codes. It's my only example but I believe that regular and frequent engine oil and filter changes are essential. Quote Link to comment Share on other sites More sharing options...
jeremy996 Posted November 14, 2022 Share Posted November 14, 2022 Timing chains tend to make a noise when the effective length of each link is slightly more than the sprocket teeth through wear. Old school mass manufacturers used to see chains as almost indestructible, but vehicles barely made it to 100,000 miles in the old days. A sort of whirring and clattering - Peaklander's video is extreme! That, only quieter. Worn chains can destroy engines, just ask a Triumph Stag owner, (that suffered from a cheap chain and a tensioner with only a limited ability to take up slack). Quote Link to comment Share on other sites More sharing options...
Junglie Posted November 14, 2022 Share Posted November 14, 2022 12 minutes ago, jeremy996 said: ...Worn chains can destroy engines, just ask a Triumph Stag owner, (that suffered from a cheap chain and a tensioner with only a limited ability to take up slack). Or just about any early '80s Honda motorcycle owner - bike camchains were rubbish and tensioners nowhere near man enough for the job. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 14, 2022 Share Posted November 14, 2022 Or.... any 2000s onwards VW/Audi owner, where they put the chain on the back of engine in some cases as it was a non-service item. Turns out they were wrong. Very expensive to repair and often write the car off. Quote Link to comment Share on other sites More sharing options...
monkie Posted November 14, 2022 Share Posted November 14, 2022 1 hour ago, Bowie69 said: Or.... any 2000s onwards VW/Audi owner, where they put the chain on the back of engine in some cases as it was a non-service item. Turns out they were wrong. Very expensive to repair and often write the car off. I guess that depends on your view... VW/Audi who won't care once the engine has done over 60k miles or 3 years service, or the owner of a 4year old/61k miles+ car. Quote Link to comment Share on other sites More sharing options...
monkie Posted November 14, 2022 Share Posted November 14, 2022 Thank you for the responses. I think I have my answer that I need to include this in my budget for a Puma Defender. I'm leaning towards the 2.4 version if I see the right one for me. My 200tdi 110 is having its Mot this week, then it will be on the market. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 14, 2022 Share Posted November 14, 2022 My view would never be as someone that changes their car every 3 years/60K. It was a mistake anyway you look at it, been very damaging to reputation. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted November 14, 2022 Share Posted November 14, 2022 I've owned both 2.4 & 2.2 Puma's from new, if you want a unbiased view of them just drop me a PM. 1 Quote Link to comment Share on other sites More sharing options...
monkie Posted November 14, 2022 Share Posted November 14, 2022 34 minutes ago, Happyoldgit said: I've owned both 2.4 & 2.2 Puma's from new, if you want a unbiased view of them just drop me a PM. Thank you, any advice is gratefully recieved. PM sent. 1 Quote Link to comment Share on other sites More sharing options...
Badger110 Posted November 16, 2022 Share Posted November 16, 2022 On 11/13/2022 at 9:02 PM, monkie said: Sorry to resurrect an old thread... I'm checking out a bunch of Puma powered Defenders with a view to replace my 110. Routine replacement of a timing chain is news to me. Are there any obvious signs of a worn chain I can look for whilst inspecting a prospective 110? I take it that if I buy one with no known history of chain replacement then I should budget for getting it sorted? Having rebuilt the Tdci , the timing chain hadn’t been an issue at 160k. I did replace the chain at 170k and in my build thread you can see the difference between a 100k chain and a new, but it was never was noisy in my opinion even though the chain had stretched and the guide was worn. Tdci’s are a world away from older LR driven Landy’s in so many ways. Replacing a chain isn’t difficult if your handy with your spanner’s, no special tools needed, just lots of silicone around the seals when done 😉 3 Quote Link to comment Share on other sites More sharing options...
