davidlandy Posted October 15, 2006 Share Posted October 15, 2006 at a recent pay n play day Isaw a couple of motors shod with the fedimas, the ones with the same tread patterns as the simex ETs. Where the side wall met the tread they were all mishapen all the way round - its almost as if the tread has been put on in about 8-10 sections - are they supposed to look like that? Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted October 15, 2006 Share Posted October 15, 2006 They all do. Its never a problem. Ive seen quite a lot of them like it including mine. There was a whole thread on Difflock.com about it. Quote Link to comment Share on other sites More sharing options...
JST Posted October 15, 2006 Share Posted October 15, 2006 i can confirm mine do as well. Quote Link to comment Share on other sites More sharing options...
ciderman Posted October 15, 2006 Share Posted October 15, 2006 No problems yet with mine , I did notice that they were on Michelen casings, But as they were half the price of Simex and taller , i recon thats a result. Quote Link to comment Share on other sites More sharing options...
gsr341 Posted October 15, 2006 Share Posted October 15, 2006 what do you fedima , useres think of them then ? on and off road ? Quote Link to comment Share on other sites More sharing options...
ciderman Posted October 15, 2006 Share Posted October 15, 2006 On road ,there ok ,Not as noisey as Simex , In the wet its a bit spicy Like a grass snake on a greasy pole. Off Road their excellent the side walls are of a very strong construction so they tend to stay on the rims when on low pressures . The actual height of them when new is 36.5 inches which is good for clearance ,But I have had to change the gearing on the diffs to compensate the higher gearing , And the steering lock will also suffer , but dont let that put you off. Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted October 24, 2006 Share Posted October 24, 2006 Mine are OK on the road (the landrover drives that bad you cant tell) Brilliant in Mud, grass etc etc but I find them poor on rock and stone. Ive seen me struggling to drive up a rock waterfall and failing then an almost identical prep'd landrover drove straight up without spinning a wheel on simex. Had similar experience since on pretty much every big rock step Ive come across! Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted October 24, 2006 Share Posted October 24, 2006 Mine are OK on the road (the landrover drives that bad you cant tell) Brilliant in Mud, grass etc etc but I find them poor on rock and stone. Ive seen me struggling to drive up a rock waterfall and failing then an almost identical prep'd landrover drove straight up without spinning a wheel on simex. Had similar experience since on pretty much every big rock step Ive come across! Saw these at Sodders Taller than simex, remoulds etc but NOT as wide and not as agressive as a simex, the lugs don't poke out as far which prob means less grip AND less mechanical damage IMHO Nige Quote Link to comment Share on other sites More sharing options...
GBMUD Posted October 24, 2006 Share Posted October 24, 2006 I find them poor on rock and stone. Ive seen me struggling to drive up a rock waterfall and failing then an almost identical prep'd landrover drove straight up without spinning a wheel on simex. Had similar experience since on pretty much every big rock step Ive come across! Try reducing the pressures. Rogue Vogue runs them and his vehicle is awesome on rocks. Chris Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted October 24, 2006 Share Posted October 24, 2006 Ive been running them low, Was running them very low but keep coming off rim's so I dont go lower than 15psi now. But even when I was using them lower they still seem'd rubbish on rock! Quote Link to comment Share on other sites More sharing options...
DefcoL Posted June 15, 2009 Share Posted June 15, 2009 Fedima off road tyres : So far have only heard good reports from those who used them for 3+ years. apart from the derogatory stuff on D44 site (but then they dont sell) I understand they are there to promote their brands, but ask those who have used them for years and you will here the truth. I hope to be at the scott williams event In July and will be running on fedimas. Quote Link to comment Share on other sites More sharing options...
Steve Hiatt Posted June 15, 2009 Share Posted June 15, 2009 I've used Fedima Maxigrip and latterly Partners, supplied by 28x4.com and they are superb. in over 40 races I've had no punctures other than a couple of nails, never from impact damage. I was amazed how much grip and stopping power the Partners have, and a low wear rate. So much better than the Yokohama Geolandars that the tread is based on, did one race on a new set, two sidewall punctures, well worn and little grip off road. Probably a good opportunity to recommend 28x4.com. Very helpful, good price and prompt, personal delivery. Quote Link to comment Share on other sites More sharing options...
ciderman Posted June 15, 2009 Share Posted June 15, 2009 I agree , 3 years on and mine are still fine , cut up abit all the same but they have outlasted a set of simex that a friend was running . I wouldnt hesitate ordering another set , but dont need em yet . Quote Link to comment Share on other sites More sharing options...
PITBULL Posted June 15, 2009 Share Posted June 15, 2009 last i heard about these no one could get hold of them has this changed as i as thinking about a set??? Quote Link to comment Share on other sites More sharing options...
missingsid Posted June 15, 2009 Share Posted June 15, 2009 Last year I saw a set of Bogger copies (not sure if they were Fedima Trial Ade) but they had the rotation arrows facing the wrong way for the tread pattern. This meant that the carcases were wrong which isn't a problem off road if you fit them backwards but is a problem if you use them on road as they would be illegal. Up until then I had thought of getting some but as I could only find them mail order I could not guarantee the rotation fitting before purchasing them. Marc. Quote Link to comment Share on other sites More sharing options...
DefcoL Posted June 15, 2009 Share Posted June 15, 2009 Last year I saw a set of Bogger copies (not sure if they were Fedima Trial Ade) but they had the rotation arrows facing the wrong way for the tread pattern. This meant that the carcases were wrong which isn't a problem off road if you fit them backwards but is a problem if you use them on road as they would be illegal.Up until then I had thought of getting some but as I could only find them mail order I could not guarantee the rotation fitting before purchasing them. Marc. Hi Marc Re "(not sure if they were Fedima Trial Ade)" All Fedima tyres are a bead-to-bead reconstructed tire with all markings in the mold. So I dont think they were Fedima. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted June 15, 2009 Share Posted June 15, 2009 last i heard about these no one could get hold of them has this changed as i as thinking about a set??? Apparently that has changed, I havent first hand experience but these guys are supposed to stock them http://www.28x4.com/ I fancy a set of Jungle trekkers but the price keeps putting me off, havent got round to phoning these guys yet to see how much the siroccos are.......anyone got the 285/75-16s? Dave. Quote Link to comment Share on other sites More sharing options...
missingsid Posted June 16, 2009 Share Posted June 16, 2009 Hi Marc Re "(not sure if they were Fedima Trial Ade)" All Fedima tyres are a bead-to-bead reconstructed tire with all markings in the mold. So I dont think they were Fedima. I think you are correct. I have just looked at a photo of one and they have writing on the side that the ones I saw did not. Marc. Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted June 16, 2009 Share Posted June 16, 2009 last i heard about these no one could get hold of them has this changed as i as thinking about a set??? Thet had loads at the Eastnor show the other week!! Paul Quote Link to comment Share on other sites More sharing options...
DefcoL Posted June 19, 2009 Share Posted June 19, 2009 I fancy a set of Jungle trekkers but the price keeps putting me off, havent got round to phoning these guys yet to see how much the siroccos are.......anyone got the 285/75-16s? Dave. Did you know that they have an OD of 33.5'' Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted June 19, 2009 Share Posted June 19, 2009 Did you know that they have an OD of 33.5'' Nope, But I do now. Will have to give 28x4 a ring and ask about prices I think. Dave. Quote Link to comment Share on other sites More sharing options...
jcwcooper Posted June 24, 2009 Share Posted June 24, 2009 Just found out that the speed rating is only 'J' so 62 mph! Thats a bit low for my liking as I use my landrover on the road too although im not going to be tearing it round all the time but thats a bit close to cruising speed on the dual carridge way. Dave. Quote Link to comment Share on other sites More sharing options...
BobtailBogey Posted June 24, 2009 Share Posted June 24, 2009 been looking at these for a while but the 35" stand almost 37~" tall which is a bit too much for me i think. Quote Link to comment Share on other sites More sharing options...
ciderman Posted June 24, 2009 Share Posted June 24, 2009 been looking at these for a while but the 35" stand almost 37~" tall which is a bit too much for me i think. Whys that Si , do you get nose bleeds Your right they are tall and have a habbit of messing your gearing up . Saying that they do smaller sizes now , I think Dave from BWORC has just fitted a set on his 90 in a smaller size ,But apparantly they still stand at nearly 35" Quote Link to comment Share on other sites More sharing options...
Paul Humphreys Posted June 24, 2009 Share Posted June 24, 2009 Whys that Si , do you get nose bleeds Your right they are tall and have a habbit of messing your gearing up . Saying that they do smaller sizes now , I think Dave from BWORC has just fitted a set on his 90 in a smaller size ,But apparantly they still stand at nearly 35" Do you know what size they were? Paul Quote Link to comment Share on other sites More sharing options...
