ukspike Posted February 24, 2011 Share Posted February 24, 2011 Hi guys, second question for the night, I gave the ninety a service at the weekend, changed all oils except the engine, the garage that I brought it from only two months ago did that, The swivels, I Could not find the level plug or the drain plug for these, the truck is a 2003, I did find the plug very near to the top of the swivel, but surly this is not the level as well is it???, any help would be most appreciated. Spike Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted February 24, 2011 Share Posted February 24, 2011 On my swivels there is no "level", I just fill with a sachet of "one shot" grease after I have been playing with them (changing seals etc.) or when there is obvious signs it has all escaped! Cheers Peter Quote Link to comment Share on other sites More sharing options...
landroversforever Posted February 24, 2011 Share Posted February 24, 2011 a 2003 axle doesnt have oil in the swivels. It has one shot grease which is a strip down and clean job to change. Supposedly lubed for life Quote Link to comment Share on other sites More sharing options...
ukspike Posted February 24, 2011 Author Share Posted February 24, 2011 Cheers Landroversforever, I was wondering if that was the case, but I had a manual handy and it said nothing about my type of swivels, guess I will just wait till they leak and then fill with one shot, many thanks. Spike Quote Link to comment Share on other sites More sharing options...
Disco-Ron Posted February 24, 2011 Share Posted February 24, 2011 Out of interest, how are you supposed to get the one shot grease in...???????? Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted February 24, 2011 Share Posted February 24, 2011 There is a single filler plug at the top on later models. No drain plug, Land Rover decided to omit it to save a few pennies. The older ones had a drain plug at the bottom and a level plug half-way up. Quote Link to comment Share on other sites More sharing options...
Puffernutter Posted February 24, 2011 Share Posted February 24, 2011 Remove the threaded plug towards the top of the swivel. Cut the corner off the one shot grease sachet. Align the two, squeeze, then clean all the one shot grease off the swivel, surrounding area and floor when it goes everywhere Don't ask me how I know.... Cheers Peter Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2011 Share Posted February 24, 2011 warm the satchet in hot water prior to filling the swivel, it's flow easier. Quote Link to comment Share on other sites More sharing options...
stuck Posted February 24, 2011 Share Posted February 24, 2011 Sorry to hijack, But what year did swivels change from oil to grease? Cheers, Mick. Quote Link to comment Share on other sites More sharing options...
western Posted February 24, 2011 Share Posted February 24, 2011 around '94 with the intro of the 300tdi Defender. Quote Link to comment Share on other sites More sharing options...
duncmc Posted February 25, 2011 Share Posted February 25, 2011 My March '95 300tdi 90 had EP90 in the swivels when I got it from a LR dealer in Sept '96. And the Dec '96 300tdi that I have just bought has grease in, but still has the level plugs and drain plugs. Of course the grease could have been put in since. Quote Link to comment Share on other sites More sharing options...
Trevorevans Posted March 27, 2011 Share Posted March 27, 2011 I checked my swivels today and there is grease in them but was wondering exactly how much should be in there? How do you know when the levels correct? Or is it just a case of get as much as you can in there. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 27, 2011 Share Posted March 27, 2011 Should be one sachet per swivel, although it's quite common for people to put an extra 1/2 sachet in. There's no real way to tell if you have enough in there - other than by cleaning it out and refilling. Les. Quote Link to comment Share on other sites More sharing options...
jonost24 Posted March 27, 2011 Share Posted March 27, 2011 Put the steering on full lock to move the swivel ball out the way....I think..... Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 27, 2011 Share Posted March 27, 2011 That's correct just off full lock works best and saves all that mess I discovered this by accident Mo Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 27, 2011 Share Posted March 27, 2011 I use oil, much easier to get in and out And you can check the level through the hole if you so desire. Quote Link to comment Share on other sites More sharing options...
ScottinAZ Posted March 29, 2011 Share Posted March 29, 2011 BTW, on the discussion of when did LR change the swivels...My 95 NAS D90 SW, which was built in late 95(took delivery in January 1996) had EP90 swivels. Quote Link to comment Share on other sites More sharing options...
