white90 Posted October 12, 2005 Share Posted October 12, 2005 For the tech archive: pics installs writeups please can you post the info on here, I can then cut and paste itinto the tech section TIA Tony Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 13, 2005 Share Posted October 13, 2005 I will try and dig out the stuff and photos I did of the original MM install on my old 90 - it's only a std unit but the instructions from Alfred Murray are non-existent so it is probably worth adding thought you had seen the light when I first saw the post title Quote Link to comment Share on other sites More sharing options...
white90 Posted October 13, 2005 Author Share Posted October 13, 2005 I tried to word it carefully to be sure people didn't think I had hit my head. I've found a fair bit of info already the more the better Quote Link to comment Share on other sites More sharing options...
Outrage Posted October 13, 2005 Share Posted October 13, 2005 I tried to word it carefully to be sure people didn't think I had hit my head. I've found a fiar bit of info already the more the better Ive got some details of someones double pump setup, if i can find the writeup and pictures i'l email the author and see if he would mind me posting it for all to see. Quote Link to comment Share on other sites More sharing options...
white90 Posted October 13, 2005 Author Share Posted October 13, 2005 that will be great thanks Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted October 13, 2005 Share Posted October 13, 2005 IIRC Lara has a 'belt and braces' PTO pump and ZF74 pump on his truck. Dollythelw also had two MMs on Pig. I can supply photos of my MM/ZF74 setup but I doubt it'll be substantially different to SCLs. Quote Link to comment Share on other sites More sharing options...
Lara Posted October 13, 2005 Share Posted October 13, 2005 I will also try to add something, I am in the process of modifying my MM to run on not only its big PTO pump but have fitted back the auxiliary power steering type engine driven pump to cut in when my wheels stop turning or turn V slow when drive assisting, also fitting similar system to a friends truck in front and rear. Will try to do this weekend. Lara. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 13, 2005 Share Posted October 13, 2005 Tony, I'll dig up my posts from LRE and repost with the ophotos, this will take a while ! Posts would be Fitting a Hydraulic winch, pros cons and options. what to be aware of how it works, and what to consider Fitting a hybrid H14W Superwinch system to the "Thing" on the front Converting a MM to PTO drive, using 2 winches from 1 control box etc Making a rear MM installation Converting winches to Air Operated Clutch for freespool. If your ok and wnany all of these fine, if not save me some time as say which ones you don't wnat ! Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 13, 2005 Share Posted October 13, 2005 Just in case my truck is ever finished this would be really handy does anyone's post include basic hydraulics "101" 'cos if not can I request it Quote Link to comment Share on other sites More sharing options...
Lara Posted October 13, 2005 Share Posted October 13, 2005 HFH is the king of Hydraulic I am sure he will give us all something to think about Lara. Quote Link to comment Share on other sites More sharing options...
dollythelw Posted October 13, 2005 Share Posted October 13, 2005 I'll do a circuit diagram for a double winch setup, Ive also got a few pics. Cheers Quote Link to comment Share on other sites More sharing options...
cols110 Posted October 13, 2005 Share Posted October 13, 2005 Excellent, this should all make a great read once complete. Is Tony having second thoughts, I think not. Quote Link to comment Share on other sites More sharing options...
white90 Posted October 13, 2005 Author Share Posted October 13, 2005 TC Nige Jez Julian all your write up will be excellent please that way it will be a superb article on fitting the hydraulic winches. ps Julian I hope you are ok with me using a couple of your pictures already. Quote Link to comment Share on other sites More sharing options...
minivin Posted October 13, 2005 Share Posted October 13, 2005 Can't wait, have hydraulic intentions of my own Quote Link to comment Share on other sites More sharing options...
Hillbilly Raider Posted October 13, 2005 Share Posted October 13, 2005 Can't wait, have hydraulic intentions of my own so you ARE going to get it muddy then Rob? or will it be for decoration like mine?!! P.S. Tonk made me post this! Quote Link to comment Share on other sites More sharing options...
Lara Posted October 13, 2005 Share Posted October 13, 2005 TCNige Jez Julian all your write up will be excellent please that way it will be a superb article on fitting the hydraulic winches. ps Julian I hope you are ok with me using a couple of your pictures already. You are welcome to use any pictures you wish. Regards, Julian. Quote Link to comment Share on other sites More sharing options...
minivin Posted October 13, 2005 Share Posted October 13, 2005 so you ARE going to get it muddy then Rob? or will it be for decoration like mine?!! P.S. Tonk made me post this! well, it's going to be a year before I get the chance to fit a winch, so in that time I should be happy enough to start getting it stuck and minimise the damage to my wallet Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 13, 2005 Share Posted October 13, 2005 1st one done, will dig out and post tommorow maybe the "How to fit a MM to the rear and have PTO powered" "How to fit an Air Clutch" for MM freespool.... Moved the 1st post rather smartish TC ! Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted October 13, 2005 Author Share Posted October 13, 2005 I seem to have lost a pic in the transfer the one with the sunk 90 can you let me have it Nige Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 13, 2005 Share Posted October 13, 2005 Hmmmmmmmmm Odd Have sent to you on e-mail as my host seem to have closed for technical servicing ! Nige Quote Link to comment Share on other sites More sharing options...
cols110 Posted October 13, 2005 Share Posted October 13, 2005 Nige, nice write up mate, very interesting, Looking at the kits on AMs site, it all looks pretty straight forward, but after seeing your set up there certainly is more to it than meets the eye, especially when you go for a PTO pump. When you say the ZF pump is still very slow, how slow is that compared to a Husky. Quote Link to comment Share on other sites More sharing options...
white90 Posted October 13, 2005 Author Share Posted October 13, 2005 Hmmmmmmmmm OddHave sent to you on e-mail as my host seem to have closed for technical servicing ! Nige I'll wait till tomorrow then add it if that's ok Quote Link to comment Share on other sites More sharing options...
ibexman Posted October 13, 2005 Share Posted October 13, 2005 For the tech archive:pics installs writeups please can you post the info on here, I can then cut and paste itinto the tech section TIA Tony Theres some good stuff and pics on irish 4wheel drive site Tony Quote Link to comment Share on other sites More sharing options...
white90 Posted October 13, 2005 Author Share Posted October 13, 2005 Theres some good stuff and pics on irish 4wheel drive site Tony I was trying to find Merv site yesterday without joy Quote Link to comment Share on other sites More sharing options...
ibexman Posted October 13, 2005 Share Posted October 13, 2005 I was trying to find Merv site yesterday without joy Ilogged on ok try ifwdc cheers chris Quote Link to comment Share on other sites More sharing options...
