kevin50 Posted May 25, 2020 Share Posted May 25, 2020 Noticed another Problem today as well as my Others diesel leaking from Wading plug hole at bottom of Timing Case, didn't know Diesel could get through that way. Had new Timing Belt and Seal not long ago but Suspect Seal, or could it be something else ? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 25, 2020 Share Posted May 25, 2020 The front seal on the injection pump has failed. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 25, 2020 Author Share Posted May 25, 2020 7 minutes ago, vulcan bomber said: The front seal on the injection pump has failed. Is it Behind the Case where Timing Belt Is ? Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted May 26, 2020 Share Posted May 26, 2020 It's part of the pump, you'll need to remove the pump to replace the seal/send it to a specialist Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 27, 2020 Author Share Posted May 27, 2020 (edited) Is this the right Tool I need to remove Pump https://www.ebay.co.uk/itm/Big-Red-Tools-12-Piece-Land-Rover-Timing-Kit-for-Diesel-Engines-SWE145/321984610886 Edited May 27, 2020 by kevin50 Quote Link to comment Share on other sites More sharing options...
western Posted May 27, 2020 Share Posted May 27, 2020 Yes 👍 that kit will allow you to remove the pump without removing the timing belt. Quote Link to comment Share on other sites More sharing options...
reb78 Posted May 27, 2020 Share Posted May 27, 2020 I would replace the timing belt again though if it has been doused in diesel... That looks like a fair leak? Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 27, 2020 Author Share Posted May 27, 2020 32 minutes ago, western said: Yes 👍 that kit will allow you to remove the pump without removing the timing belt. Thanks Quote Link to comment Share on other sites More sharing options...
cackshifter Posted May 27, 2020 Share Posted May 27, 2020 I'm not saying the belt is ok, but they don't seem to mind oil. I have a lathe that has a belt running in the gearbox, under oil, and Honda made a small engine with the timing belt inside. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 27, 2020 Author Share Posted May 27, 2020 8 minutes ago, cackshifter said: I'm not saying the belt is ok, but they don't seem to mind oil. I have a lathe that has a belt running in the gearbox, under oil, and Honda made a small engine with the timing belt inside. Wasn't sure to take a chance on the Belt, It was just fitted new couple of months ago with pully and oil seal also new water pump, Has not been ran much since then, maybe 6 or 7 times Idling, and no more then 10 minuets Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 27, 2020 Share Posted May 27, 2020 Don’t chance it - the price of a new belt is nothing compared the cost if it slips or fails. 1 Quote Link to comment Share on other sites More sharing options...
western Posted May 27, 2020 Share Posted May 27, 2020 I would advise replacing the timing belt Kev, then you know it will not fail due to contamination. Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 27, 2020 Author Share Posted May 27, 2020 Change of Plan, not going for the Tool as wont get it till next week sometime, Mates gonna take cover and belt off to get at it properly, so that way can Check Belt and anything else in there, Called in to Local Diesel Specialist today and he is going to put the Seal in for me if I take Pump to him. 1 Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 28, 2020 Author Share Posted May 28, 2020 Doesn't look to bad in there, Belt was a little wet but has dried out completely now, Gonna spray brake cleaner or something and clean everywhere before putting back together. Pump is at Diesel place to get seal, hopefully ready to pick up tomorrow. Only Diesel No sign of any Oil Leaks. Quote Link to comment Share on other sites More sharing options...
western Posted May 28, 2020 Share Posted May 28, 2020 that's good news. Quote Link to comment Share on other sites More sharing options...
Mutley Posted May 29, 2020 Share Posted May 29, 2020 As others have said personally i WOULD change the timing belt! Just for knowing how Diesel can affect rubberized items like seals and such likes, they seem to soften, expand and perish after being in contact with diesels!?! Diesel is a freaky weird substance at times!?! When used in certain situations such us a penetrator or cleaner it's great, but when in contact with certain other components such as rubber and the likes it's quite destructive!?! Just my observations Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 29, 2020 Author Share Posted May 29, 2020 2 hours ago, Mutley said: As others have said personally i WOULD change the timing belt! Just for knowing how Diesel can affect rubberized items like seals and such likes, they seem to soften, expand and perish after being in contact with diesels!?! Diesel is a freaky weird substance at times!?! When used in certain situations such us a penetrator or cleaner it's great, but when in contact with certain other components such as rubber and the likes it's quite destructive!?! Just my observations I know Mate, Just trying to save a bit, sick of spending now, hard times anyway. but you are right, my local Landy shop should have one in tomorrow. Another thing I meant to ask, I didn't get the Tool to refit, what size Bolt or Drill Bit is used as the Pin when setting it up ? Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2020 Share Posted May 29, 2020 9.5mm drill bit shank can be used as a timing pin for the injection pump Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 29, 2020 Author Share Posted May 29, 2020 36 minutes ago, western said: 9.5mm drill bit shank can be used as a timing pin for the injection pump Thanks Mate, Probably have every size apart from that one. 1 Quote Link to comment Share on other sites More sharing options...
western Posted May 29, 2020 Share Posted May 29, 2020 Always the one we don't have 🙄 Quote Link to comment Share on other sites More sharing options...
Snagger Posted May 30, 2020 Share Posted May 30, 2020 If you can get an old R380 reverse light switch from your local garage, they work well as a flywheel locking tool. They may have a broken one in a bin or a work used one that they’d sell cheaply. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted May 30, 2020 Share Posted May 30, 2020 NEVER reuse a timing belt. even a new belt that has been fitted, taken off, then refitted Quote Link to comment Share on other sites More sharing options...
kevin50 Posted May 30, 2020 Author Share Posted May 30, 2020 Disaster. We refitted Pump set Timing up as before when we originally changed belt and pulleys, it starts with a bit if a struggle, but chucking loads of Black smoke / Fumes. won't idle Just cut's out. It's like it could be Over fuleing. What have we done wrong ? Quote Link to comment Share on other sites More sharing options...
Mutley Posted May 30, 2020 Share Posted May 30, 2020 Did you lock off/secure the fuel pump??? Through the centre of top left sprocket as you look at the engine, it also locks up the timing cycle. Quote Link to comment Share on other sites More sharing options...
Mutley Posted May 30, 2020 Share Posted May 30, 2020 Sounds like it wasn't stopped at TDC or it has moved in the process of the refitting??? Quote Link to comment Share on other sites More sharing options...
