Orange Springs
In my experience"rock hard"! Much stiffer than original equipment.
In defence of the orange supplier (sorry) they are a sensible option if you want bling on the high street, less body roll.
Plenty of proper off road kit out there......
we are talking scrapiron springs right?
my +2 springs are great- like marshmallow- as much flex as you like- there's not a chance that they are +2 anymore but they flex like buggery!
try breaking them in a bit- i reckon the sag they get after time is a good thing!
They've been on my hybrid for about 7 months now, and were on the donor rangy for about a year before i had it
The ride hight is perfect for the back, just need more give
Fronts need to go up by no more than an inch, but need to give a lot more than now
Get your front and rear axle weights measured at a weigh bridge an then it should be possible to calculate which springs will give you the desired ride height and some more flex too.
I suspect red/whites will give you too much lift if you want to keep the ride height you have now.
Good idea, only problem, where do i find a weigh bridge around here :unsure::unsure:
Mine are very good. Whatever else can be said about Scrairon and their products, the springs on my Landrover are ace. They may be a little stiffer than stock and do not allow it to wallow all over the road when cornering but they a still plenty soft enough to give a good ride off road and they will allow the rear tyres to touch the insides of the wheel arches so I guess they are soft enough too. When I bought them, several years ago, I was asked on the telephone what car they were for and what kind of load I usually carry. I have been pleased with them since day one - and after all the tales of defective springs they have been subject to some scrutiny too! I have no complaints.
Chris
I agree with you there, they do give a nice ride, minimal body roll, and feel good in the corners
But i'm not happy with the flex so they've got to go :angry:
Hoping to get more flex with a softer spring, and then try and restore road manners with some anti roll bars (disconnectable obviously :rolleyes: )
Erm................
new - ie fitted and not used, not even off the driveway :
NSF 4000 lbs
OSF 2700 lbs
NSR 128.88 lbs
OSR 10693 lbs
Slight Use - shortly after say a trip to tescos (incs say 1 Speed Bump)
NSF 40.2 lbs
OSF 220 lbs
NSR 228.88 lbs
OSR 63 lbs
Heavy use - say mounting a kerb, or carrying 3 hamsters 50 miles
NSF F Knows
OSF F Knows
NSR F Knows
OSR F Knows
Phone call to SIR :
NSF absolutely normal as new no issues no problem its fitting / driver error
OSF absolutely normal as new no issues no problem its fitting / driver error
NSR absolutely normal as new no issues no problem its fitting / driver error
Probably not being much help am I ? :P
Nige :ph34r:
Yep,
In all seriousness Trevs (LR90 - Admin here) website has a superb piece of kit :
IMHO this should be in the 'tech archive' as a basic starting point for suspension queries,
absolutely essential kit, if not a "godsend"...
you'll need a weighbridge ticket total / LR Front only / rear only = (3x weighs) ....to really be of use....but boy is it
Ta Trev :P
Nige
http://www.lr90.shacknet.nu/lr90/calculator.aspx
Thats the one, i'm sure i'll be using that in the future :D
Some pics to show the lack of compression
There's about 2" between the tub and the tyre (not chopped the tub out yet) and about 3" to go up in the damper
A-frame ball joint will be going, as soon as i can think of something to replace it with :unsure:
Erm................
NSF 4000 lbs
OSF 2700 lbs
NSR 128.88 lbs
OSR 10693 lbs
NSF 40.2 lbs
OSF 220 lbs
NSR 228.88 lbs
OSR 63 lbs
NSF F Knows
OSF F Knows
NSR F Knows
OSR F Knows
Phone call to SIR :
Nige :ph34r:
Is that what they call "variable rate springs" then...? :hysterical::ph34r:
i dont know the ratings but two options could be
1. Get Pugwash to sit in your wagon for a while that will help them settle down (very) quickly!
2. Change makes, i run procomps and find them superb, 255/85 touch tub on compressions, give +2" height and plently of droop!.
Yep,
Ta Trev :P
Nige
Did sir check the tech section/index/suspension?
You could try Bearmach springs, BA 2256 (front) and 2257 (rear). These give +2" lift, but are soft springs specifically for off-road use on a RR. Not suitable for towing or load carrying mind. Try Jim at Gigglepin if you want a good steer. 01732 464393. :D
