Hybrid_From_Hell Posted October 14, 2005 Share Posted October 14, 2005 When you say the ZF pump is still very slow, how slow is that compared to a Husky. Cols110.............., A husky looks positively "super rapid" in comparison ! Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 14, 2005 Share Posted October 14, 2005 For the tech archive:pics installs writeups please can you post the info on here, I can then cut and paste itinto the tech section TIA Tony Tony, u still want stuff for the 8274 section? no, i haven't made it hydrobollick Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 14, 2005 Share Posted October 14, 2005 Tonk u can't knock hydraulic stuff mush, .................... don't forget your "Whizzy" steering system B) Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 14, 2005 Share Posted October 14, 2005 i wasn't knockin it, they're just too heavy for my truck Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 14, 2005 Share Posted October 14, 2005 .....and its one of the few "Tonk Proof" parts too B) Hyd U/Js next ? Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 14, 2005 Share Posted October 14, 2005 tonk proof?????????? nothin is Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 14, 2005 Share Posted October 14, 2005 Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 14, 2005 Share Posted October 14, 2005 atleast i drive hard enough to break things Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 14, 2005 Share Posted October 14, 2005 Grammar Tonk, Grammar........ should read "atleast i drive hard enough to break a selection of everythings regularly" Tsk Tsk Nige Quote Link to comment Share on other sites More sharing options...
Tonk Posted October 14, 2005 Share Posted October 14, 2005 atleast everything is easy to get apart, hasn't got time to rust up Quote Link to comment Share on other sites More sharing options...
Bush65 Posted October 14, 2005 Share Posted October 14, 2005 I have a 10500 lb Mile Marker for a rear winch and in the process of modifying a pair of 8274's to hydraulic for front of rangie and bushie. Maxi Drive PTO pump in rangie. Parker CP16-100C-23-S pump for bushie. CP designates clutch pump - it is factory fitted with a 12 volt electo-magnetic clutch with 2 A section vee belt pulley. Theoretical displacement is 0.321 litre/rev and max speed is 3300 rpm (about 100 litre/min). Max pressure with that clutch is 3000 psi (207 bar). Another approach to speeding up Mile Marker winches is to fit a smaller displacement motor and increase the system pressure to achieve the same torque as the larger motor. Quote Link to comment Share on other sites More sharing options...
landi41 Posted October 14, 2005 Share Posted October 14, 2005 Can't add anything about hydrorubbish but i can recommend a good novel if you plan to use a Milemarker :) Quote Link to comment Share on other sites More sharing options...
white90 Posted October 14, 2005 Author Share Posted October 14, 2005 Mark 8274 stuff always welcome. I'm waiting on some stuff from a few people: double motor/double gearbox Will warnes pics of oil filler/drains. any hydraulic info greatly recieved also. Quote Link to comment Share on other sites More sharing options...
John_T Posted October 14, 2005 Share Posted October 14, 2005 Landi41 is quite right. You do need a good long book to read if you, like me, have a Milemarker. I get really bored waiting at the top for the "electric" guys who failed half way up the climb. Quote Link to comment Share on other sites More sharing options...
cols110 Posted October 14, 2005 Share Posted October 14, 2005 Cols110..............,A husky looks positively "super rapid" in comparison ! Nige Hmmmm, that is slow then. Quote Link to comment Share on other sites More sharing options...
landi41 Posted October 14, 2005 Share Posted October 14, 2005 Landi41 is quite right. You do need a good long book to read if you, like me, have a Milemarker. I get really bored waiting at the top for the "electric" guys who failed half way up the climb. John; You are so perceptive....Thats exactly what i meant :) ya sure !! Quote Link to comment Share on other sites More sharing options...
Lara Posted October 17, 2005 Share Posted October 17, 2005 I just read the Tech section on Hydraulic winches, S--t boys wait for me Nothing left to write, I am totally impressed with both of your very informative write-ups, I will try to add my bit but only so people can look at different setups as their is certainly not much I can add to you two Lara. Quote Link to comment Share on other sites More sharing options...
McS Posted October 17, 2005 Share Posted October 17, 2005 How about this one Tony? 70 Ton single line pull and should be fairly indestructible (well, it does have to recover Challenger II's all day long!!) McS Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted October 17, 2005 Share Posted October 17, 2005 wos the fan cover, window blind, type thing for?! Quote Link to comment Share on other sites More sharing options...
McS Posted October 17, 2005 Share Posted October 17, 2005 wos the fan cover, window blind, type thing for?! sounds like the start of a guess the object competition to me...! So, come on, answers on a postcard, I'll post the solution on Wednesday. McS Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 17, 2005 Share Posted October 17, 2005 I think it is an air vent So when foreigners start shooting at the driver and he s**ts himself you can open the vent to let the smell out Quote Link to comment Share on other sites More sharing options...
minivin Posted October 18, 2005 Share Posted October 18, 2005 sounds like the start of a guess the object competition to me...! So, come on, answers on a postcard, I'll post the solution on Wednesday.McS it was devized during the gulf war as the yanks had a tendency to shot anything that moved, the previous Gulf War 1 had them putting painted black arrows on vehicles or white cloth crosses on the tanks but that made for perfect targets. For GW2 some cunning chap come up with these devizes which were stuck on the sides of the vehicles, which IIRC when viewed through InfraRed Goggles looked really bright, which during night opps would hopefully stop the tank-buster A10 et cetera busting open British tanks again Quote Link to comment Share on other sites More sharing options...
white90 Posted October 18, 2005 Author Share Posted October 18, 2005 Rogue Trooper has sold him a Mud Damper Quote Link to comment Share on other sites More sharing options...
McS Posted October 19, 2005 Share Posted October 19, 2005 it was devized during the gulf war as the yanks had a tendency to shot anything that moved, the previous Gulf War 1 had them putting painted black arrows on vehicles or white cloth crosses on the tanks but that made for perfect targets.For GW2 some cunning chap come up with these devizes which were stuck on the sides of the vehicles, which IIRC when viewed through InfraRed Goggles looked really bright, which during night opps would hopefully stop the tank-buster A10 et cetera busting open British tanks again Spotter! exactly right though, worked to good effect too... McS Quote Link to comment Share on other sites More sharing options...
minivin Posted October 19, 2005 Share Posted October 19, 2005 Spotter! exactly right though, worked to good effect too... McS he he, who the daddy Quote Link to comment Share on other sites More sharing options...
