vulcan bomber Posted January 22 Share Posted January 22 So, I'm about ready to loose my rag with the fuse box in the 110. It's 1989 vintage so we are on Glass fuses. Is there an obvious way of converting over to Blade fuses as per the 200s onwards? Quote Link to comment Share on other sites More sharing options...
hurbie Posted January 22 Share Posted January 22 you can use a aftermarket blade fuse box , snip off the end's of the wiring and crimp on new terminals to fit the new fusebox . if you want to go the original route , it takes some time to find the right fusebox , and more difficult , the right connectors for it . Quote Link to comment Share on other sites More sharing options...
western Posted January 22 Share Posted January 22 Pretty sure there is a post in here about swapping from glass to blade fuses, IIRC it use 2 x VWP 10 blade fuse boxes. Quote Link to comment Share on other sites More sharing options...
western Posted January 22 Share Posted January 22 Found it - - - Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 22 Share Posted January 22 https://fuddymuckers.co.uk/wiki/doku.php?id=alfie:fusebox_upgrade 1 Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 22 Author Share Posted January 22 Thanks chaps, these methods I'm aware of and probably the way I'll go, I'm open to other suggestions at the moment as well. Quote Link to comment Share on other sites More sharing options...
hurbie Posted January 22 Share Posted January 22 other methode would be to buy a new loom .... Quote Link to comment Share on other sites More sharing options...
Paul C Posted January 22 Share Posted January 22 Prc4826 is the blade fuseholder 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 23 Share Posted January 23 I might have a fuse holder and a bracket in the shed somewhere off the 300tdi if you want them ? Quote Link to comment Share on other sites More sharing options...
Sigi_H Posted January 23 Share Posted January 23 Just for your interest. To avoid a central fuse box at all: Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 23 Author Share Posted January 23 5 hours ago, ianmayco68 said: I might have a fuse holder and a bracket in the shed somewhere off the 300tdi if you want them ? Yes please that would be worth a look. Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 23 Share Posted January 23 I’ll have a look, it’s about somewhere might take a day or two as I tend to put stuff in a safe place these days, but it’s normally that safe I can’t find it when I need it 😁. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted January 23 Share Posted January 23 @vulcan bomber I have these if they are any good to you Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted January 23 Share Posted January 23 Those Durite ones look like the ones I used. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 23 Share Posted January 23 I want to say Autosparks sell the drop in replacements as used on their looms. But I've not looked for a while. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 23 Author Share Posted January 23 2 hours ago, landroversforever said: I want to say Autosparks sell the drop in replacements as used on their looms. But I've not looked for a while. They are listed on there website. 1 Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 23 Share Posted January 23 @vulcan bomber found them quite easily, which is a surprise. sorry pics not very good, just got home and didn’t check them before I came out of the shed. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 23 Author Share Posted January 23 2 hours ago, ianmayco68 said: @vulcan bomber found them quite easily, which is a surprise. sorry pics not very good, just got home and didn’t check them before I came out of the shed. How much? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted January 23 Share Posted January 23 Oooooohhhhhhhh very expensive 🤔🤔🤔, no charge just cover the postage if you want them. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted January 23 Author Share Posted January 23 1 hour ago, ianmayco68 said: Oooooohhhhhhhh very expensive 🤔🤔🤔, no charge just cover the postage if you want them. Pm on the way. Quote Link to comment Share on other sites More sharing options...
