Turbocharger Posted March 22, 2010 Share Posted March 22, 2010 Have seen the following engines all in the same 90. Ford 3litre V6, Jag 4.2 straight six, Went well but had dreadful oil surge on the hills, and heavy!! Ford Windsor 302, nice transplant, Chevy 350 small block, Best but was a bit heavy, Mopar 440, Too heavy and a tight fit! Then 440 with blower fitted! Went well but was much too heavy! Rover V8 4.2, Probably the best compromise. Lara I bet that went well, must be more than 1000bhp! Quote Link to comment Share on other sites More sharing options...
JensM Posted March 22, 2010 Share Posted March 22, 2010 Over here, it's not that uncommon to put a 4 litre Volvo truck engine in RRCs. First few pics in this thread give you an idea of how it looks: http://slrk.phpbb2.se/board/range-rover-td40-76-projektet-t1060.htm A friend of mine ran that conversion in a RRC. Good engine for roadwork, never got to try it offroad, though... Quote Link to comment Share on other sites More sharing options...
petethepilot Posted March 23, 2010 Share Posted March 23, 2010 I bet that went well, must be more than 1000bhp! Probably a lot more, but kinda crowded under the hood... Quote Link to comment Share on other sites More sharing options...
heath robinson Posted March 23, 2010 Share Posted March 23, 2010 As a slight reversal, I saw a home-made looking boat upstream from Bristol this weekend, with a 200tdi in it... Quote Link to comment Share on other sites More sharing options...
LandyLee Posted March 23, 2010 Share Posted March 23, 2010 anyone seen an orange six wheel defender with a gmc v8 diesel in it , 3 sp auto box if I remember,,, it was around here a few years ago , about the same time a somerset guy used to fit 2.8 mitsubishi td engines in to range rovers and discos ,,,, Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 24, 2010 Share Posted March 24, 2010 HA HA !!! I had one of them in my old RRC What a total nightmare to start on cold days, 1 small pre heater in the inlet manifold trying to start 6 cyl My solution to the 6 pot York starting was to install 6 long preheaters in the manifold pointing down each inlet towards the valve. Then I added a diesel powered 'flame thrower' in the throttle body. Preheat for 30 seconds and then ignite the flame thrower and then the start button. Worked even in snow! Never needed easy start and sounding like a tractor was the best bit! I like the sound of this Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted March 24, 2010 Share Posted March 24, 2010 Ahhhhhh, music to my ears! you cant beat the sound of a nice big diesel lump. Nice idea about the pre heat on the York, Other than the starting problems, i thought it was quite a good set up in my RRC. I would like to put a V8 diesel in an old Fordson Major i have Maybe one day! Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 25, 2010 Share Posted March 25, 2010 I always prefered diesels that sound like they should have 38 tons+ behind them then ones that sound like italian taxis queuing for a fare. Also 6 inline sounds better as a diesel then V8s like the GMCs. V8s should be petrol really. Now, I have a workshop manual for a Rolls Royce CV12 and there is a small add in a recent tractor magazine for the same engine.... That would make an interesting conversion! Quote Link to comment Share on other sites More sharing options...
milliejasper1111 Posted March 25, 2010 Share Posted March 25, 2010 All i need now then, are 3 more CV12s, glue them together and join the dark world of tractor pulling! Ian Quote Link to comment Share on other sites More sharing options...
HPLP Posted March 25, 2010 Share Posted March 25, 2010 As a slight reversal, I saw a home-made looking boat upstream from Bristol this weekend, with a 200tdi in it... Well not so off.....I helped fit 2 200tdis to a ex east german offshore patrol boat. It runs very well and has a distinctive roar at flat out! H Quote Link to comment Share on other sites More sharing options...
lrfarmer Posted March 25, 2010 Share Posted March 25, 2010 I like the sound of this sounds the same as mine but go's better in the land rover than my combine but the combine dose come in at 6 ton Quote Link to comment Share on other sites More sharing options...
longlandy Posted June 21, 2010 Share Posted June 21, 2010 I run a cummins 6bt in my selfbuilt 6x6 landrover using a zf 5-42 box Quote Link to comment Share on other sites More sharing options...
steve b Posted June 21, 2010 Share Posted June 21, 2010 lets see some pics then , how did you do the drive to the 3rd axle ? cheers Steveb Quote Link to comment Share on other sites More sharing options...
Night Train Posted June 21, 2010 Share Posted June 21, 2010 I run a cummins 6bt in my selfbuilt 6x6 landrover using a zf 5-42 box I'd love to see how you did it too. I had to scratch build a 3 speed transfer box for mine. Quote Link to comment Share on other sites More sharing options...
longlandy Posted June 22, 2010 Share Posted June 22, 2010 I did have a splitter box to give two outputs, though this is not on the car at the mo since fitting the cummins(no room!)I have designed a twin output transfer box which I may make myself(I own engineering firm)though a company involved with landrovers is interested in the design. The problems with the ashcroft/ foley unit is the price,use of week rover axles and custom parts in the event of failure. Quote Link to comment Share on other sites More sharing options...
Night Train Posted June 22, 2010 Share Posted June 22, 2010 I did have a splitter box to give two outputs, though this is not on the car at the mo since fitting the cummins(no room!)I have designed a twin output transfer box which I may make myself(I own engineering firm)though a company involved with landrovers is interested in the design. The problems with the ashcroft/ foley unit is the price,use of week rover axles and custom parts in the event of failure. Excellent! Do you have photos that you can post? It would be good to see a thread on your conversion. Quote Link to comment Share on other sites More sharing options...
longlandy Posted June 22, 2010 Share Posted June 22, 2010 I may do a thread if people are interested, have tried on a "clique" forum,but it got ignored while they patted each other on the backs for riveting on a bit of cheq plate. Quote Link to comment Share on other sites More sharing options...
steve b Posted June 22, 2010 Share Posted June 22, 2010 Go for it , its all about innovation and sharing here fella Its always good to see anothers take on it cheers Steveb Quote Link to comment Share on other sites More sharing options...
bluespanner Posted June 22, 2010 Share Posted June 22, 2010 What would i need to put a nice 2.8 BMW in my 90 then? I'm thinking P38 DT R380... Quote Link to comment Share on other sites More sharing options...
Aragorn Posted June 23, 2010 Share Posted June 23, 2010 The P38 DT R380 bellhousing is the same part number as the 2.8i Defender, so that would be a fair starting point. The complete P38 gearbox however probably wouldnt work too well in a 90, so you'd likely have to swap the input shaft and bellhousing over into a 90 box. You'd then need to work out what landrover did for the clutch/flywheel etc. Again P38 DT bits might fit, but you'd have to compare the parts with whats fitted to the M50/52 engine as standard to see if they'd work. For example, the trigger ring for the engine management might be on the flywheel, and it might be different between the petrol and diesel engines. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted June 23, 2010 Share Posted June 23, 2010 I may do a thread if people are interested, have tried on a "clique" forum,but it got ignored while they patted each other on the backs for riveting on a bit of cheq plate. I always enjoy seeing other peoples' innovation. Can't wait to see what you've been making. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 24, 2010 Share Posted June 24, 2010 I always enjoy seeing other peoples' innovation. Can't wait to see what you've been making. Ditto, please post up longlandy Quote Link to comment Share on other sites More sharing options...
deepmud Posted June 28, 2010 Share Posted June 28, 2010 I sold my volkswagen 1.9td to a guy in Colorado who made an adapter for his old 66' Rover. http://www.66rover.com/VW%20TD/VW%20TD.html Quote Link to comment Share on other sites More sharing options...
