landroversforever Posted January 2, 2012 Share Posted January 2, 2012 I'm trying to work out what the clutch pedal on my truck is, and if it is the original one. The truck is a 1984 90, with what I assumed was the original pedal. A mate at work suggested fitting the 300tdi pedal as this is spring assisted. Now the one on the truck looks remarkably like the one I have bought! So could somebody with a 200tdi or before, post up a picture of their clutch pedal as viewed from the floor please? Thanks in advance all Quote Link to comment Share on other sites More sharing options...
Gazzar Posted January 2, 2012 Share Posted January 2, 2012 I think your mate may have given slightly incorrect advice. I think he may have meant the td5 clutch pedal, it is assisted by an over centre spring - quite different, once the "centre" is reached the spring helps the push. The earlier 110/90 clutch pedal is very similar to the series version. G. Quote Link to comment Share on other sites More sharing options...
western Posted January 2, 2012 Share Posted January 2, 2012 300Tdi have a overcentre assist spring it's like this spring item 2 in this link http://www.numcat.ru/landrover/p/31/53772/ 300tdi pedal can be fitted to older vehicles, I've had one of these pedals since mid 1995 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 2, 2012 Author Share Posted January 2, 2012 Well, assuming the pre 300tdi (never seen one before) looks nothing like that, I already have a 300tdi pedal! Doh! Quote Link to comment Share on other sites More sharing options...
western Posted January 2, 2012 Share Posted January 2, 2012 Well, assuming the pre 300tdi (never seen one before) looks nothing like that, I already have a 300tdi pedal! Doh! pre 300Tdi clutch pedal here http://www.numcat.ru/landrover/p/31/53773/ Quote Link to comment Share on other sites More sharing options...
Diff Posted January 2, 2012 Share Posted January 2, 2012 The 300tdi and later pedal spring doesn't actually help to push the pedal down. It is an overcentre pedal return spring. This means that it only acts as a pedal return spring in the first part of the pedal stroke. As you push the pedal down, the return spring goes 'overcentre' so that for most of the pedal stroke, you are only pushing the pedal down against the force of the springs in the clutch cover plate, rather than against the force of the springs in the clutch cover plate AND the force of the pedal return spring, as in the pre 300tdi models. The pre 300tdi models have an unecessarily strong pedal return spring which adds a considerable amount of 'stiffness' to the clutch. Fitting a 300tdi and later spring/pedal works very well. You can also fit a much lighter (use one with as many coils and as long as possible) replacement return spring in place of the original on the pre 300tdi pedals for a similar result. Regards, Diff. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 2, 2012 Author Share Posted January 2, 2012 Thanks for the info All . What it seems to have confirmed is that I now have a duplicate of the pedal I started with . Quote Link to comment Share on other sites More sharing options...
CwazyWabbit Posted January 3, 2012 Share Posted January 3, 2012 Thanks for the info All . What it seems to have confirmed is that I now have a duplicate of the pedal I started with . ... and a weak left leg if you needed something softer than the 300 tdi pedal you already had Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 3, 2012 Author Share Posted January 3, 2012 I stupidly assumed I would have the old pedal on there Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 3, 2012 Share Posted January 3, 2012 That other one going spare now then Ross? Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 3, 2012 Author Share Posted January 3, 2012 Thinking of building it into the new PC, push the pedal to make the fans go faster Yes it is Quote Link to comment Share on other sites More sharing options...
mickeyw Posted January 3, 2012 Share Posted January 3, 2012 I changed the pedal in my V8 90 to the over centre spring type. It still gave me a painful leg after a day off road, and the V8 clutch is somewhat lighter than the diesel one. Problem solved - I fitted an auto box. Think I still have the sprung pedal box somewhere James... Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 3, 2012 Author Share Posted January 3, 2012 I would like a lighter clutch sometime in the future, I have a painful left hip after long hours in the drivers seat. But it can wait for now Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2012 Share Posted January 3, 2012 I would like a lighter clutch sometime in the future, I have a painful left hip after long hours in the drivers seat. But it can wait for now fit a pedal servo, similar to a brake servo but smaller diameter. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 3, 2012 Author Share Posted January 3, 2012 But how much is that going to rape my wallet for Ralph? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted January 3, 2012 Share Posted January 3, 2012 What you need, Ross is a clutch pedal for a Lightweight. Mo Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 3, 2012 Author Share Posted January 3, 2012 Quote Link to comment Share on other sites More sharing options...
western Posted January 3, 2012 Share Posted January 3, 2012 But how much is that going to rape my wallet for Ralph? don't know, there was a thread recently can't remember if it was on here or LRO or somewhere else. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted January 3, 2012 Author Share Posted January 3, 2012 ohhh, was that the red servo thingy? IIRC it was around £300? I think Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted January 3, 2012 Share Posted January 3, 2012 Something like this would do the job as well though surely? http://www.ebay.co.uk/itm/150730159415 My Series III came with one on the brakes, and another in the box in the back. Sadly they both went in the bin, but given that the vehicle sat for 10 years I would have had doubts as to their effectiveness any more! Quote Link to comment Share on other sites More sharing options...
western Posted January 4, 2012 Share Posted January 4, 2012 ohhh, was that the red servo thingy? IIRC it was around £300? I think Yes, that was it. Quote Link to comment Share on other sites More sharing options...
ashtray Posted January 5, 2012 Share Posted January 5, 2012 http://www.redbooster.com/ Quote Link to comment Share on other sites More sharing options...
discomikey Posted January 5, 2012 Share Posted January 5, 2012 i thought about a remote servo for my series 3, as the pedal is rather heavy with a HD cover. a mini one i think is around £30 Quote Link to comment Share on other sites More sharing options...
