OilIT Posted March 25, 2006 Share Posted March 25, 2006 Hi I am looking for an LT230T transfer box for my 200tdi defender. Is there any easy way of visually identifying the ratios etc on the transfer box (i believe the ratios are different for the discovery, and for the earlier LT230R-maybe somebody could correct me if I'm wrong !) Appreciate any help! Cheers OilIT Quote Link to comment Share on other sites More sharing options...
western Posted March 25, 2006 Share Posted March 25, 2006 There may be a sticker on the rear face adjacent to the oil fill/level plug stating which ratio is fitted, if not serial number is/should be stamped in the casing below the circular rear cover. provided the box hasn't come from a 2.0litre Mpi Discvery all the other boxes have the same ratio's Quote Link to comment Share on other sites More sharing options...
simonb Posted March 25, 2006 Share Posted March 25, 2006 Tdi disco, 1.2 ratio, Tdi defender, 1.4 ratio. 2.5 petrol defender 1.6 ratio. Can't remember what 2.5NA, 2.5 TD and V8 were. The info has been on here before, someone must know.. Or get the serial # and give Mr Ashcroft a ring.... Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 25, 2006 Share Posted March 25, 2006 2.5 P Defender 90s are 1.4:1, at least both ours were. 2.5P 110s were 1.6:1 which was better with that engine IMHO. I think some of the V8 90s may have been 1.2:1 too? Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted March 25, 2006 Share Posted March 25, 2006 Get underneath with a rag. Next to handbrake unit (left of) at bottom on the ali casing rub like hell and then post up here the number, I'll look it upo Nige Quote Link to comment Share on other sites More sharing options...
OilIT Posted March 26, 2006 Author Share Posted March 26, 2006 thanks - will do! Quote Link to comment Share on other sites More sharing options...
OilIT Posted March 26, 2006 Author Share Posted March 26, 2006 Thanks everybody -- was underneath - scaped away all the goo - and there is a sticker !!! Brilliant (if only everything was this easy) Quote Link to comment Share on other sites More sharing options...
isbjorn Posted June 22, 2009 Share Posted June 22, 2009 Was searching around and thought I might add a photo of how they look. a bit messy but it might help someone else... http://duckfieldengineering.com/defender/gearbox.htm <- help with identification of gearbox and transfer boxes. Quote Link to comment Share on other sites More sharing options...
Andrew Chua Posted June 23, 2009 Share Posted June 23, 2009 I'm really amazed that the sticker will hold on there so well admist the heat and mud. so the question is, is the sticker avaliable as a part? I think I would like to stick the 1.222 on mine after changing the ratio. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 23, 2009 Share Posted June 23, 2009 Is it not easier to get a complete unit of the right ratio and swap it out? Save you getting the sticker for one thing Quote Link to comment Share on other sites More sharing options...
western Posted June 23, 2009 Share Posted June 23, 2009 just use some number stamp & stamp the ratio into the alloy casing, it can't fall off then Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted June 23, 2009 Share Posted June 23, 2009 To distinguish the two, LT230T have a big stake nut on the intermediate shaft (between the PTO cover and handbrake) while the LT230R don't, the intermediate shaft being retained by a small bit of metal held in with an ~M6 bolt. Quote Link to comment Share on other sites More sharing options...
