daveturnbull Posted August 24, 2018 Share Posted August 24, 2018 One of my favourite builds. When are you going to extend the sills to meet the front arches? Quote Link to comment Share on other sites More sharing options...
jad Posted August 24, 2018 Author Share Posted August 24, 2018 Well it took me this long to get around to modifying the side vent to fit. The sliders now being too short does annoy me since changing the outer wing skin but it had far too big a gap with the defender sides. Galv isn't the best thing to weld though... I really should get around to doing it though. Wonder if I can get them partially dipped to recoat the extra bit?.... Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 24, 2018 Share Posted August 24, 2018 59 minutes ago, jad said: Well it took me this long to get around to modifying the side vent to fit. The sliders now being too short does annoy me since changing the outer wing skin but it had far too big a gap with the defender sides. Galv isn't the best thing to weld though... I really should get around to doing it though. Wonder if I can get them partially dipped to recoat the extra bit?.... There are some spray on galvs you can get. Not sure how good they are compared to hot dip but I'd have thought like all paints it's down to the prep so as long as the surface is clean and degreased properly then that's better than nothing. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 24, 2018 Share Posted August 24, 2018 I've electroplating with zinc recently, very simple and good value.... Quote Link to comment Share on other sites More sharing options...
jad Posted August 24, 2018 Author Share Posted August 24, 2018 I do have some zinga. It's works pretty well but it looks quite different. Matt finish, not as smooth. Would probably look a bit odd! Bowie that sounds you haven't started a thread anywhere per chance? Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted August 24, 2018 Share Posted August 24, 2018 I suppose it's all down to aesthetics but a friend had pretty good success with coating the rock sliders I repaired for him (and had galvanised) with bed-liner. Also provided a bit of extra grip, but they were a different design being a Land Cruiser. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 24, 2018 Share Posted August 24, 2018 22 minutes ago, jad said: Bowie that sounds you haven't started a thread anywhere per chance? Afraid not, no, it stemmed from doing the electrolysis rust removal which is excellent, it was a natural step from there, just a few more chemicals needed. I can do a thread if people are interested.... Quote Link to comment Share on other sites More sharing options...
jad Posted August 24, 2018 Author Share Posted August 24, 2018 Bowie 👍 I could zinga and paint the whole thing but there would always be a part of me that knows 🙈 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 24, 2018 Share Posted August 24, 2018 Will see what I can do... Likely not until after the weekend though. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted August 24, 2018 Share Posted August 24, 2018 3 hours ago, jad said: Well it took me this long to get around to modifying the side vent to fit. The sliders now being too short does annoy me since changing the outer wing skin but it had far too big a gap with the defender sides. Galv isn't the best thing to weld though... I really should get around to doing it though. Wonder if I can get them partially dipped to recoat the extra bit?.... Can't you extend them and just send for complete dipping? It's possible to get items re-galvanised, that's all you would really be doing. Quote Link to comment Share on other sites More sharing options...
jad Posted August 24, 2018 Author Share Posted August 24, 2018 I could do! but at the moment its money I dont want to spend... When I take my TVR apart and galv the chassis that will probably be a sensible time to do that as well. 1 Quote Link to comment Share on other sites More sharing options...
lo-fi Posted August 24, 2018 Share Posted August 24, 2018 5 hours ago, Bowie69 said: can do a thread if people are interested Yes please Quote Link to comment Share on other sites More sharing options...
jad Posted August 9, 2023 Author Share Posted August 9, 2023 Well its been a very long time since I posted in here.... I still have it, no massive changes, going through some updating renewing parts etc. The following is a list of work I have completed over the past maybe year or so.... 3D printed a snorkel in ABS in about 16 parts and melted it together using acetone. Reprinted my speaker mounts in ABS, the previous PLA had warped in the hot weather. Changed the clutch release bearing as its been squeaking. Unfortunately only discovered LOF do an extreme heavy duty bearing after replacement.... 😕 Changed the front axle casing after finding out the mounts were about 9mm too far apart, also wanted to increase the castor angle to get rid of some remaining prop vibration. Its now on the limit of what it can be but is good for vibration. Changed the timing belt/waterpump. Cant say how glad I am that I did this. One of the bearings was as dry as the sahara and I also found the timing belt was not correctly tensioned 😳 So its always been a bit loose in my ownership.... Fortunately now corrected with a homemade washer in a washer.... I am also making a new android head unit for the car based on an SBC but that is work in progress. I need to do the pictures another time.... All of them appear to be in different places hiding somewhere! Jad Quote Link to comment Share on other sites More sharing options...
jad Posted August 9, 2023 Author Share Posted August 9, 2023 some photos..... and here is my dry bearing.... https://youtube.com/shorts/33Jcj7Ioo2Q Quote Link to comment Share on other sites More sharing options...
Popular Post jad Posted August 9, 2023 Author Popular Post Share Posted August 9, 2023 6 Quote Link to comment Share on other sites More sharing options...
smallfry Posted August 9, 2023 Share Posted August 9, 2023 Good to see you have a Renault Master Mk2. Best van ever. 1 Quote Link to comment Share on other sites More sharing options...
