Gazzar Posted Friday at 09:06 AM Share Posted Friday at 09:06 AM Any plastic experts on here? What type of plastic would work as an inter leaf shim material? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted Friday at 09:08 AM Share Posted Friday at 09:08 AM I'd guess UHMWPE or similar - very slidy stuff. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted Friday at 09:27 AM Author Share Posted Friday at 09:27 AM Tough enough? It doesn't deform or anything? Quote Link to comment Share on other sites More sharing options...
Daan Posted Friday at 10:46 AM Share Posted Friday at 10:46 AM For friction coeficient, PTFE (teflon) is best. Ideally teflon to teflon, so you would need 2 layers. other wise nylon will be ok I'd say. Are these the 101 springs? Not sure if they have the joggle at the end like aftermarket ones do. This means they only touch at the bushing ends, 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted Friday at 11:09 AM Share Posted Friday at 11:09 AM Oilon would work nicely.... but I've only seen it as a thicker 'plate' rather than anything shim-like. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted Friday at 11:20 AM Author Share Posted Friday at 11:20 AM Yes, 101 springs. They taper in their length, and touch at the ends. No joggle. I did wonder at putting a shim along the full length to eliminate wear. But no idea how that would work. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted Friday at 11:20 AM Author Share Posted Friday at 11:20 AM 11 minutes ago, landroversforever said: Oilon would work nicely.... but I've only seen it as a thicker 'plate' rather than anything shim-like. There are so many plastics, I'm easily confused. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted Saturday at 08:32 AM Share Posted Saturday at 08:32 AM PTFE would be good. It was used for its non-binding under high load and general thermal and chemical stability on the wing pivots on Tornado, so should be good at producing non-bind for breakout forces on springs. The only concern I have is it getting abraded by dirt, but it will still protect the steel regardless. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted Saturday at 02:51 PM Share Posted Saturday at 02:51 PM 6 hours ago, Snagger said: PTFE would be good. It was used for its non-binding under high load and general thermal and chemical stability on the wing pivots on Tornado, so should be good at producing non-bind for breakout forces on springs. The only concern I have is it getting abraded by dirt, but it will still protect the steel regardless. I’d be worried about adding a softer material to the spring packs that can get abrasive materials embedded in it. That’s then just going to abrade everything. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted Saturday at 07:12 PM Share Posted Saturday at 07:12 PM There's special dry moly based lubricant spray available, try a Google search, may have been Wurth or Ambersil. Quote Link to comment Share on other sites More sharing options...
hurbie Posted Saturday at 07:22 PM Share Posted Saturday at 07:22 PM i would take the springs apart , clean and paint , then put them together with some normal grease between the leafs (where they touch). Quote Link to comment Share on other sites More sharing options...
Gazzar Posted Saturday at 07:29 PM Author Share Posted Saturday at 07:29 PM Yes, that's the plan. Quote Link to comment Share on other sites More sharing options...
Snagger Posted Sunday at 02:52 PM Share Posted Sunday at 02:52 PM 19 hours ago, hurbie said: i would take the springs apart , clean and paint , then put them together with some normal grease between the leafs (where they touch). That’s all I have ever done. Some people like more, and some parabolics have plastic slipper blocks, but I don’t think parabolics need anything more than an occasional clean and grease. Quote Link to comment Share on other sites More sharing options...
hurbie Posted Sunday at 03:05 PM Share Posted Sunday at 03:05 PM i work with HGV's and these use a lot off parabolic springs , i hardly ever see plastic spacers in use . in the middle where the leafs touch each other and the strops are placed , there's normally a steel spacer (i wouldn't use plastic here because this will get compressed and cause the strops to get loose). at the end of the leave's there's normaly a rubber or plastic "slipper" pad , these are the only place's paraballics touch each other . Quote Link to comment Share on other sites More sharing options...
Gazzar Posted Sunday at 05:05 PM Author Share Posted Sunday at 05:05 PM I think the plastic shims were fitted from new from the factory. I doubt the MOD fitted them and this truck wasn't used after being cast. Quote Link to comment Share on other sites More sharing options...
hurbie Posted Sunday at 08:00 PM Share Posted Sunday at 08:00 PM 2 hours ago, Gazzar said: I think the plastic shims were fitted from new from the factory. I doubt the MOD fitted them and this truck wasn't used after being cast. did the 101 came with parabolic springs from the factory ? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted Sunday at 09:47 PM Author Share Posted Sunday at 09:47 PM They're taper leaf springs as standard. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted Sunday at 10:24 PM Share Posted Sunday at 10:24 PM 36 minutes ago, Gazzar said: They're taper leaf springs as standard. What do you mean by taper leaf springs Gazzar? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted 20 hours ago Author Share Posted 20 hours ago They get thinner as you go away from the axle. Can't spell elliptical. 1 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted 20 hours ago Share Posted 20 hours ago Ahh thank you! Quote Link to comment Share on other sites More sharing options...
Gazzar Posted 19 hours ago Author Share Posted 19 hours ago There will be photos soon, on the build thread. Quote Link to comment Share on other sites More sharing options...
