mat2495 Posted March 12, 2013 Share Posted March 12, 2013 Could somebody confirm where the timing mark on the camshaft sprocket should be in relation to the woodruff key slot? I have two and they are 90 degree's different setting it up the two different ways suggests that 90 degrees anticlockwise is correct ( the other timing mark being opposite the key way. 3.5 engine with standard 3.9 cam if it makes an difference Thanks Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 12, 2013 Share Posted March 12, 2013 Its got nothing to do with where it is in relation to the woodruff key. The dots on the cam and crank wheels should be next to each other. Ie dot on cam at 6 o'clock and dot on crank at 12 o'clock. Providing cylinder 1 at TDC Quote Link to comment Share on other sites More sharing options...
mat2495 Posted March 12, 2013 Author Share Posted March 12, 2013 yes but if the dots are in a different position on the cam gear then surely the camshaft will be in a different position when the two dots align at cylinder 1 tdc? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 12, 2013 Share Posted March 12, 2013 Pics would be good, but from what you say the timing marks are in different positions to the keyway in the cam sprocket? Is one a Britpart? Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted March 12, 2013 Share Posted March 12, 2013 Not sure if this will help..... Timing marks top of bigger gear and small dot on top of lower gear... Engine at TDC. This was 4.6 but they aren't too different.... How different is yours?? Neil Quote Link to comment Share on other sites More sharing options...
zim Posted March 12, 2013 Share Posted March 12, 2013 Not sure if this will help..... IMG_1480.JPG Timing marks top of bigger gear and small dot on top of lower gear... Engine at TDC. This was 4.6 but they aren't too different.... How different is yours?? Neil Technically you're right, but it's normally setup with mark on the bottom of the big gear & mark at the top of the bottom gear. The above pictured will be ok as the crank turns twice to the cams once. G From google : 1 Quote Link to comment Share on other sites More sharing options...
mat2495 Posted March 12, 2013 Author Share Posted March 12, 2013 mine looks exactly like this one from turners website http://www.turnerengineering.co.uk/acatalog/info_240.html Quote Link to comment Share on other sites More sharing options...
duncmc Posted March 12, 2013 Share Posted March 12, 2013 And mine. Quote Link to comment Share on other sites More sharing options...
Scooby Jim Posted March 12, 2013 Share Posted March 12, 2013 My Rover 3500 Haynes agrees. Quote Link to comment Share on other sites More sharing options...
need4speed Posted March 12, 2013 Share Posted March 12, 2013 yep thats what i meant about 6 o'clock, 12 o'clock.... Quote Link to comment Share on other sites More sharing options...
zim Posted March 12, 2013 Share Posted March 12, 2013 Technically you're right, but it's normally setup with mark on the bottom of the big gear & mark at the top of the bottom gear.The above pictured will be ok as the crank turns twice to the cams once. G From google : No, you're not right...sorry. Quote Link to comment Share on other sites More sharing options...
mat2495 Posted March 13, 2013 Author Share Posted March 13, 2013 All sorted now, timing mark is definitely wrong on the new sprocket! Thanks all Quote Link to comment Share on other sites More sharing options...
Rob_B Posted March 13, 2013 Share Posted March 13, 2013 Not sure if this will help.....IMG_1480.JPG Timing marks top of bigger gear and small dot on top of lower gear... Engine at TDC. This was 4.6 but they aren't too different.... How different is yours?? Neil I did mine last week. 3.5 with 3.9 cam and a gear like in this picture. The key should be at 9 o'clock and the timing mark at 6 o'clock (in the pic it is at 12 o'clock) Quote Link to comment Share on other sites More sharing options...
mat2495 Posted March 13, 2013 Author Share Posted March 13, 2013 Yes, that's the conclusion i came to, but with the timing mark at 6 o'clock the key was at 12 o'clock. Really glad I compared the old and new gears as that would have caused quite a lot of head scratching when trying to get it to go. matt Quote Link to comment Share on other sites More sharing options...
Alpine Posted November 21, 2022 Share Posted November 21, 2022 Just wondering why my 1994 discovery 1 3.9 did not have a camshaft location plate fitted. l am replacing the camshaft and was thinking should I install one on reassembly. Stewart Quote Link to comment Share on other sites More sharing options...
smallfry Posted November 22, 2022 Share Posted November 22, 2022 The V8 with vee belts and a distributor did not have a locating plate. The disributorless engines (GEMS and Thor) did have one, but they were fitted to later vehicles. The engines with a wide polyvee belt (Serpentine) I cant remember TBH, but I dont think it did. 1 Quote Link to comment Share on other sites More sharing options...
Alpine Posted November 23, 2022 Share Posted November 23, 2022 Thanks a bit relieved as I did not won’t to deviate from original specs. good work small fry Quote Link to comment Share on other sites More sharing options...
