oakeedokee Posted January 3, 2007 Share Posted January 3, 2007 Been scratching my head as to the best way to mount a Warn M1200 to the front of my bobtail today and thought I would ask you guys for some guidance. I've got a mounting plate to suit it, but it will need modification to make it sit as far back as possible. I like the approach angle with no winch fitted, so do I move the rad back and fit electric fans or will I be able to keep it where Land Rover intended? I can't afford to buy a winch bumper so would like to see other folk's photos of home-made setups. Any tips, problems you've come across too please. Thanks. Quote Link to comment Share on other sites More sharing options...
Marc.be Posted January 3, 2007 Share Posted January 3, 2007 Hi, thi is the way I did it. doesn't stick out furhter than a simple bumper. Quote Link to comment Share on other sites More sharing options...
v8bertha Posted January 4, 2007 Share Posted January 4, 2007 I have searched hi and low for a piccy of my bumper, but all I can find is a couple from when it was "in development"! Only problem I had was after I welded the sides into the tray, the winch was a *REALLY* tight fit against the mounting bolts that go through the chassis. Suppose if you are gonna weld the tray directly to the chassis then you won't have this problem tho. HTH D Quote Link to comment Share on other sites More sharing options...
oakeedokee Posted January 4, 2007 Author Share Posted January 4, 2007 How do you get on with the winch being so low down? Does the tray fill up with carp too easily? Marc, looking at your photo have you removed one of the stays that support the bonnet release? Does that affect it's operation? Quote Link to comment Share on other sites More sharing options...
Marc.be Posted January 4, 2007 Share Posted January 4, 2007 How do you get on with the winch being so low down? Does the tray fill up with carp too easily? Marc, looking at your photo have you removed one of the stays that support the bonnet release? Does that affect it's operation? its 4weeks that i drive without that bar and i don't have problems with it. the bonnet still opens like it used to do before. can take some more pictures if you want. Quote Link to comment Share on other sites More sharing options...
oakeedokee Posted January 4, 2007 Author Share Posted January 4, 2007 Yes please I'd like to see how its all connected to the chassis. Quote Link to comment Share on other sites More sharing options...
Marc.be Posted January 5, 2007 Share Posted January 5, 2007 Yes please I'd like to see how its all connected to the chassis. I started with a bikini winch mount that i got from a friend. I welded that plate to my bumper and this is how it's attached to my chassis. my rangie has a 1" bodylift, without a bodylift, you maybe should fix the mounting plate under the chassis instead of above it. And this is a view to see that the approach angle isn't affected. and finally a picture of my range rover with the winchbumper. (It has normally 255/85 tires instead of those standard size tires. ) Quote Link to comment Share on other sites More sharing options...
Lewis Posted January 6, 2007 Share Posted January 6, 2007 I know you said you cant afford a winch bumper but this may be of some use. It was an RDS tubular bumper with the centre section cut out beneath the A-bar, and a second-hand warn winch plate that came off an old M8000 welded into the gap. The mounting holes were welded up in the bumper and re-drilled to allow the bumper to sit further back against the rad and it leaves a good approach angle. Sorry, not the best photo Lewis Quote Link to comment Share on other sites More sharing options...
oakeedokee Posted January 6, 2007 Author Share Posted January 6, 2007 Thanks for the photos, Marc and Lewis. it's given me inspiration! The reciprocating saw and angle grinder have been put to good use today. I've decided to weld the plate mid-way up the chassis legs to keep the approach angle as close to original as possible. I still haven't decided on how or where to attach the bumper tubes but I'm hoping it will all fall into place as I proceed. I'll take some photos as soon as I get my camera repaired. Quote Link to comment Share on other sites More sharing options...
Redeye Posted January 7, 2007 Share Posted January 7, 2007 this is my creation all made from 5mm steel apart from the front plate thats 10mm well it's all i had left and i've not bent it yet! the winch cradle also bolts down to the brace between the chassis rails. Quote Link to comment Share on other sites More sharing options...
freeagent Posted January 7, 2007 Share Posted January 7, 2007 thats a nice bit of fabrication... but i'd keep an eye on those recovery points mounted so high up, they'll exert a lot of leverage on the bumper mounts when used in anger... much better to get them in line (horizontally) with the bumper mounting points... if you were using them to lift the vehicle straight up in the air, they'd be perfect. hope you don't take offence, i know a little bit about engineering and stuff, and reckon you might be surprised at the force those recovery points will see.... Quote Link to comment Share on other sites More sharing options...
DEANO3528 Posted January 8, 2007 Share Posted January 8, 2007 I have to agree. They are really high up aren't they. Must be 6 inches of extra leverage there. Don't get me wrong it's a nice piece of gear but rec points attached to the steering guard would have been better. My pick-up had them mounted along the chassis rails... ...which seemed to work ok but no winch plate of course. Quote Link to comment Share on other sites More sharing options...
v8bertha Posted January 9, 2007 Share Posted January 9, 2007 How do you get on with the winch being so low down? Does the tray fill up with carp too easily? Marc, looking at your photo have you removed one of the stays that support the bonnet release? Does that affect it's operation? I've had no problems with it being low down so far, despite burying it in some sticky mud! I did make a couple of largish holes in the bottom of the tray so that things would drain out easily. I think they were about 45mm holes. I removed both of the stays. Not really a problem for me cos I've got rid of the standard bonnet release mechanism and just gone for bonnet pins instead. Quote Link to comment Share on other sites More sharing options...
Andy Posted January 9, 2007 Share Posted January 9, 2007 apart from the mounting loads caused by high recovery points, wouldnt ones that far above chassis line tend to dig the front of the car in? where as lower mounted ones should help lift the front out of the goo? Quote Link to comment Share on other sites More sharing options...
q-rover Posted January 10, 2007 Share Posted January 10, 2007 Only if the attachment point on the recovering vehicle is lower. IE the recovery is 'going downhill' This could be said for all recoveries though, but high recovery points would make this scenario more susceptable Quote Link to comment Share on other sites More sharing options...
teslo Posted September 19, 2007 Share Posted September 19, 2007 Few photos of my winch bumper. Quote Link to comment Share on other sites More sharing options...
jules Posted September 21, 2007 Share Posted September 21, 2007 cheeting I bought mine it know has a T-Max comp fitted Quote Link to comment Share on other sites More sharing options...
Orange Posted October 3, 2007 Share Posted October 3, 2007 Here's mine... It's a slightly modified Southdown Bumper picked up from another forum member. Mounts nice and snugly to the front of the car and leaves a *good* approach angle. * read good for a RRC!!! And a profile shot... If it's an auto, you might need to move the oil cooler out of the way... SEE HERE Quote Link to comment Share on other sites More sharing options...
oakeedokee Posted October 6, 2007 Author Share Posted October 6, 2007 I finally got around to taking some photos of the finished article. I decided to weld the mounting plate mid way up the chassis rails. It is welded horizontally across the front of the rails, horizontally along the length of the rails, then vertically up the sides and finally horizontally along the front cross member, so is welded in three dimensions if you like. Its stood up to some pretty tough winching so I'm quite pleased with it, although I need to scrap the bumper which is the original with a section removed from the centre and replace it with some welded on box section, as it bends very easily when up against trees. Quote Link to comment Share on other sites More sharing options...
COLD SURFER Posted October 8, 2007 Share Posted October 8, 2007 no pics at this time, but I got a welded up craddle from www.dap-inc.com and my 10,000 winch dropped right in after some hacking away of the bumper of my RRC. Made 2 - 2" cuts into the lower part of the bumper about 2' across and bend/pounded/folded the heavy bumper metal forward to allow the winch to rotate 90 degrees forward. the mount was pre-drilled, zinc washed, and 1/4" thick. Don't know if DAP sources the mount from the UK or not, but it's faster and cheaper to go this route from my experience mounting on other vehicles that had serious pressure applied to the mounts during their life. The unit mounts between the bumper mounts. U shaped channel with box welded ends. Quote Link to comment Share on other sites More sharing options...
