gearbox for series 3 whats the best fit for 5 speed
sussex-landy
IMHO the one that needs the least buggering about would be a 4 pot defender LT77 with an adaptor plate to join it to your V8.
Well he's already got the adapter plate...
Anything can be made to fit, LT77/R380 are much of a muchness but you need the Defender tail end.
  • 3 weeks later...
Have you considered fitting an overdrive instead? What is it that you are trying to achieve, a wider range of gears or better motorway cruising? The extra power from the V8 wouldn't have a problem with a change in diff ratios either.
I was going to make the same suggestion - it has a similar step up as 5th on a LT77 or R380, but is simple to fit with standard parts and also allows the "splitting" of the lower gears to give 1st and 1.28, 2nd and 2.28, 3rd and 3.28 as well as a new top gear. That can be handy on hills.
  • 2 weeks later...
  • 2 weeks later...
