Mutley Posted February 3, 2022 Share Posted February 3, 2022 Can somebody please tell me what size Banjo Hose I need to fit for the Bonjo breather bolt??? Have found the bolt on ebay genuine at a good price, a fiver each so just need the hose tail part. Cheers Andy Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 3, 2022 Share Posted February 3, 2022 With acknowledgment to @FridgeFreezer as I had copied this ages ago from a post of his, try this: Fittings are 1/8" BSP thread, 6mm push-fit tube is the standard (just buy a 10 or 30m reel), Camozzi nickel-plated brass fittings are nice and robust compared to the plastic ones. Any decent hydraulics place should have them. Don't buy stainless, they're 5x the price. Axles, R380 and LT230 breather are all 1/8" BSP not sure about anything else. Think your front cover needs one but sure a TDi owner could confirm. In an ideal world going to 1/4" and bigger bore 8-10mm pipe gives a far freer flow and improved breathing but that involves drilling & tapping. As you can gather from this, it’s more convenient to replace the banjo fittings with push fit screw-in elbows. 1 Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 4, 2022 Author Share Posted February 4, 2022 @Peaklander thanks for that bit of info. So what size is fitting that the Banjo bolt goes through and the pipe work pushes onto? I know it has a copper washer top and bottom, no idea what it's called??? Thanks again Andy Quote Link to comment Share on other sites More sharing options...
Peaklander Posted February 4, 2022 Share Posted February 4, 2022 I can see that it isn't listed as a separate item on LR diagrams, only with the pipe. It's called a banjo union. You can buy generic ones in various sizes - just get the correct size for your banjo bolt. I still think the push fit elbows would be better. Quote Link to comment Share on other sites More sharing options...
hurbie Posted February 4, 2022 Share Posted February 4, 2022 2 hours ago, Peaklander said: I still think the push fit elbows would be better. i agree with that , the hole in the banjo bolt is so small , it takes nothing to clog up with moisture and causing rust , and blocking your breather . the hole in a pushfit elbow is way bigger ! Quote Link to comment Share on other sites More sharing options...
92a Posted February 4, 2022 Share Posted February 4, 2022 10mm (just put one on a drill bit) If you only need one of the steel fittings PM me and I'll post you one ? Quote Link to comment Share on other sites More sharing options...
Daan Posted February 4, 2022 Share Posted February 4, 2022 This is what I use, stopped all blockages: https://gwynlewis4x4.co.uk/product/200tdi-300tdi-axle-breathers/ Daan Quote Link to comment Share on other sites More sharing options...
Mutley Posted February 4, 2022 Author Share Posted February 4, 2022 Thanks guys I'm with the program now! Thanks for the link @Daan pictures I can understand!?! @92a thanks for your very kind offer, but I think I will now invest in this push pull set up. There that wasn't so hard was it!?! Cheers all Andy Quote Link to comment Share on other sites More sharing options...
Giles Posted February 5, 2022 Share Posted February 5, 2022 I have Camozzi fittings too - they cost me just over 2€ each with the vat. It's much better to get the swivel ones, not the fixed ones on the GL site, as this makes it way easier to remove for maintenance, pipe re-routing etc. FYI, if it isn't obvious, the standard LR tube is 6mm and pushes straight in Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 5, 2022 Share Posted February 5, 2022 Can you tell I cleaned the truck yesterday? 1/8" BSP to 6mm push-fit tube is what directly replaces the genuine Land Rover ones, I went out to 1/4" BSP (re-drilled and tapped the axle) and 8 or 10mm tube as it breathes way easier.The Finns taught me that one, when a hot axle hits a frozen puddle in the tundra it takes a surprisingly deep breath If you're doing axles & gearbox etc. at the same time a 30m reel of hose in a colour of your choice is often the cheapest thing to buy, and a party pack of black cable ties, that way you can go wild and crazy with the routing and bring it up somewhere nice and protected. My front axle comes up into the air box, the gearbox etc. all join up and are run up inside the B-pillar and I think the back axle comes up in the back of the truck, but I've slept since I did that so can't remember for sure Quote Link to comment Share on other sites More sharing options...
uninformed Posted February 6, 2022 Share Posted February 6, 2022 @FridgeFreezer the next step after that is to pressurise the housing (axle, gearbox, t/case) with 2-3psi 🙂 most of the comp guys here have been doing that for 20 years. But I like what you’ve done 👍 Quote Link to comment Share on other sites More sharing options...
