Sam's 3.5 Disco MEGASQUIRT START/FINISH INSTALL THREAD! :)
Mr Noisy
Congrats and glad that it started first time, just like mine did (so the guide on the VR sensor has worked 2 out of 2)
Mine also had a flat spot on hard acceleration with Nige's initial map, the first tuning run sorted that.
Hello mate thankyou :)
Yep 100% success rate, tbh I'd be including it in the instructions, I soldered up my EDIS and everything beforehand, I was confident the diagram was right and that I had interpreted correctly so saw no reason why it wouldn't start!
Unfortunately got lots to do before I can get it on the road :( can't wait because even moving round the shop I can tell its gonna be an awesome improvement! :)
Cheers!
Well, did this tonight, not that remarkable:
Finished it, plugged the ECU in and loaded some software.
Had a bit of a poke about and I'm pretty lost I'd say! :o
Guess I need to get my heater in, fill it up with coolant, fit the WB sensor and get it set up (some queries there too I think regards the switchover point?) and then just run it up and see what happens, take some live data and start getting my head round it!
Early night tonight!! :D
Well done Sam! Congratulations on getting your motor running and thanks to a superbly documented thread. :i-m_so_happy:
I started to document my 90 build on another forum, but that was even more of a ball-ache and more time consuming than actually dong the build. So i gave up the thread, then gave up the forum.
As has been said before, a picture tells a thousand words, keep them coming! Videos are great too.
Would the next phase in the build be tagged onto this , or are you likley to start a new one?
Everything will be in this thread mate, if its related to my Megasquirt build or regards the tuning and god knows what else In the near future, I'm not too keen on multiple threads if I'm honest so this one is THE Megasquirt thread, and I have a car build thread and engine build thread on Landyzone.
Cheers :)
I always find it amusing that peeps are worried about getting it running, then find it runs and won't stop ! :D
Its sort of 360 degreees out in their brains !
Thanks to the very clever Ian (BBC) who sussed this for me, when I 1st did mine I sort of thought "Er...." WTF
I also know that after the "Fix" was sussed a large number of peeps went "Whoppee" and up to that point had just used a full FIA Kill Switch :rofl:
I haven't yet worked out why some do and some don't, joys of Lucarse wiring looms :D
Nige
It makes sense that the lamp holds the relays on which then hold the system on whereas before it was all off the key and obvs the lamp wouldn't power the coil/fuel pump etc.
Now Nige, question for you.
Thinking on, here's my sequence if events:
Fit heater and refill with coolant.
Fit LC-1 Wideband and setup megatune accordingly and burn to ECU.
Warm up on base map ticking over, check coolant level etc.
Then check ignition timing and adjust on megatune if incorrect.
Then take out on the road.
Big question:
Am I better using megatune auto tune or megatune data log and then using analyser in megalogviewer? Or do they do the same job?
I think I will start to get my head round this bit by bit.
Any other pointers please??
Thanks! :)
Basics 1st Sir
Check
ALL 8 Guages on Megasquirt are working and reading
Ensure TPS is calibrated - also right click on any guage on megatune and select TPS, ignition on press Aceel pedal, 0-100% sweep ?
BLOCK off PWM and set Tickover srew on plenum
Reconnect PWM
Autotune is very very good, but a Log shows everything for double checking
Carry base map and a way to upload it if the new MSQ makes it runs like **** :D
Nige
Thankyou gents!
Yep the lc1 is grounded at the relay board which is cool, I think it will need a separate supply Sony can calibrate it before the igntion is on but can pinch that from a nearby battery!
Thanks for those tips Nige, will do! :D
Speak to Nige anyway and I'm sure he can confirm/sort out the prices! :D
Relay board is definitely "nice"
I am a person that can justify £98 for something which is nice.
It also means the wiring is screwed in not soldered to an impossible ECU plug so much easier for any future repairs, but if you're on a budget or simply not bothered about having the "nice" solution then you don't really need it.
Not trying to influence you either way because its personal choice really, to the sum of around £98! :)
Hmmm problems.
Can't get throttle to 0%.
Calibrate many times but always rests around 5-8%.
Get a full sweep to 100% and nice and smooth but won't calibrate to 0%.
So could this be why it will not idle below 1400rpm?
PWM disconnected, both ports blocked, and idle screw full in I get 1300/1400rpm.
Reconnect PWM and get 1700rpm approx.
It just won't slow down!
Don't think I had this problem until I filled the coolant up, now I have coolant temp 177F and its running fast.
Have sprayed carb cleaner around and makes no difference :(
Idle is a bit up and down and air/fuel ratio fluctuates (NB) when the pwm is plugged in.
Any ideas??!
To calibrate TPS
Megatune on ignition on
Tools
Calibrate TPS
Get current Top box should be 20-30
Press pedal to floor get current should be day 250- 300
Then save and exit
Set tickover by blocking note blocking pipe disconnecting pwm doesn't work it's a powered "off" when blocked check cable and throttle stop and then use screw on top of plenum to get steady
Check in settings what us set as tickover target when warm (+73 degrees )
Then reconnect pwm
Nige
Pwm is removed and has been removed every time and both ports are fully blocked!
Seems I might have an air leak because I put my hand over intake pipe on tickover and it carries on running quite happily with nearly no vacuum on my hand!
