roguevogue Posted September 11, 2013 Share Posted September 11, 2013 I need help from someone who knows Mile Marker winches. I assume that that is what I have, but I can't find a picture of one with a motor quite like this one. I would like to know if there is a pipe work diagram somewhere, although I will probably sell it rather than use it. Any help would be appreciated, I searched the motor part number but found nothing useful. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted September 11, 2013 Share Posted September 11, 2013 http://hydliterature.eaton.com/literature/ any good? maybe low speed high torque motors, can't see the model number from your photos though. Quote Link to comment Share on other sites More sharing options...
steve b Posted September 11, 2013 Share Posted September 11, 2013 By the look of the size of the pipe ports I'd say that is an option to run on a PAS pump , ie low flow rate . The rest of the winch looks pretty good , so a new motor to match your flow and pressure and away you go? cheers Steveb Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 11, 2013 Share Posted September 11, 2013 Most of it looks like mine, but the motor is totally different. Mine just has two ports which go up to the control block in the wing. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 12, 2013 Author Share Posted September 12, 2013 Thanks guys, thanks for your help. The motor has the valve block, solenoids and I assume pressure relief mounted on it, the part number is 185-2478-002 but I can't find any reference to it. The winch looks barely used, the anodising on the fairlead is intact so no rope has been across it in anger for sure. Any suggestions what it might be worth? Quote Link to comment Share on other sites More sharing options...
zim Posted September 12, 2013 Share Posted September 12, 2013 £50 and i'll pay postage Quote Link to comment Share on other sites More sharing options...
Team Idris Posted September 12, 2013 Share Posted September 12, 2013 That looks like it isn't a power steering driven winch? It looks like the bottom pair of solenoids are forward and reverse, and the top one is the change over solenoid between drum rotation and hydraulic ram in and out - where the ram connects to those bottom pair of JIC fittings. The single line from the end of the motor is the 'leak off' line. One way valves in the block mean it is always connected to the tank low pressure line. All the other milemarker motors I've seen have shaft seals that can do full line pressure. But back in the day that was the way it was done, so an ordinary lip seal on the shaft could hold the oil in. Are there any letters marked on the ports? (T, P, L1, L2). p.s. £60 Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 12, 2013 Author Share Posted September 12, 2013 Thanks for that, the ports facing backwards are marked T and P, the pipe to the end of the motor is marked BRAKE, the other port facing away from the drum is marked T1, the hex port below it isn't obviously identified but has a screwed in plug so I assume it is the pressure relief valve. Google did throw up this LR4X4 thread, which seems to be on the same motor. Sadly no conclusion there either. Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 12, 2013 Author Share Posted September 12, 2013 By the way, £60 is slightly more tempting than £50 , not tempting enough yet though....... Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 12, 2013 Share Posted September 12, 2013 Are you not tempted to use it ? Ps £61.50 ? Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 12, 2013 Author Share Posted September 12, 2013 I would like to use it but i'm having a break (waiting for a tempting project) and I picked this up in a deal on another winch. I might take it to Newbury and see what the interest is like next month, if it doesn't sell I'll stick it under the bench, it looks almost new. Quote Link to comment Share on other sites More sharing options...
Anderzander Posted September 12, 2013 Share Posted September 12, 2013 I'm tempted for the body of the winch to replace mine - but I think realistically it's be more cost effective to refurb mine. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted September 13, 2013 Share Posted September 13, 2013 That's way cooler then T is tank, P is pump, T1 is a mystery? and the hex is maybe the Auxillary Relief Valve. There is no hydraulic over-run valve, as the solenoid on top lifts the brake. (This makes more sense, as how could an ancient motor finish up on a modern winch? ) Now I don't know about you guys, but both my hydraulics 'creep' out under load, so this would fix that annoyance right off It's a proper winch motor, as opposed to the usual conveyer belt motor we get bundled at the 'low end'. It certainly isn't worth what it cost new, which is a shame in a way, as I suspect the motor and valve alone would be £800+ ? But what drum speed at what flow? I'd throw an hour at it to connect it to something with a known flow, so you can say "does this drum speed at this flow" to gain extra cash cudos. But it should say ** cc/rev somewhere on the motor? Quote Link to comment Share on other sites More sharing options...
henk Posted September 13, 2013 Share Posted September 13, 2013 I might take it to Newbury I have a new normal motor for it as well as a 12v electric valve block (but don't know where) and go to Newbury Quote Link to comment Share on other sites More sharing options...
roguevogue Posted September 13, 2013 Author Share Posted September 13, 2013 I think that realistically I will sell it on as is, thanks Henk. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted September 16, 2013 Share Posted September 16, 2013 Using my best google fu, 10 minutes threw this up from your part no? http://www.eaton.com/ecm/groups/public/@pub/@eaton/@hyd/documents/content/pll_1303.pdf looks to me like yours and sounds feasible t-series brake low speed high torque, or close to it. Quote Link to comment Share on other sites More sharing options...
