M10 hex rivnuts
Anderzander
Thanks guys - how do they install ? I can't quie make it out .... Does that collar fold up on the outside with the thread inside ?
I'm searching now for somewhere that sells them in small quantities..... Also working out if I could get a nut inside and hold it to tighten a bolt there.
Hi,
Rivnuts fit from the front whereas Hank Bushes fit from the rear so you need good access as you need to put a lot of force on the back in order to use a setting tool (tapered punch or possibly a ball baring) and hammer or press on the front to splay out the hank sleeve.
Marc
Your other option is a nut welded to a strip of metal you can slip through a drain hole.
Or, the easier one, a bolt welded to a strip of metal you can poke through a drain hole. Trying to fit something and line the nut up is hard, but a poking out bolt thread is a lot easier.
http://www.orbitalfasteners.co.uk/en/search/c/2765/p/2 do M10 and M12 in steel Rivnuts an can order in single units
Thanks both - but these look like standard round rivnuts - rather than the hex shaped ones to fit the crossmember.
