Michele Posted March 6, 2006 Share Posted March 6, 2006 I got some new toys last week... First hint... Hint #2 (bling enough?) This is easy enough if you're eagle eyed... Link to comment Share on other sites More sharing options...
SteveG Posted March 6, 2006 Share Posted March 6, 2006 weird looking dumbell??? I assume you have a pair or it could be a shiny CV/paperweight Steve Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted March 6, 2006 Share Posted March 6, 2006 I just counted the rings.... about 31..... does that mean it's 31 years old? or 31 times stronger? Link to comment Share on other sites More sharing options...
Michele Posted March 6, 2006 Author Share Posted March 6, 2006 I'll tell you: 30 and 500 P.S. 500 as my posts P.S. Sure I have a pair Link to comment Share on other sites More sharing options...
Michele Posted March 6, 2006 Author Share Posted March 6, 2006 Hint #3 and enough for now Link to comment Share on other sites More sharing options...
simonr Posted March 6, 2006 Share Posted March 6, 2006 OK, the shaft is 30 spline - so, my guess is either that yo are running a Toyota diff, front shafts and CV's into custom drive flanges, or you've had new front inner shafts made to use with toyota CV's with standard diffs and custom flanges? Close? Either way - good idea! Si Link to comment Share on other sites More sharing options...
Michele Posted March 6, 2006 Author Share Posted March 6, 2006 Hi Si, the 2nd you said All in the name of the scientific research of course,believe me! Link to comment Share on other sites More sharing options...
minivin Posted March 6, 2006 Share Posted March 6, 2006 I got some new toys last week... First hint... Hint #2 This is easy enough if you're eagle eyed... A series II or a LWT by the looks of the grill Link to comment Share on other sites More sharing options...
will_warne Posted March 6, 2006 Share Posted March 6, 2006 OK, the shaft is 30 spline - so, my guess is either that yo are running a Toyota diff, front shafts and CV's into custom drive flanges, or you've had new front inner shafts made to use with toyota CV's with standard diffs and custom flanges?Close? Either way - good idea! Si OK, my turn now: Toyota 30 spline diffs, Longfield 30 spline shafts and their latest CVs (sorry, the falts sides are a give away) plus drive flanges. Link to comment Share on other sites More sharing options...
Michele Posted March 6, 2006 Author Share Posted March 6, 2006 A series II or a LWT by the looks of the grill That's not mine OK, my turn now: Toyota 30 spline diffs, Longfield 30 spline shafts and their latest CVs (sorry, the falts sides are a give away) plus drive flanges. Just CVs and custom made axles. I'll keep my ARBs You guys are too clever,made it the shortest game ever Link to comment Share on other sites More sharing options...
will_warne Posted March 6, 2006 Share Posted March 6, 2006 Just CVs and custom made axles.I'll keep my ARBs You guys are too clever,made it the shortest game ever No, its probably that I should get out more! Link to comment Share on other sites More sharing options...
Michele Posted March 6, 2006 Author Share Posted March 6, 2006 No, its probably that I should get out more! Me too... Link to comment Share on other sites More sharing options...
LR90 Posted March 6, 2006 Share Posted March 6, 2006 Your Cube is really taking shape. Post up some pics when you do the CV swap. Anyone care to guess how this compares with the stregthened CVs Ashcroft now supply (which would run with stock shafts)? Link to comment Share on other sites More sharing options...
will_warne Posted March 6, 2006 Share Posted March 6, 2006 Your Cube is really taking shape. Post up some pics when you do the CV swap.Anyone care to guess how this compares with the stregthened CVs Ashcroft now supply (which would run with stock shafts)? Both are VERY strong, you get to the point where the inner shaft is going to be the weak link of the axle. Ashcroft get my money, though, as I'm only an hour or so from them and there's no machining or conversion parts are needed. Link to comment Share on other sites More sharing options...
Michele Posted March 7, 2006 Author Share Posted March 7, 2006 Surely not.... Toyota parts in the best 4X4 BY FAR........... You just need one of their engines with VVTi and your' smokin........(or at least your tyres will be..... Nah mate no way. The only 'yota thing is the pattern,they're not even made in Japan,get the point? and the bushing will serve as reference for in-house machining (or whatever it's called). As to strenght...the scientific way would be to put them to the test using one of those custom made machines... This should give accurate numbers to make engineers and scientists happy for a while For the Longs it has been done already,I will link the graph... As to the average user (me) I'm happy enough to know they're up to far bigger tyres I will ever be allowed to run...accordingly to reports and threads they're stronger than R&P. The Cube is not going to be a Yankee rockcrawler so I don't really bother,I just liked the idea and it's a good chance to tinker on my own truck...which I like more and more as it gets (the tinkering...and the truck obviously!) And learn something in the process! I have a spare pair of 110 type (oil bathered) sviwels I'm cleaning in the workshop,I will take pics of the various steps and hopefully be able to start soon...I'm contemplating the idea to modify the chrome balls to correct castor while I'm there and this could slow things down a bit. Ben (isuzurover) is kindly guiding me so not to forget anything and keep things clear (I'm a bit sometimes). Link to comment Share on other sites More sharing options...
Michele Posted March 7, 2006 Author Share Posted March 7, 2006 Originally Posted by camo ................................................ft lbs * degree * inner axle used * failure stock toy birf..............................3700 .....30........long 4340.......birf exploded randys birf elimn kit......................5000.....40........randys ...........ujoint broke long treated oem birf....................5100 .....45.......long 4340.......stub broke newfield 4340 birf........................7000......80.......300 m.............inner axle broke longfield 4340 birf........................7000......80.......300 m.............inner axle broke longfield 30 spline birf...................8900.....120......4340..... .........inner axle broke stock toy 27 spline inner axle..........4000....20.......................... ..axle broke stock dana 44 30 spline inner..........5200....25......................... ...ears broke pig toy 27 spline 4340 inner............5500....90....................... .....axle broke yukon dana 44 30 spline 4340 inner..5800....48............................yoke broke longfield toy 27 spline 4340 inner.....6500....80............................ax le broke stock dana 60 35 spline stub..........8300......80 ..........................ears broke yukon dana 60 35 spline 4340 stub..12000....90..........................shaft broke Referring to the Gen I Longs. Link to comment Share on other sites More sharing options...
dirtydiesel Posted March 7, 2006 Share Posted March 7, 2006 Well done michele looks like your in the lead. Me and rog (898 kor) bought one of those the other day to look at the vaiability of making them fit. Link to comment Share on other sites More sharing options...
isuzurover Posted March 7, 2006 Share Posted March 7, 2006 Looking good Michele. I am now wishing I had waited a year to buy mine, but the overall strength should be the same, just yours should last longer with the bigger balls. Especially since you are using yours in a DD application. Link to comment Share on other sites More sharing options...
Michele Posted March 7, 2006 Author Share Posted March 7, 2006 Mine or yours? Big balls DD,yup,it's gonna be a good test Link to comment Share on other sites More sharing options...
Revor Posted March 7, 2006 Share Posted March 7, 2006 Nice goodies.... The shafts and CV's look nice in Europe!!! B) Keith Link to comment Share on other sites More sharing options...
Michele Posted March 7, 2006 Author Share Posted March 7, 2006 Welcome uncle Trevor! Link to comment Share on other sites More sharing options...
Revor Posted March 7, 2006 Share Posted March 7, 2006 Hey All the cool kids are doing it!! You know how it is... You see a new board and there is something new to see.. Some of the other boards are getting tiresome.. I thought about "sneaking in to see what you where up to.. but I'm too up front for that... Plus in a forum I can help you out if you like.. K Link to comment Share on other sites More sharing options...
Astro_Al Posted March 7, 2006 Share Posted March 7, 2006 I thought about "sneaking in to see what you where up to.. but I'm too up front for that... Plus in a forum I can help you out if you like..K Woah! Now this IS getting interesting. Al. Link to comment Share on other sites More sharing options...
Revor Posted March 8, 2006 Share Posted March 8, 2006 Woah! Now this IS getting interesting.Al. Wait till Ben starts asking us to measure our balls!! Link to comment Share on other sites More sharing options...
isuzurover Posted March 9, 2006 Share Posted March 9, 2006 Wait till Ben starts asking us to measure our balls!! You mean you haven't done it yet??? I am happy with my early model CVs - since I will be fitting them into series housings. But I have been toying with the idea of fitting some 80 series Longfields instead... Apparently there is enough room, after some mods to the top swivel pin... But I come up with lots of crazy ideas, so I will probably forget about it... Keith, I am interested in the 30 spline 300m salisbury axles you mentioned. Any more info/prices (feel free to email/PM). Link to comment Share on other sites More sharing options...
