Vent ABS System
WesBrooks
Hi all,
Whats the standard procedure for venting the '94 ABS system (RRC) before disassembly?
Are the brake fittings a standard thread rather than tapered? I was toying with the idea of buying a job lot of small bolts to screw back into the holes once brake pipes are removed to keep the internals clean after disassembly.
Edited by WesBrooks
If the pump is disabled, then every time you apply the pedal, the accumulator will lose a little pressure, so leave the ignition off and pump the pedal as elbekko said.  Once that’s been done, it should be depressurised, but I’d start by slowly undoing the bleed nipples on the valve pack and accumulator.  It’s worth unplugging the pump just to avoid accidental pressurisation should you forget while whorking.
On 6/1/2020 at 8:58 AM, WesBrooks said:
Thanks, will do that.
Pump, block, and controller unplugged. No front loom or fuseboxes left on the vehicle! 🙂
Are you reusing the brake system Wes?
More out of surprise and interest than anything, but there's a hydraulic accumulator in the brake system?
42 minutes ago, elbekko said:
Still separate from the valve block on the P38, it's together with the pump.
Yup exactly, can bed on a Classic to replace pump and separate accumulator -one way of getting slightly newer second hand parts to keep yours running!
If it was me, if the ABS system from the classic didn't work, I'd be looking to find one that did not fall back on the non-ABS system from the discovery.
Having owned vehicles with both, the RR ABS system is massively better, even if the ABS isn't functioning. More powerful, arguably better feel.
Softdash era classics definitely come across as customer funded test mules! The ABS, traction control, intermediate Serp V8s, and air suspension were all early but similar versions to that seen in the P38s?
Edited by WesBrooks
On 6/7/2020 at 8:13 AM, WesBrooks said:
I certainly intend to keep the ABS. Don't think the '94 (14CUX) had traction control did it?
Pretty certain it was an option - don't think it was ever standard - but my '93 had TC. As Snagger says, rear axle only on the classic (and earlier P38s) - but it's still pretty effective.
I'd say that's an entirely fair comment! Started before the softdash (from '93? EAS wasn't available before that, don't think TC was. The intermediate serp V8s were later).
Would using a hand vacuum to clear the brake fluid cause any issues?
I realise that it won't be an issue of just draining the caliper bleed nipples but wanted to make sure the obvious answer isn't likely to cause issues like the intuative way of  rotor arm removal on V8s!
It might not work. Maybe for the front brakes, but you'll want the valves in the valve block to open up while bleeding. So either using the pedal with the ignition on, or opening them with diagnostics (at least on the P38).
Certainly for the EAS.  It took me two years to find my soft dash Tdi Vogue (non-SE) - factory coil sprung, cloth manual seats (no crackEd leather and no trouble prone switches, motors or ECUs), no leaky sunroof, no huge fuel bill, and an R380 that doesn’t sap too much of the Tdi’s lesser performance.  Not that many of this spec about.
  • Like 1
Should be fine for removing the fluid, but not necessary.  But for bleeding, there is a very specific sequence in the manuals, and it is done by the pump.
