Brilliant Ideas "Going on my Christmas list 2012" Thread
I have one of the 'normal' thread gauges and it comes in very handy but if someone was to give me a thread detective as a present I wouldn't say no :) It would certainly be harder to lose! :) ..... and I have plenty of socks
Not as 'bling' but I think I'll stick with these two I have:
http://www.frost.co....itch-gauge.html
Spearos, I have to agree, but this tool is for us real engineers :P
but used in conjunction with one of these which are surprisingly cheap these days, still leaves a few more toys to be bought with your £35.
The tool is a good idea though, as is this thread. My birthday is at the end of this month :D
It's not cheap for what it is though.
Actually, for what it is, it is cheap. It cost us a fortune to make something like. If you think about, and I'm sure David would agree, you need to machine a piece of metal to have a male thread and a female thread in it, and they should be to a 6g/6h fit ideally, its a bit of work to make, and they've been zinc plated, and stuck on a piece of wire rope, with plastic spacers in between, you've got a fair old bit of stuff there for your money. I don't think we could machine each fitting in less than 1.5/2 minutes, and that'd be with scrwecutting backwards in the gap before parting off, having drilled and tapped the female side, and when our machines book out at £40/hr +, you can easil say £1.20 each, and there's a few of them!
This thread should be locked and banned ..... my birthday was 2 days ago and I got no tools :(
I guarantee everyone that wanders into your workshop and sees a thread detective will try to screw two of the bits together......
Oh I do like that, being that size I would be less likely to loose it, just when I needed it!!
As above I just got myself the crimper and love it, although it's something you can use for big stuff I was more impressed with the way it worked on standard crimp connectors as the smallest die is 4mm a really professional job.
For Christmas I ask for (and get) selection boxes not the chocolate type but boxes of nuts & bolts, cir-clips, crimp connectors, washes etc, always useful to have on the shelf and can be brought for £5-£12 so better than a pair of socks!!
Jason.
As this is a Christmas list thread I propose we put the hydraulic crimper that Jason recommended on the list :)
Just happens it's also £35 if bought from http://www.eastadd.c...ol-prod-76.html
Turns out they got their pricing wrong and forgot to add postage :( So Jasons ebay link is the cheapest for this http://www.ebay.co.uk/itm/250990322863 41.99 delivered
I just ordered a crimper too! I'm a sucker for things like that - particularly recommended by someone I trust!
Si
Simon, Why do I have the feeling that you will find all sorts of uses for it apart from it's intended purpose!! Seriously I think you will be happy with it, I only have two comments so far, on smaller crimps where the wire wants to come out, its a bit of a three handed operation I got around this by putting it in the vice but want to make a small bit of tube with a base plate for it to sit in. The second thing I noticed on the bigger (yellow) crimps it crushed the plastic too much and exposed the terminal maybe I just got a bit over enthusiastic or used the wrong die but got around this by cutting off the plastic and using heat shrink.
Jason.
I have a few other items to add to the list:
A rechargeable LED torch from Clas Ohlson comes with 12v and 240v charger lasts for about four hours and has a really impressive light output and only £9.99.
12v USB power adaptors Great for charging different gadgets from Ipods to sat navs
IR Thermometer go for the higher temp range one again one of those devices that has a thousand uses, from finding leaks to faulty wiring.
12V fuse/circuit tester check the load on a circuit find items that are draining the battery etc.
Jason.
What are you thinking? Crimping the toes of people who diss me on line? :o
Actually, I just want something that does a better job of big ring terminals. I have a crimper for 16-70mm from Vehicle Wiring Products - and it doesn't do a particularly nice job of them. You generally have to select the next size down to make a decent crimp. I'm hoping these will make a neater job of it!
Si
