chris200100 Posted May 2, 2007 Share Posted May 2, 2007 Hi Folks, I'm new to the defender scene and was wondering can you replace the sliding windows on a 110 CSW with fixed ones or the new sliding ones??? Also how do you get the old ones off?? Quote Link to comment Share on other sites More sharing options...
western Posted May 2, 2007 Share Posted May 2, 2007 prise the rubber filler strip out & drill out all the rivtes [4mm drill bit IIRC] then prise the complete unit off the body side, fixed windows can be fitted just use a normal window seal similar to the front screen one. welcome to LR4x4.com hope you like it here Quote Link to comment Share on other sites More sharing options...
Top90 Posted May 2, 2007 Share Posted May 2, 2007 Personally I'd go for fixed ones.... All the sliding ones rattle once they are about 6 weeks old in my experiance. (Unless you jam something in them ) Rich Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 2, 2007 Share Posted May 2, 2007 And when they are 19 years old and battered by trees, the rattle big time ! Quote Link to comment Share on other sites More sharing options...
western Posted May 2, 2007 Share Posted May 2, 2007 And when they are 19 years old and battered by trees, the rattle big time ! mine don't Quote Link to comment Share on other sites More sharing options...
Holyzeus Posted May 3, 2007 Share Posted May 3, 2007 And leak Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 3, 2007 Share Posted May 3, 2007 Ralph, That's because yours have a few hundred kilos of equipment laying against them... They daren't move !! Quote Link to comment Share on other sites More sharing options...
western Posted May 3, 2007 Share Posted May 3, 2007 Ralph,That's because yours have a few hundred kilos of equipment laying against them... They daren't move !! Hmmm, you might be spot on there Quote Link to comment Share on other sites More sharing options...
Mr Bean Posted May 9, 2007 Share Posted May 9, 2007 I have an anti-vibration device slotted into the runners to stop them rattling. It's called timber. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 9, 2007 Share Posted May 9, 2007 They rattle squeak and leak in my brand new 110 but they all do it, god knows why they haven't managed to make a window that works in 24 years of building 110s I will be taking them out and fitting the solid 90HT type rear side windows in due course, I know they do not fit exactly but I think they can be made to fit. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 9, 2007 Share Posted May 9, 2007 My old Td5 110 (6 years old) have never rattled, and i opened them virtually every day for the dog to breathe. maybe i was just lucky! Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted May 9, 2007 Share Posted May 9, 2007 Matches work well - for a while. Quote Link to comment Share on other sites More sharing options...
JSG Posted May 10, 2007 Share Posted May 10, 2007 When I had my TD5 110 they were fine with no squeeks until I'd been offroading in it - then they rattled a bit. Quote Link to comment Share on other sites More sharing options...
Simon Smith Posted May 10, 2007 Share Posted May 10, 2007 Mine don't rattle after 15 years, I am always opening and closing them for the dog and they are quite tight and hard to move. Is this only a problem on the later ones? Quote Link to comment Share on other sites More sharing options...
Guest dew110CSW Posted May 10, 2007 Share Posted May 10, 2007 Mine never leak or rattle, they are opened quite regular. Maybe it's not being used that makes them rattle too much? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted May 10, 2007 Share Posted May 10, 2007 MOG leaks and rattles - or so I've heard Les. Quote Link to comment Share on other sites More sharing options...
Tomas Posted May 10, 2007 Share Posted May 10, 2007 After 6 years service in coil mines - my rattle when I just look at them. I was thinking about seal them with some kind of silicon that will stick to the rails, but not to the glass - say: - push the silicon to the rail - oil the window glass - push it close - wait the silicon to harden - try to open again Any comments if this should work or if it is the fastest way to get them replaced completely? Thx. Tomas Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 10, 2007 Share Posted May 10, 2007 I did something like you thought Tomas but the silicon failed, and basically just made a mess and fell out.... I recently put in strips of plastic (Used for packing plastic house windows when they are installed) and glued them in on one side only with Evo-stick... Yet to see how long they last but presently I am rattle free, and the windows still slide open.... I'll post a few shots if interested... Let me know Neil Quote Link to comment Share on other sites More sharing options...
Tomas Posted May 11, 2007 Share Posted May 11, 2007 Neil, Thanks, hat sounds as an interestring trick - I belive if you post few pics many others would appreciate too. Thanks, Tomas Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 11, 2007 Share Posted May 11, 2007 Now please respect shoddy work when you see it people.... I had no choice of colour when it came to plastic but the rattle has gone and you don't see the green bits when you pass the car at speed looking the other way ! Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2007 Share Posted May 11, 2007 Hmmm, looks like a top quality bodge job to me, will have a closer inspection next weekend if you bring the 110. Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 11, 2007 Share Posted May 11, 2007 Thank you for your words of encouragement ! New prop is installed and all re-greased underneath so the 110 is still the planned transport for next weekend Ralph... If I can take the lead boots off It'll be an opportunity to see what MPG I can get out of the old beast on a long run... Neil Quote Link to comment Share on other sites More sharing options...
western Posted May 11, 2007 Share Posted May 11, 2007 should fly along quite nicely then Quote Link to comment Share on other sites More sharing options...
Marcell Posted June 9, 2007 Share Posted June 9, 2007 My sliding windows also started to rattle more and more, until it rattled more than the sceam of my 300tdi So i drilled out the rivits, and fitted laminated 8mm glass , with a normal rubber seal, as used in the small windows on the sides of the rear door. Here are a photo. Quote Link to comment Share on other sites More sharing options...
OilIT Posted June 10, 2007 Share Posted June 10, 2007 I recently discovered that whilst i thought it was the glass rattling, a lot of it was due to some of the rivets having worked 'loose', after i drilled them out and re-riveted the rattles reduced considerably.......to check, open the sliding window, stick head in from outside and push frame in and out at the bottom, looking at the inside of the rivets - if this is the case you will see (or feel if you put your finger on it ) very slight movement - possible solution??? Quote Link to comment Share on other sites More sharing options...
