landroversforever Posted November 19, 2013 Share Posted November 19, 2013 So who's built a wood burner to heat their workshop? I'm thinking about putting one in at some point. Anything you would do differently next time? Any particular plans you found online which were a great help? I've found a few different vague plans, but no real tech. I can hopefully get some proper stove pipe through a work colleague's mate for scrap price . Quote Link to comment Share on other sites More sharing options...
mickeyw Posted November 19, 2013 Share Posted November 19, 2013 There have been a few write ups on here about workshop heaters. I'm sure CwazyWabbit the ninja link finder, will be along very soon with directions to them. Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted November 19, 2013 Share Posted November 19, 2013 Made mine with an old propane cylinder, I patterned the controls on my proper living room heater and its quite controllable. As mine is fairly small a bed of solid fuel is handy to keep it going when I'm distracted and forget to throw sticks on it. Use a hefty section for the first bit of the stack if you want it to last. I had an old co2 cylinder the same size as a pub bottle which I cut a 2 foot section from. The heat from that alone warms a big area. Luckily it was a nice fit to a standard flue pipe. I do plan to make a heat exchanger to burn waste oil in small quantities. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 19, 2013 Share Posted November 19, 2013 There have been a few write ups on here about workshop heaters. I'm sure CwazyWabbit the ninja link finder, will be along very soon with directions to them. My ears are burning A build http://forums.lr4x4.com/index.php?showtopic=60373 Bits and pieces http://forums.lr4x4.com/index.php?showtopic=63232 Design by Si http://forums.lr4x4.com/index.php?showtopic=21195 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 19, 2013 Author Share Posted November 19, 2013 My ears are burning A build http://forums.lr4x4.com/index.php?showtopic=60373 Bits and pieces http://forums.lr4x4.com/index.php?showtopic=63232 Design by Si http://forums.lr4x4.com/index.php?showtopic=21195 Get away from the stove then . Cheers! Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 19, 2013 Share Posted November 19, 2013 Get away from the stove then . Cheers! Are you kidding? It's like an ice box in here Quote Link to comment Share on other sites More sharing options...
bluespanner Posted November 24, 2013 Share Posted November 24, 2013 I just got an old rayburn off a farmers scrap heap. It runs 4 rads and heats the girl next doors shop too. I also rigged up a water cylinder on the loft so I can finally wash my hands in hot water! I burn pallets but dismantling them is labour intensive. I want to make something to mount on a digger/fork lift that will break one up. Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted November 24, 2013 Share Posted November 24, 2013 Wouldn't driving over them sort most of the breaking up of the pallet? Quote Link to comment Share on other sites More sharing options...
WESTENDER Posted November 24, 2013 Share Posted November 24, 2013 An axe or a maul, no punctures off the many nails either Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted November 24, 2013 Share Posted November 24, 2013 I used to lay them flat on the floor and put a foot on it then just run a chainsaw across it either side of the blocks. Done both sides this gives you lots of lumps of wood that are wood burner sized, plus lots of short bits of plank that split lovely and easily into kindling. Quote Link to comment Share on other sites More sharing options...
Deej Posted November 24, 2013 Share Posted November 24, 2013 (edited) Here's a link to the build pics for my woodburner, might give you some ideas:http://s1142.photobucket.com/user/DJDeejUK/slideshow/Wood%20Burner Edit: Just had a look through the pictures again and realised there are some funny ones in there as well. Such as six foot flames shooting out the flue when I fed it some used engine oil... Edited November 24, 2013 by Deej Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 24, 2013 Author Share Posted November 24, 2013 Thanks Deej. What size bottle is it? Quote Link to comment Share on other sites More sharing options...
Deej Posted November 25, 2013 Share Posted November 25, 2013 19Kg Quote Link to comment Share on other sites More sharing options...
Cliff Pountney Posted December 4, 2013 Share Posted December 4, 2013 Where are you planning to draw the cold air from? Is there an advantage to ducting it to draw air from outside? 1) If air is drawn from inside it gets replaced by cold air being drawn in from outside (around door gaps, etc). 2) Any gasses in the shop get drawn into the burner. That might be a good thing but could also lead to an explosion. (unlikely agreed). 3) If the chimney is not drawing for any reason and you arrange the ducting to drain any carbon monoxide gets dumped outside. 4) This final reason is tenuous in the extreme.......cold air is denser so you should get more heat. That might be negated by having to heat that cold air up more. I think I would look at providing a door seal and an external air pick up. Great looking device though. I need to build one! Cliff Quote Link to comment Share on other sites More sharing options...
GW8IZR Posted December 4, 2013 Share Posted December 4, 2013 2) Any gasses in the shop get drawn into the burner. That might be a good thing but could also lead to an explosion. (unlikely agreed). Yep, spraying brake cleaner about when the burner or a propane heater is on leads to very odd headaches and strange dreams .. Quote Link to comment Share on other sites More sharing options...
Tanuki Posted December 4, 2013 Share Posted December 4, 2013 Yep, spraying brake cleaner about when the burner or a propane heater is on leads to very odd headaches and strange dreams .. Yes - the vapours from some organohalogen solvents/refrigerants can be seriously dangerous/fatal if they contact hot metal. "Phosgene", for example, was used as a gas during WW1 Quote Link to comment Share on other sites More sharing options...
heath robinson Posted December 10, 2013 Share Posted December 10, 2013 That and the fact that if the burner is shoving gas up the chimney, and so to replace that is pulling cold air into the building (through door/window gaps, under the eves etc.). If you draw your air in from outside, you're not circulating cold damp air around your workshop. If you make a cold air manifold, you can have air go in under the embers, and also above the heart of the fire to help burn off the gassified combustibles. Speaking from experience (I've made a few small/medium ones, and one monster horizontal 47kg one), gas bottle burners loose any residual heat as soon as the fire goes out. The one I made for my camper is twin-walled (two sizes of bottle, nested) and the gap between the walls packed with sand as a thermal mass. Works a treat! Use 2/3s of the top of the bottle for a baffle, and kink the chimney, you'll get loads of heat out of the hotplate and flue before the sides of the burner heat up. The more single-walled flue you have inside your shop the better, for heating, so angle the pipe across as much space as you can. And lastly, make sure your door seals are good, carbon monoxide poisoning isn't as exiting as phosgene gassing, but still not much fun. Hope that helps! Quote Link to comment Share on other sites More sharing options...
heath robinson Posted December 10, 2013 Share Posted December 10, 2013 Alternatively, have a look at designs for rocket stoves/rocket mass heaters. Low-tech, and amazingly efficient! http://www.richsoil.com/rocket-stove-mass-heater.jsp http://www.inspirationgreen.com/rocket-mass-heaters.html Quote Link to comment Share on other sites More sharing options...
landrovermanuk Posted January 19, 2014 Share Posted January 19, 2014 There is a very good write up on building log burners on an american site OFN. It's in the general fab section on the second page..., Hope this helps... Quote Link to comment Share on other sites More sharing options...
