FridgeFreezer Posted March 16, 2007 Share Posted March 16, 2007 Since I'm intending to fabricate some sort of dash panel for the 109 I was pondering how to make holes for the dials - hole saws are all well and good but they're not terribly accurate. I acquired a 30mm one of these from an abandoned cupboard at work and thought it was neat, and lo and behold after a bit of googling I found that they're not that expensive and you can get 52mm ones for putting gauges into panels: Q-Max 52mm punch Thought I'd share it as a useful alternative to hole-saws, and you can get ones that make square holes too (very handy for square switches). Quote Link to comment Share on other sites More sharing options...
biasbilt Posted March 16, 2007 Share Posted March 16, 2007 Since I'm intending to fabricate some sort of dash panel for the 109 I was pondering how to make holes for the dials - hole saws are all well and good but they're not terribly accurate. I acquired a 30mm one of these from an abandoned cupboard at work and thought it was neat, and lo and behold after a bit of googling I found that they're not that expensive and you can get 52mm ones for putting gauges into panels:Q-Max 52mm punch Thought I'd share it as a useful alternative to hole-saws, and you can get ones that make square holes too (very handy for square switches). I've used them and my dad bought some on my advice, and provided that you are only trying to cut holes in thin material they do a good job. They also don't tear thin sheet like hole saws do. Well recommended. Toby Quote Link to comment Share on other sites More sharing options...
LR90 Posted March 16, 2007 Share Posted March 16, 2007 Having spent several (enjoyable) hours cutting and filling out square holes for switches these do sounds like a handy tool. Quote Link to comment Share on other sites More sharing options...
Lewis Posted March 16, 2007 Share Posted March 16, 2007 I have a set of those requisitioned into my toolbox at work, they leave a nice bevelled edge on one side too Quote Link to comment Share on other sites More sharing options...
smo Posted March 17, 2007 Share Posted March 17, 2007 They look very handy for the money, might have to get some of them for fabricating my new dash Quote Link to comment Share on other sites More sharing options...
Rustyrangie Posted March 18, 2007 Share Posted March 18, 2007 I've used these in the past for making up one off bits of radio test equipment. The large ones struggle a bit on 16gauge steel but in general they do a great job. They get a bit pricey if you need a few though. Have you tried a stepped conecut? I'll try and find out some deatails and post them on here. Bob Quote Link to comment Share on other sites More sharing options...
Rustyrangie Posted March 18, 2007 Share Posted March 18, 2007 I've used these in the past for making up one off bits of radio test equipment.The large ones struggle a bit on 16gauge steel but in general they do a great job. They get a bit pricey if you need a few though. Have you tried a stepped conecut? I'll try and find out some deatails and post them on here. Bob As promised, Found them in the RS catalogue. they're called a "multicut" The photo didn't copy, look on the RScomponents site for one if you're interested All products in this category HSS PG29 European conduit drill RS Stock no. 325-6616 Quantity Price 1+ £46.90 S Y In stock Priced as: Each Dearer than I thought but they do work very well and leave a burr free finish on one side with just a bit of burring on the other. Bob Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted March 18, 2007 Author Share Posted March 18, 2007 They're big bucks from RS, as are stepped cone drills. Machine Mart do a set of 3 cone drills for £35 from 4-30mm between them. Frosts do a set of these punches for ~£45 but don't include the 52mm one which is cheapest from the first link I posted. Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 19, 2007 Share Posted March 19, 2007 They're nice, they produce round holes unlike drill bits that don't (in thin material). standard tool for fitting VHF aerials in roof panels. Quote Link to comment Share on other sites More sharing options...
geoffbeaumont Posted March 19, 2007 Share Posted March 19, 2007 Is it just me, or do the punch keys look suspiciously like bog standard allen keys? Quote Link to comment Share on other sites More sharing options...
Tonk Posted March 20, 2007 Share Posted March 20, 2007 they are standard allen keys stepped drills also get the thumbs up best thing i use is a cnc punch machine but thats probably a bit big for home use Quote Link to comment Share on other sites More sharing options...
HoSS Posted March 20, 2007 Share Posted March 20, 2007 I actually don't like these for making holes when tidyness is the key. They tend to warp the panel as they pull through, especially if close to an edge. I have made two dash boards recently, one from Ali and the second from wood (don;t ask- just didnt like the first ones layout, after spending >20 hours on it) I used the adjustable rotary type of cutter in a pillar drill. Link makes a clean hole in wood or metal, and is fully adjustable so you only need to buy one. and on top of that you can resharpen it. Quote Link to comment Share on other sites More sharing options...
101nut Posted March 20, 2007 Share Posted March 20, 2007 I used the adjustable rotary type of cutter in a pillar drill. Linkmakes a clean hole in wood or metal, and is fully adjustable so you only need to buy one. and on top of that you can resharpen it. Works great in a fixed drill press but is 'orrible if hand-held in a power drill ... AndyG Quote Link to comment Share on other sites More sharing options...
HoSS Posted March 26, 2007 Share Posted March 26, 2007 Works great in a fixed drill press but is 'orrible if hand-held in a power drill ...AndyG Absolutely, pillar drill only. Quote Link to comment Share on other sites More sharing options...
