Axles on Ebay. Quite possibly just a bit OTT
Matt Lee's comp racer is hydraulic drive, it's very fast.
Thats all i know.
Look forward to seeing them axles on the Disco :D
Jim
Ps: If you did go full hydrualic drive then you could have a proper winch :ph34r:
Pss: Cogs are now ticking :rolleyes:
Thats all i know.
Jim
You sure? <_<
A while back I considered building something out of a hydrostatic drive crop sprayer - since it has everything built in that you need. Ones with broken/missing booms don't tend to go for much more money than this and often they run HUGE diameter wheels that make Bathtub's loo like a dinky toy!
I fancy the idea of building the cab inside the wheel diameter such that you could run inverted (uncomfortably) but more to use the wheels as your cage. With spoked wheels - you would be able to see out the sides too. Just run tank steer with a big pivot between the front & rear halves to allow articulation.
Fag packet sketch.....
Perhaps I'd better finish my Suzuki first!
Si
