Chris.Ding Posted April 9, 2011 Share Posted April 9, 2011 Is it best to fit new universal joints or replace the complete propshaft with a complete cheap 'British' Part? I am thinking that the splined slider may go sooner rather than later. Also, I do not know if any damage has been done to the propshaft as the joints are very loose. I hope that a new complete propshaft with come with new nuts & bolts. PS Thanks to previous help for tracking down the cause of the vibration when accelerating. PS Are gaiters worth fitting? Quote Link to comment Share on other sites More sharing options...
western Posted April 9, 2011 Share Posted April 9, 2011 new props don't come with the bolts/nuts, you have to either re-use the existing items if they are in good order or buy new bolts/nuts. if the rilsan coating on the sliding section is damaged, it can't be repaired AFAIK, so it'll be new replacement prop time. IIRC 90/110 never had rubber gaiters fitted on the prop sliding section, but that's not to say you can't fit one, but ensure the prop alignment is noted & re-instated after fitting a gaiter & before tightening the gaiter clips. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 9, 2011 Share Posted April 9, 2011 My, I think original, front propshaft has a rubber gaiter on the sliding joint. Quote Link to comment Share on other sites More sharing options...
Les Henson Posted April 10, 2011 Share Posted April 10, 2011 Fitting a gaiter over the sliding joint will greatly prolong the life of it - providing you grease it well before fitting the gaiter. The parts of the prop that contain the universal joint are cast iron and most of the time don't get damaged when the U/J wears. Les. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 10, 2011 Share Posted April 10, 2011 I've never replaced a prop because the u/ j needed changing. Now that I read Land Rover forums it seems the in theng to do. I've yet to understand, is it the replace and not repair thing or simply not knowing what is and is not worn. I had to fit another prop to the front of my Defender last year when a u/j went. That was because the prop wasn't re usable. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted April 10, 2011 Share Posted April 10, 2011 I've never replaced a prop because the u/ j needed changing. Now that I read Land Rover forums it seems the in theng to do. I've yet to understand, is it the replace and not repair thing or simply not knowing what is and is not worn. I had to fit another prop to the front of my Defender last year when a u/j went. That was because the prop wasn't re usable. I agree |I have only ever replaced U/J in Landrover props , they are replaceable , thats why they have circlips and are not"staked" . I have had to replace 1 rear prop, because the vehicle came down on a boulder , and smashed the uni bending the prop in the process. I have always fitted the gaiter if missing , IIRC they used to be standard fitment . Quote Link to comment Share on other sites More sharing options...
western Posted April 10, 2011 Share Posted April 10, 2011 rubber gaiter only shown for the front propshaft item 8, page 399 my '89 110CSW never had them fitted from new. Quote Link to comment Share on other sites More sharing options...
mmgemini Posted April 10, 2011 Share Posted April 10, 2011 Why do the staked ones seem to last forever ? I worked at a Ford main dealer for 7 years. Mostly Transit. The u/ j's were staked, even on the extended chassis. I don't remember replacing one in that time. Why I served my time at United Omnibus Company Darlington. Started in the drawing office.1954. One of my first jobs was to draw a prop yoke. It was reasonably large and shew the cracks on that yoke...... Quote Link to comment Share on other sites More sharing options...
Dave W Posted April 10, 2011 Share Posted April 10, 2011 Replace or repair ? Quote Link to comment Share on other sites More sharing options...
western Posted April 10, 2011 Share Posted April 10, 2011 just a bit twisted, unwrap it & weld it back together, it'll be fine Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 11, 2011 Share Posted April 11, 2011 just a bit twisted, unwrap it & weld it back together, it'll be fine Over-kill Bit of duct tape and bailing twine should do the trick. Maybe some chemical metal for luck. Quote Link to comment Share on other sites More sharing options...
nicks90 Posted April 13, 2011 Share Posted April 13, 2011 its got a LSx V8 power going through it, so chemical metal wont do the trick. However a B&Q drain pipe slid over the top, with some exhaust clamps to hold it to each bit of the broken prop should suffice. Quote Link to comment Share on other sites More sharing options...
dantd5 Posted April 13, 2011 Share Posted April 13, 2011 just a bit twisted, unwrap it & weld it back together, it'll be fine For real?? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted April 13, 2011 Share Posted April 13, 2011 For real?? Only in extremis (gunfire over the next hill, and approaching). Quote Link to comment Share on other sites More sharing options...
