I've used a dumb battery charger before and I've also used a bench power supply which could put out up to 30v dc.
You'll get more current through it by either increasing the voltage, increasing the solution strength or increasing the electrode area. Also ensure all connections are as good as possible. Oh and every so often clean the electrode(s).
Also clean your part really well afterwards or it will rust quickly as it's pretty much soaking in a salt solution.
We tried using a car batter that was at about 80% but it didnt put out much current at all. I wanted to use an old laptop charger which gives 19V at 3.5amps but my dad said it wasnt safe... <_<
The parts will be well cleaned when they come out. I took out one of the less rusty parts this morning washed it off in clean water dried and scrubbed it. It seems like a big improvement over their initial state! :)
Fortunately the noise the steering pump was making has now gone so I believe it was just air, but the leak is still there so I am fairly sure it needs another new seal :angry: but at least Its only 1 circlip and pulling the bearing out after the pump is off. That might wait though as it doesnt seem too bad....
Cheers
Jad
  • 2 weeks later...
So rather than being ill this Christmas I decided to get on with some car work! What a novel idea :blink:
Gearbox tunnel has been constructed
post-19190-0-64928900-1420573776_thumb.jpg post-19190-0-45811100-1420573780_thumb.jpg post-19190-0-55580500-1420573784_thumb.jpg post-19190-0-36103700-1420573788_thumb.jpg post-19190-0-45468600-1420573792_thumb.jpg post-19190-0-77420500-1420573796_thumb.jpg post-19190-0-54376600-1420573800_thumb.jpg post-19190-0-61108800-1420573804_thumb.jpg
We used some more lumiweld to fill in some fold lines. Its a little tricky to use but can yield some faily good results.
post-19190-0-27209600-1420573808_thumb.jpg post-19190-0-29188400-1420573917_thumb.jpg post-19190-0-16040900-1420573921_thumb.jpg
et voila
post-19190-0-52737200-1420573925_thumb.jpg post-19190-0-26473800-1420573990_thumb.jpg
And with a bit of trimming the original footwell panels fit. Although I am still a little unsure whether I want to make some new ones or not. I suppose it could always be done later when its on the road.
post-19190-0-73889400-1420573994_thumb.jpg post-19190-0-16911800-1420574009_thumb.jpg
and a bit more in the next post....
We made a brace to go under the seatbox for the handbrake.
post-19190-0-10413700-1420575067_thumb.jpg post-19190-0-70072500-1420575063_thumb.jpg
Made an attachment for the transfer box linkage to secure the knob
and after a little cutting and drilling the centre panel is on. Still not sure what to with the gearbox stick gaiter though so am open to suggestions!
I also added the original series instruction plate which im still hoping is correct with high towards the front..... Correct me if I am wrong?
We also finished off the drivers side rock slider as that has been waiting for a while now!
post-19190-0-85230700-1420575084_thumb.jpg post-19190-0-44556300-1420575090_thumb.jpg post-19190-0-28146000-1420575095_thumb.jpg post-19190-0-85506700-1420575610_thumb.jpg
Cheers
Jad
If I were you RE the gearstick gaiter, what about chopping the bent disco gearstick off where it steps out at the rubber line, weld some straight bar on the bring it forward a little and then use the front portion of a defender gaiter. I did the same with the gearstick and made a defender/disco hybrid gaiter in my tomcat.
Not the best pic but you get the idea. There are disco style leatherette gaiters on eBay for reasonable money I have used in the past.
Will.
Haha thats a brilliant idea! My dad initially wanted to put some storage in there but i got the feeling anything would just get quite warm and I didnt think it would look that tidy. Initially it will probably have a laptop on for tuning. But then cupholders will probably be high up on the list! Keep my coffee nice and warm :D
Cheers Will. I want something like that. just trying to work out the best way to keep it looking neat and tidy. I was planning on using a disco gaiter but dont have one to look at right now. Not sure how I would mate the current square hole to the round gaiter a defender has.... Will have to get hold of a couple and have a play. Cutting the gearstick is probably a good idea as at the moment it is a little far back, although manageable, but if you turn it around 180 degrees its a little far away! So right and forward would be ideal :i-m_so_happy:
Jad
Crikey that was quick! Definitely has potential....I like the incorporated tray. Are the cup holders big enough for costa cups? :P Think they might be a bit close to the megasquirt et al though, although I assume you have got the cover we are going to make for the electrics already on their? ;)
Hand fabricate? could make a billet top cover for the tunnel?......
That curved upper section is supposed to represent a cover containing the megasquirt and fuse box, the dims are completely out I'm not even sure if the units were in inches or mm haha and I didn't bother saving it but yeah a billet tunnel top would be smart, could even get it anodised for extra burburry points
And the cup holders are designed to fit bottles of newcy brown!
No as a matter of a fact not! i can "feel" the halfshafts screaming for their lives when I see axletramp! :D
Uhh that last one looks like it hurts the old pocket :(
With regards to axletramp, I take it this won't be used so much offroad? If not you could make some traction bars like the Yanks do on the old school dragsters, it should help the grip on launch as well?
It wont be used much off road. I got a bit bored of pay and play sites with my 90. Everything started to look the same.... Mostly it will be green laning trips with mates, winter hack and chav beater :P
I went for the Borg Warner T Box for the centre diff. Hopefully it will spread the power somewhat more effectively, prolong axle life and reduce axle tramp.
If I have axle tramp issues then yes I will be investigating some traction bar type system but at the moment I would like to keep it more simple if possible :)
Yeah had a seat in it and positioned it to have a look at making seat frames and it really doesn't feel that bad. In 2nd and 4th its a bit far back but I don't think it will be uncomfortable at all. If it is then shouldn't be hard to modify.
Not sure about Borg Warner but lt230 it's pull back for high ratio.
Mike
It is as standard but I think that the standard shifter is on a pivot and the linkage comes off below the pivot meaning that forward is back and back is forward?.... But I havent had a look at a car and cant find any pics on the internet so cant be too sure!
I grabbed a quick pic of the hybrid gaiter ther other day just in case it gives anyone any ideasIMAG1693.jpg
Hope you don't feel I'm trying to push anything.
Edit: damn iPad and photobucket! Struggling to copy and paste. Should be a new pic now?
Will.
