Woody3 Posted June 1, 2010 Share Posted June 1, 2010 Hi, While swapping my old 19J for a 200tdi, I have been advised to swap the rear axle for a disc brake version. Been browsing on ebay and have come across a 300 tdi rear axle, which has new discs, calipers and pads. My question is, are 200 tdi axles the same as 300 tdi ones? This one states that it is 24 spline, which makes no sense to me whatsoever Something about being more heavy duty? Ta, p.s. I did a search, but to no avail Quote Link to comment Share on other sites More sharing options...
picpoki Posted June 1, 2010 Share Posted June 1, 2010 Hope you don`t mind for borowing your topic...Can I change axles to discos? Rear discos axle is not salisbury, front is the same. Is rear axle strong enough for fully laden 110? I`m going to Iran in september and I want to be shure the car will make it Oh... I have 2.5 petrol def, axle is from 200tdi disco. I think 200tdi and 300tdi axles are the same... let he experts confirm. Cheers Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 1, 2010 Share Posted June 1, 2010 In terms of fitment they are the same. A 300Tdi Disco or Defender axle will bolt up in place of a 200Tdi Disco or Defender axle. The 24 spline is the spline count on the half-shafts. 24 spline is stronger, which is good. A rear axle off a Discovery or Range Rover Classic (or a 90) is not suitable for a 110, it is not rated for the vehicle's gross weight. The only axles suitable for these vehicles are the Salisbury as fitted to earlier vehicles or the strengthened type as fitted to later ones. Quote Link to comment Share on other sites More sharing options...
Andy Posted June 1, 2010 Share Posted June 1, 2010 I believe 24spline axles all have 4-pin diffs too? I know the 2-pin diff is the weakest thing in a 10spline axle. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 1, 2010 Share Posted June 1, 2010 No, it's a 2 pin diff like the earlier 10 spline. The difference is in the spline count for the half shafts only, the 24 spline half shaft being stronger by virtue of increased contact area and an increase in minimum diameter of the half shaft due to smaller, more numerous splines. HTH Mo Quote Link to comment Share on other sites More sharing options...
bishbosh Posted June 1, 2010 Share Posted June 1, 2010 If the axle is from a Discovery then you will also need to change the diff flange for a four bolt one. Easy enough to do though. Quote Link to comment Share on other sites More sharing options...
Andy Posted June 1, 2010 Share Posted June 1, 2010 No, it's a 2 pin diff like the earlier 10 spline. The difference is in the spline count for the half shafts only, the 24 spline half shaft being stronger by virtue of increased contact area and an increase in minimum diameter of the half shaft due to smaller, more numerous splines. HTH Mo Ahh ok, I was under the impression all 24spline diffs were also 4-pin. My mistake. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted June 1, 2010 Share Posted June 1, 2010 No problem Andy However the latest 110 rear axles of the P38 type are 4 pin. Just to confuse Mo Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted June 2, 2010 Share Posted June 2, 2010 .....and all V8 90 Rear diffs are 24 spline oh...and 4 pin too (just to help confuse some more ) Nige Quote Link to comment Share on other sites More sharing options...
scube Posted June 2, 2010 Share Posted June 2, 2010 Bishbosh is right however only if the Discovery or some of the later Range Rovers have the rubber doughnut instead of the normal UJ. All the rest of the diff’s will bolt on no problem. Quote Link to comment Share on other sites More sharing options...
Woody3 Posted June 2, 2010 Author Share Posted June 2, 2010 Ok...I've put an Offer in anyway, just gotta wait to see if it gets accepted or not. Thanks again for your help everyone...even though you have slightly confused me even more haha Cheers, Quote Link to comment Share on other sites More sharing options...
Andy Posted June 2, 2010 Share Posted June 2, 2010 .....and all V8 90 Rear diffs are 24 spline oh...and 4 pin too (just to help confuse some more ) Nige I knew this & thought it was normal. My only excuse is I haven't had a landy for over 3 years & just back on here looking as I fancy another by winter time. Quote Link to comment Share on other sites More sharing options...
picpoki Posted June 3, 2010 Share Posted June 3, 2010 A rear axle off a Discovery or Range Rover Classic (or a 90) is not suitable for a 110, it is not rated for the vehicle's gross weight. The only axles suitable for these vehicles are the Salisbury as fitted to earlier vehicles or the strengthened type as fitted to later ones. So the problem is in the housing of the axle? The half-shafts are the same? Diferential is strong enough? Thanks for explanation Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 3, 2010 Share Posted June 3, 2010 Diff and half-shafts are different, and stronger. The casing is also beefier and therefore stronger. The real issue is the legality. The vehicle is plated for a certain weight and the standard Rover axle isn't rated for the same weight. Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted June 3, 2010 Share Posted June 3, 2010 Diff and half-shafts are different, and stronger. The casing is also beefier and therefore stronger. The real issue is the legality. The vehicle is plated for a certain weight and the standard Rover axle isn't rated for the same weight. Sorry but the halfshafts are no different. all new Defenders now have the same part number for their rear halfshafts. they all leave the factory with seperate halfshaft and drive flange. gone are the days of the 'mushroom end' The casing on the post 2004MY 110's is exactly the same as a disco /90" casing, bar a different bolt pattern for the diff and a 15mm (ish) ring (which does jack for stopping an axle bending) welded on where the diff pan sits. It has a 'P38' 4 pin diff which is stronger than a 2 pin obviously. other wise its the same axle tube. The Salisbury axle has unrivalled strength in its diff but any axle casing that has to be spread open to get the diff in and out cannot be stronger than a banjo style axle tube. Steve Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted June 3, 2010 Share Posted June 3, 2010 Salisbury axle casing Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted June 3, 2010 Share Posted June 3, 2010 Fair enough, I stand corrected. If the casing is no stronger then it begs the question why they're rated for more weight? :| Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted June 3, 2010 Share Posted June 3, 2010 I Don't know the answer to that, but it's probably down to the fact that a 2 pin diff is not able to last long shoving a bus around where as a 4 pin which also has much beefier bearing retainers can cope very well. I think Land Rover moved to salisbury axle in the early days on the long wheel base due to differential failures not bent axles. Steve Quote Link to comment Share on other sites More sharing options...
Prith Posted June 3, 2010 Share Posted June 3, 2010 Sorry to hijack this thread. I have a def 110 which was originally a 2.5NAD & I have recently replaced it with a Def 200tdi engine. MyI have a salisbury axle with drums only. Don't know how many splines its it. Can I upgrade to a 200tdi/300Tdi axle? Do I need to change the rear propshaft? Wish there was a bolt on disc brake kit for the salisbury axle! Quote Link to comment Share on other sites More sharing options...
Megansfolly Posted June 3, 2010 Share Posted June 3, 2010 .....and all V8 90 Rear diffs are 24 spline oh...and 4 pin too (just to help confuse some more ) Nige same as the ex mil nads but they have drums on them Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted June 3, 2010 Share Posted June 3, 2010 Don't forget also that the weight rating is also down to the size of the coil springs on a 110" - they are 'kin huge compared to disco / 90" Quote Link to comment Share on other sites More sharing options...
picpoki Posted June 4, 2010 Share Posted June 4, 2010 Oh.. That could be a problem... I`ll just have to rebuild the salisbury and change the front one to discos. Quote Link to comment Share on other sites More sharing options...
rick Posted June 5, 2010 Share Posted June 5, 2010 [snip] The Salisbury axle has unrivalled strength in its diff but any axle casing that has to be spread open to get the diff in and out cannot be stronger than a banjo style axle tube. Steve I'd be donning a flame proof suit too I'd take a Sals over any Rover diff ever used/fitted to a Defender. The heavily braced/trussed Rover rear ends have been used to replace Sals assemblies that pulled axle tubes from the centres in certain (overloaded usually) applications, but then a trussed and braced Sals would be stronger again. A number of owners have replaced P38 style Rover rrear ends in late model Defenders here with Sals diffs, they were sick and tired of the constant rebuilds. It's shame GKN and Rover down specced the D60 when they built it under license from Dana, oh, except for the centre where they at least use four sun gears rather than the standard US two pin diff. and FWIW, 130 Sals axle tubes are beefier (thicker walled) than 110's. ie. they are the same OD, smaller ID in the tube. 130 tube = approx 8+mm wall 110 tube = approx 6mm wall You knew someone would eventually bite, didn't you Quote Link to comment Share on other sites More sharing options...
Off Road Toad Posted June 5, 2010 Share Posted June 5, 2010 I'd be donning a flame proof suit too I'd take a Sals over any Rover diff ever used/fitted to a Defender. The heavily braced/trussed Rover rear ends have been used to replace Sals assemblies that pulled axle tubes from the centres in certain (overloaded usually) applications, but then a trussed and braced Sals would be stronger again. A number of owners have replaced P38 style Rover rrear ends in late model Defenders here with Sals diffs, they were sick and tired of the constant rebuilds. It's shame GKN and Rover down specced the D60 when they built it under license from Dana, oh, except for the centre where they at least use four sun gears rather than the standard US two pin diff. and FWIW, 130 Sals axle tubes are beefier (thicker walled) than 110's. ie. they are the same OD, smaller ID in the tube. 130 tube = approx 8+mm wall 110 tube = approx 6mm wall You knew someone would eventually bite, didn't you I'm sorry but i disagree with you . We don't often see issues with the rover style 110" axle they are at least easily repairable on a DIY basis and bracing and trussing a salisbury axle would be fairly foolish if you ever wanted to be able to service your diff unit owing to the nature of needing to spread your axle casing. I respect other peoples opinions but i don't like the 'i'm gonna shoot you down in flames' attitude that a lot of people seem to have . What is right and works for one person may not be right for another. Don'y worry - i've got plenty of fire extingushers Quote Link to comment Share on other sites More sharing options...
rick Posted June 7, 2010 Share Posted June 7, 2010 I'm sorry but i disagree with you . We don't often see issues with the rover style 110" axle they are at least easily repairable on a DIY basis and bracing and trussing a salisbury axle would be fairly foolish if you ever wanted to be able to service your diff unit owing to the nature of needing to spread your axle casing. I respect other peoples opinions but i don't like the 'i'm gonna shoot you down in flames' attitude that a lot of people seem to have . What is right and works for one person may not be right for another. Don'y worry - i've got plenty of fire extingushers That's OK, as I disagree with you There have been numerous problems with the P38 style Rover diff in the rear of 110 and 130's here in Oz, they really don't seem to be able to take any punishment. A number of owners have retrofitted the Sals. As for need to spread the case, you can mostly pry the centre out with some tyre irons, it doesn't use much pre-load or take much to pop out. (and the same goes for the D60, which is beefier in the tubes, they really are heavy) Quote Link to comment Share on other sites More sharing options...
