backstop Posted December 13, 2011 Share Posted December 13, 2011 My '97 Defender 110 CSW seems to "lean" towards the passenger side a bit. Certainly, the rear passenger tyre is a bit closer to the wheel arch than on the driver's side. I've just read (on a site pushing Old Man Emu shocks and springs) that this is normal. Can anyone comment on this please? If I need to do something, any advice as to what to do, how difficult will it be etc? Quote Link to comment Share on other sites More sharing options...
western Posted December 13, 2011 Share Posted December 13, 2011 a slight lean to the left is normal, the drivers side springs are slightly longer, so with driver onboard the vehicle rides level when moving [well that's the theory according to LR] Quote Link to comment Share on other sites More sharing options...
Maverik Posted December 13, 2011 Share Posted December 13, 2011 My 90 it lopsided all the time just in different directions! - depends on how much fuel you've got it, if you're in it, what you've got in the back in verious places, its not a "huge" difference, but I've kinda learned to live with it. you can get 10mm spacers to sort it out, or you can just ballast it on the oposite side with a bag of spanners Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted December 13, 2011 Share Posted December 13, 2011 Pre-Td5 cars have a lean to the left with handed springs left and right. For Td5 models onwards they did away with it and went for the straight and narrow look. Quote Link to comment Share on other sites More sharing options...
MrKev Posted December 13, 2011 Share Posted December 13, 2011 See, in his avatar, even James' has a slight lean to the left. Kev Quote Link to comment Share on other sites More sharing options...
backstop Posted December 13, 2011 Author Share Posted December 13, 2011 Many thanks guys. Your replies saved me the worry that the MoT man might call for new springs or something. Quote Link to comment Share on other sites More sharing options...
mike080381 Posted December 13, 2011 Share Posted December 13, 2011 Just because the collective genius on here knows, doesn't mean that the MOT man knows too. I tried to have on tell me today that I need exhaust emissions on BOTH LPG and Petrol! Quote Link to comment Share on other sites More sharing options...
Lorrick Posted December 13, 2011 Share Posted December 13, 2011 Just make sure he does not fail it on missing handbrake cables Richard Quote Link to comment Share on other sites More sharing options...
landrover6x6 Posted December 17, 2011 Share Posted December 17, 2011 Hi , just a note to say i test vehicles every day, can only test on the fuel the vehicle drives in on , Quote Link to comment Share on other sites More sharing options...
pete3000 Posted December 18, 2011 Share Posted December 18, 2011 drivers side springs are slightly longer than pasenger side, so you get a slight lean, the logic is that the drivers weight levels it out. Of course you never see this as you can only see it when unladen usually. And doesn't take in to account passengers being as heavy. You could fit two passenger side front and two passenger side rear springs, or just eat more pies Quote Link to comment Share on other sites More sharing options...
mickeyw Posted December 18, 2011 Share Posted December 18, 2011 A lean at the front MIGHT be a sign of a collapsed swivel bearing. Check for this by jacking up the front axle enough for the tyre to be clear of the ground. Then get an assistant to waggle a shovel up and down under the tyre while you look for any movement between the swivel ball and housing. Quote Link to comment Share on other sites More sharing options...
Buzza Posted December 18, 2011 Share Posted December 18, 2011 Dont forget on pre TD5 models the fuel tank is on the drivers side as well Quote Link to comment Share on other sites More sharing options...
