chris2010 Posted August 8, 2015 Share Posted August 8, 2015 300 tdi defender. Auto. 1.6 transfer box. Running on 35.10.5.16 fedima siroccos. Rear mounted . Full length brand new defender td radiator. Twin cooling fans . Davies craig electronic water pump with controller to suit. Water pump impeller and thermostat removed. Brand new cylinder head and gaskets . 50/50 antifreeze mix This is the problem or not . Outside temperature 26 degree's. 50 mph constant speed. Temperature gauge sits between 100 degrees and 105 degrees. To me this seems to warm. But it's a constant reading backed up with the davies craig temperature reading. When I drop down to 30mph through town it drops to about 90/95 degree's. and on idle it sits at 85ish after its cooled down . Is this OK ? Or am I getting over paranoid ? My only next thing I'm going to install a roof scoop to direct cold air behind the can Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted August 8, 2015 Share Posted August 8, 2015 That sounds very hot to me.... My 200 sits at 88 degrees all day.. Doesn't matter what it's doing. That's off an aftermarket VDO Temp gauge. Quote Link to comment Share on other sites More sharing options...
chris2010 Posted August 8, 2015 Author Share Posted August 8, 2015 My runs a vdo gauge . I'm just wondering with all the mods etc it might push temperatures up . Also with the lack of natural airflow through the rad this would put the temperatures up Quote Link to comment Share on other sites More sharing options...
Diesel_90 Posted August 8, 2015 Share Posted August 8, 2015 When you say you've removed the thermostat have you blanked off the bypass hose? Quote Link to comment Share on other sites More sharing options...
western Posted August 8, 2015 Share Posted August 8, 2015 reckon with rad behind the cab & no ram air flow only the fans [when they switch on] & no thermostat that's why your getting over 100 degree readings, most 'normal' tdi's sit around 90/95 when working. Quote Link to comment Share on other sites More sharing options...
Team Idris Posted August 8, 2015 Share Posted August 8, 2015 Sounds like a reverse vortex coming off the front of the vehicle and working against the fans. Do the fans have a proper fan-cowl in the form of a box? (As opposed to two fans lying against the rads fins)? Landys have funny air flows. At 30mph a sheet rolled up in front of the vents started moving toward the bonnet edge! Quote Link to comment Share on other sites More sharing options...
chris2010 Posted August 8, 2015 Author Share Posted August 8, 2015 The bypass pipe goes to the radiator . fans are up against the fins, When fans are on . And on idle you can feel a lot of hot air being pushed out of the rear of the radiator Quote Link to comment Share on other sites More sharing options...
chris2010 Posted August 9, 2015 Author Share Posted August 9, 2015 This fault is starting to get on my nerves to the point I may just break my truck up. Give up spending money on it Quote Link to comment Share on other sites More sharing options...
Snagger Posted August 12, 2015 Share Posted August 12, 2015 I'd refit the original water pump and thermostat for a start, but the rear mounted rad isn't going to be good for high speeds. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 13, 2015 Share Posted August 13, 2015 Rear mounted rads can work really well at all speeds, but it's all about how you duct air to them. Seeing a photo or three of the setup would be very helpful. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted August 13, 2015 Share Posted August 13, 2015 Put the thermostat back in it's there for a reason without it there is no control over water temperature or flow. I ran a 200tdi tomcat with rear rad for 5 years as a daily driver several trips to Italy never a problem I had standard water pump, standard thermostat and an electric fan (that very rarely ran). Mike Quote Link to comment Share on other sites More sharing options...
