Astro_Al Posted October 24, 2005 Share Posted October 24, 2005 Hi, I now have second hand Defender gauges, courtesy of 'Monsieur Frigidaire-congélateur' and his recent escapades at Sodbury (merci!), but I need to know how I can reset the mileage back to zero. Is it set up so that you can't tamper with it, or is there a known method??? Cheers, Al. Quote Link to comment Share on other sites More sharing options...
jules Posted October 24, 2005 Share Posted October 24, 2005 I know a few places in southampton that can do it but I will not say names on the forum and I have never personaly spokent to them about it. It is easy on a P38 so I'm told I don't know about Def ones why have burned out your drill Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted October 24, 2005 Author Share Posted October 24, 2005 Hmm, thanks Jules. Hold that thought... I have a drill which I got free and don't mind knackering - just wondered if there was an easier way. Knowing me I'd leave it running, go away to do something else, and return to a smoking drill just as it reached the number it started on. I guess they can't be run backwards, so I'd have to go right the way round. There must be a way in - I'll have a fiddle when I get my hands on it. Al. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 24, 2005 Share Posted October 24, 2005 Is it a Td5 electronic one you have? what milage is showing on it? reason i ask, is i have a brand new Td5 one here (bought at billing this year in a Td5 dash!) which i'm going to fit into my 300Tdi, which has 34000KM on it (i have a KPH mechanical speedo fitted at present), so i need to "fast forward" my new speedo head. if you'rs is a) electronic, B) MPH c) near (or under) 21000miles, then drop me a PM! cheers Jamie PS... fitting the electronic spedo head into an older 90/110 is a doddle too! Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted October 24, 2005 Author Share Posted October 24, 2005 I dunno (but I doubt it), my personal shopper picked it up for me - lets ask him: Oi, Fridge! What's the answer? Al. Quote Link to comment Share on other sites More sharing options...
western Posted October 24, 2005 Share Posted October 24, 2005 If it's a older click over numbers type, then it is possible to very carefully prise the retainer ring off and undo the 2 screws on the back to get in to reset/move the numbers, I did mine to set the 1st digit correctly as it wasn't moving, hasn't had a ill effects cos it's still working OK. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 24, 2005 Share Posted October 24, 2005 you forgot to add "so I am told" at the end Western ! and yes, thats the way to do it, use a watchmakers screwdriver to release the clips. so I am told B) Nige Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 24, 2005 Share Posted October 24, 2005 you forgot to add "so I am told" at the end Western ! and yes, thats the way to do it, use a watchmakers screwdriver to release the clips. so I am told B) Nige Nah...i used a big flat blade on my old one! Quote Link to comment Share on other sites More sharing options...
western Posted October 24, 2005 Share Posted October 24, 2005 Didn't forget anything Nige, that's how I adjusted my own speedo to correct it's total mileage reading Quote Link to comment Share on other sites More sharing options...
BogMonster Posted October 24, 2005 Share Posted October 24, 2005 Presumably with an electronically driven one if you connected it to a frequency generator your kid nicked from the school electronics lab you could crank the freq output up till it read 135mph and leave it there for a week or two until it got right the way round and back to the figure you wanted? Quote Link to comment Share on other sites More sharing options...
Steve King Posted October 24, 2005 Share Posted October 24, 2005 If it's a older click over numbers type, then it is possible to very carefully prise the retainer ring off and undo the 2 screws on the back to get in to reset/move the numbers, I did mine to set the 1st digit correctly as it wasn't moving, hasn't had a ill effects cos it's still working OK. You forgot Remove note reading "Oh No! Not Again!" and disgard. Quote Link to comment Share on other sites More sharing options...
jules Posted October 24, 2005 Share Posted October 24, 2005 You forgot Remove note reading "Oh No! Not Again!" and disgard. Quote Link to comment Share on other sites More sharing options...
reads90 Posted October 24, 2005 Share Posted October 24, 2005 You forgot Remove note reading "Oh No! Not Again!" and disgard. don't laugh have seen that before. A mate wanted to do that with his car and took the speedo out and found that writen on the back. But there again it was an allegro Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 24, 2005 Share Posted October 24, 2005 Superb.... Nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted October 24, 2005 Share Posted October 24, 2005 No it's not electric - it's a stock defender one. Surely there's no rocket science behind it - and for the fiver you/I paid for it it's got to be worth a prod even if it breaks and ends up in the tech archive as "how not to clock your defender" Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted October 25, 2005 Author Share Posted October 25, 2005 Too right Fridge. I'll have a go at the weekend. Thanks for the method folks. Al. Quote Link to comment Share on other sites More sharing options...
PeterW Posted October 25, 2005 Share Posted October 25, 2005 Too right Fridge. I'll have a go at the weekend. Thanks for the method folks. Al. Don't forget, its not actually illegal to clock a speedo... Let me explain.... An odometer records mileage. Thats it. Its a grey area whether its legal requirement to have one, only a speedo is required. There is not an offence of changing the mileage shown in any of the Road Traffic Acts or Construction and Use regs, HOWEVER.... It is an offence to obtain a pecunary advantage by deception - in other words clocking a vehicle in order to either sell it with less miles on, or claim under a warranty or limited mileage insurance etc. Thats why most second hand cars in main dealers have stickers over the odometer showing that the mileage has not been confirmed. If you remove and keep the old speedo head and reset the current one to zero, when you come to sell the vehicle the two added together **should** show the correct recorded mileage for the vehicle... HTH Cheers Peter Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted October 25, 2005 Author Share Posted October 25, 2005 Yeah, just for the record, it's kind of a full rebuild - replacement chassis, engine etc, so there isn't really a mileage to keep that's relevant to anything. I don't really think I'm trying to gain or avoid costs by setting the mileage to zero at this point. Cheers, Al. Quote Link to comment Share on other sites More sharing options...
clunk Posted October 25, 2005 Share Posted October 25, 2005 I've never taken a LR clock apart before but if its similar to most then it should unscrew to get to the internals. It should then be possibe to manually rotate the rollers individually until you have 9 showing on all of them. then one more rotation will effectively bring it 'around the clock' and back to zero. all the rollers are connected by a small tag - WARNING! DONT TAKE THEM APART AND DONT ASK HOW I KNOW THAT!!!- so if you start at the tenths of a mile roller and then work over to the left it should work. easier than the drill method! And if the thought police are around, er, um I, ah, read that in a book somewhere clunk Quote Link to comment Share on other sites More sharing options...
