cackshifter Posted August 24, 2012 Share Posted August 24, 2012 I see Motor and Diesel http://www.ebay.co.uk/itm/170651925809?_trksid=p5197.c0.m619 are offering bits to allow fitment of a 'Puma' 6 speed Getrag box behind a 300tdi. Has anyone any experience or knowledge of these? They also offer a HD 250mm clutch for the TGV/300tdi. Nigel Quote Link to comment Share on other sites More sharing options...
Gazzar Posted August 24, 2012 Share Posted August 24, 2012 How does the 6 compare with the R380? Stronger? Higher top speed? Lower 1st gear? Quote Link to comment Share on other sites More sharing options...
ejparrott Posted August 24, 2012 Share Posted August 24, 2012 A friend has a 110 puma, he says he noticed no difference in top gear at all, but first is a lot lower than the old LT or R380 Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 24, 2012 Share Posted August 24, 2012 Yes, much lower 1st... Quote Link to comment Share on other sites More sharing options...
elbekko Posted August 24, 2012 Share Posted August 24, 2012 So only useful with a 1:1 TC behind it? Quote Link to comment Share on other sites More sharing options...
cackshifter Posted August 24, 2012 Author Share Posted August 24, 2012 M & D quote ratios as: 1st 5.443:1, 2nd 2.839:1, 3rd 1.721:1, 4th 1.223:1, 5th 1:1, 6th 0.742:1. R380 ratios 1st 3.39:1, 2nd 2.13:1, 3rd 1.3:1, 4th 1:1, 5th 0.77:1 Pumas have a 1:2: 1 transfer box, so quickly doing the sums for comparison with a 1.4, overall ratios... (and ignoring whether 1.22 etc) 6 speed 1st 6.53, 2nd 3.4, 3rd 2.4, 4th 1.47, 5th 1.2, 6th 0.89 R380 1st 4.75, 2nd 2.98, 3rd 1.82, 4th 1.4, 5th 1.08 Does look a usefully bigger spread at either end Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 24, 2012 Share Posted August 24, 2012 Your choice of transfer case gear depends on if you have power to push the top gear and will depend on your own engine... The main advantage is the much lower first for off road, low range use. Also note, reverse is a lot lower, 4.935 versus 3.429 Quote Link to comment Share on other sites More sharing options...
JimAttrill Posted August 24, 2012 Share Posted August 24, 2012 I can say that the R380 reverse is a bit high. I often use low-range to reverse out of steep driveways. Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted August 24, 2012 Share Posted August 24, 2012 From my experience of owning more than one Puma and numerous previous models the Puma box offers more relaxed cruising in top. Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted August 24, 2012 Share Posted August 24, 2012 how much! for an extra £100, i brought a whole landy for that! Quote Link to comment Share on other sites More sharing options...
nicks90 Posted August 28, 2012 Share Posted August 28, 2012 jeeeez - £1000 and you still have to buy the clutch and gearbox for it! If you want a more relaxed top speed cruise and a lower 1st - it would be much cheaper to fit a 1.6 transfer gear and an overdrive. Quote Link to comment Share on other sites More sharing options...
ini88 Posted August 12, 2013 Share Posted August 12, 2013 Has anyone fitted this yet? I would like to see if you need to push the engine back or forward at all. Quote Link to comment Share on other sites More sharing options...
