Bigger brakes
6 pot
Hi all I would like to fit bigger brakes to my defender as i am planning a huge engine upgrade. I know i will have to fit bigger wheels. Is there a off the shelf kit or will i have to find the parts separately?
Cheers Rob
Ehm, this is a joke right?
Are you fitting a nuclear reactor or a V8?
Why do you need bigger wheels to go with your huge engine?
If you are intending on invading a country let us know which one and we may be able to help.
:rolleyes:
no. no joke i want better brakes to avoid killing me or someone else
V8 (yank)
I know (think) I will need bigger wheels to fit round the bigger brakes
invading a country????? where the hell did you get this from?
I have talked to a north west tuning company who do 365mm ish discs with bigger calipers but i did not like there sales technique (wanted more for used stuff than i could buy it for retail new one bloke said adapters yes no problems the other who had some wheels to sell said they were weak )
Why would i be joking?
You don't say if you have a 110 or 90
Put vented disc on
They will make a hell of a difference and with good pads will do the job
The axles will limit the amount of power that will go to the wheels
It a land rover built in safety factor , put too much power thoUgh to the wheels and the half shafts break
And I really think you underestimate the power you are going to get a yank motor once it has gone though the 4 wd system
What BHP are you looking at
to be honest a 90/110 setup in good cond will be hard to beat.you could put vented on the front help with brake fade and that should do really.
i was running a 200+ bhp V8 90 with solid discs all round and ebc ultramax pads and it stopped on a dime.
i would be a lot of expense for little gain in my opinion.
Put 80series axles under it. They got HUGE brakes, and if you don't think they're good enough slap some grooved/drilled discs and green stuff (or whatever) pads on it. These axles will also handle the increase in power and give you a better turning circle ;) .
(311x35 vented front discs, 4pot caliper. 335x18 vented rear discs, single pot sliding caliper).
I've got them under my 109' with front pads from a 100series (physically bigger than 80series pads), brakes are awesome!
Cheers Rob
Hi Rob,
I do a big 6 pot calliper conversion, with 342mm discs (that are also twice as wide as a standard vented disc)
All bolt on, no modications required - although you do need to run 18" or bigger wheels.
The kit has been designed with ALCON, so is not some cheap budget calliper set up. Will be a few pictures in next months LRM.
Comes with braided lines, fluid etc etc.
Ian
I saw the guys at Rogers of Bedford fitting a 6-pot calliper kit to a customised Defender the other day. It might be worth calling them and asking about it.
That'll be a set of my brakes ;)
Onto this:
Just so happens I've also tuned it, supplied the lights, wheel adaptors... and a few other bits! :)
Ian
Onto this:
Ian
It was this car in LRM which made me decide to modify mine. In fact Porny supplied the adaptors for me, and I am hoping to return in the summer for an engine tweak ;)
I regularly tow a 25ft boat behind my landy and have thought about upgrading the brakes...if only money was limitless (but where would be the fun in that)!!!
And before anyone says anything I have now put extended arch's on so it is legal!
Onto this:
Ian
That's the one, Ian. I had a good look around it, and while the amount of lime green paint underneath and the size of the wheels are not to my taste, it's a very impressive vehicle.
Hi I am running a 4.2 tdi diesel in my 110 (340bhp) I am using standard landrover vented disks and calipers on the front and a standard disk rear axle set up as well. I regularly tow a 22 ft trailer for work behind this truck and it stops perfectly, as said earlier the std. setup is really good. I had std non vented disks on the front at the start but experienced serious brake fade if doing a lot of braking now I fitted the vented disks this issue had gone away.
