old leafer Posted December 3, 2011 Share Posted December 3, 2011 strange one here we have a rangerover trayback running 101 axles front and rear and have been asked to convert it to discs any idea what parts fit regards mark Quote Link to comment Share on other sites More sharing options...
Soren Frimodt Posted December 4, 2011 Share Posted December 4, 2011 AFAIK Zeus does one, at least they used to.. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted December 4, 2011 Share Posted December 4, 2011 i think zeus stopped it for the 101? few places that sell disk brake conversion for series, could they not fit with a mod or two? http://www.zeus.uk.com/land-rover.php http://www.heystee-a...csbrks/disc.htm http://www.rockymoun....uk/?page_id=41 http://www.roamoffroad.com/ Quote Link to comment Share on other sites More sharing options...
western Posted December 4, 2011 Share Posted December 4, 2011 Series parts won't fit 101 has 6 stud wheels/hubs instead of 5. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted December 4, 2011 Share Posted December 4, 2011 oh really? cheers Ralph, what about this, just with 6 studded disk and spacer? http://forums.lr4x4.com/index.php?showtopic=22910 Quote Link to comment Share on other sites More sharing options...
SOA 93 Posted December 4, 2011 Share Posted December 4, 2011 I did reply to this post this morning, obviously didn't load up, although I did wait for the green blocks to finish. Anyway, Zeus still do make the 101 conversion it's about £900 for each end, they are only made to order and they wait for about 10 orders before doing a run. You get custom bells, custom disc's, Caliper mounts, custom nodular cast iron 4 piston calipers with Stainless pistons, longer wheel studs, brake pipes, pads and fittings etc. Caliper piston size is the same as the old Jag XJ (IIRC) , whether that's the same as 110 calipers i don't know, discs are a bit bigger than LR's and alot thicker although not vented. As said above I don't think normal LR stuff will fit, the 101 axles are much heavier duty than defender salisbury's, bigger shafts, CV's, Hubs and bearings and of course they are six stud. If you manage to make something fit then please post up, I'd be very interested. Quote Link to comment Share on other sites More sharing options...
101sean Posted December 5, 2011 Share Posted December 5, 2011 I'd fit Salisbury axles off a Snatch 110 with discs already on and sell the 101 axles, they are worth around £500-750 each if in good nick. No one has come up with an alternative to the Zeus set up afaik Not much help to a challenge truck but there's nothing wrong with 101 brakes in normal use provided they are properly adjusted. There's a pic of an Aussie 101 Rapier tractor with it's back wheels off the ground on a braking test, that was when you could get proper asbestos shoes though! Quote Link to comment Share on other sites More sharing options...
Michele Posted April 23, 2012 Share Posted April 23, 2012 strange one here we have a rangerover trayback running 101 axles front and rear Bryn Hemming's RRC? Quote Link to comment Share on other sites More sharing options...
