Rear Axle Lockers
leeds
Have an ARB rear axle locker fitted to my 110 overland vehicle which runs on standard half shafts and HD drive flanges.
Last year did 25,000 miles in total in Australia with about 20,000 miles done off bitumen. The rear axle locker was engaged say a dozen times at low speed when I thought it would be useful to have continuing drive to both rear wheels. On inspecting the half shafts they are both twisted. Could engaging the rear axle locker whilst on the move actually be the cause of the half shafts being twisted? Or is the twist just the result of general driving in the Australian outback?
The heavy duty drive flanges on the rear wheels shows some wear as the standard drive flanges on the front wheel.
Regards
Brendan
Sounds normal to me, think about how the corrugations will effect the half shafts as the wheels are constantly loaded and unloaded never mind the off road use :)
I inspected my front shafts, CVs and diff a couple of weekends ago for the first time since fitting them before the OBC, not a mark on any of them, no twisting, no "chatter" marks, nothing. Mr Ashcroft does make exceedingly good axle bits !
Switching the locker in/out on the move is In my opinion the reason for the twisting
count yourself lucky and Upgrade time :)
I have today pulled the MD ones out of my front axle and after 5 or 6 years they are still A1 condition.
If I were to replace I'd get Ashcrofts for ease of supply/quality.
they weren't around when I purchased.
Thanks for the replies folks.
I decided NOT to fit Ashcroft type shafts to my 110 as I felt it would be easier to replace a broken half shaft in the middle of nowhere then to try and find a replacement diff. Weakest link idea. Spare half shafts were carried.
Is it time to reconsider that idea? Remember the 110 is an overland vehicle and not a competition truck
Regards
Brendan
Brendan
the Diff is strong already, Ashcroft shafts/Drive members you'll have one of the strongest L/R set ups available.
I would prefer to have the weakest link at the propshaft, for ease of replacement and to avoid additional damage.
I'm not sure that engaging the locker while moving is such a good idea, probably better to be at a slow crawl/ walking pace when you switch it in/out.
I agree with the others about upgrading your halfshafts, but might be worth talking to Ashcrofts about your concerns, as I'm sure they'll give you some honest advice.
I can't see that engaging the ARB when you're moving is a problem, particularly if you're going in a straight line. The diff will already be running both half shafts at the same speed anyway so it doesn't matter to the diff what speed you are doing.
Engaging them whilst spinning one wheel I can see as a problem but not while driving dead straight.
A while back, I had an idea (a torque overload warning) involving using the elastic twist in a half shaft to measure the torque applied to a wheel - but someone said the plastic deformation of halfshafts was significant - so it may be difficult to rely on the deformation being elastic and proportional to the torque.
I fitted a new long shaft to my 90 with a line painted along the length. Drove it on the road for a year then inspected the shaft. I can't remember how much it had twisted - but it was significant (60 degrees?) along it's length.
I would be inclined to think that your twist is just part of the normal life of a shaft?
Si
Wow that's brave... :blink:
You'd rather have a broken propshaft flailing around the underside of the floor than a broken halfshaft contained safely in the axle...
Hmm .. each to his (or her) own! :P
Tony
I'm with the others on this one.. the LAST thing i'd want is a broken propshaft trashing the underside of my car... give me a broken halfshaft/ CV joint any day...
