Final help and opinions for my 110 300tdi rebuild
11 hours ago, Pastycrimper said:
Hi, Well unfortunately the heater blower unit/assembly I just received from breakers is a Puma/TDCi type so no good to me. Do you have one available in good condition?
Yes I have a few. I will dig one out tomorrow. shame I was just down the road from your Defender last weekend!
Ahoy. Thornton Breakers are sending down another one free of charge from an earlier (2001) TD5. Not sure what the condition will be like........
Has anyone ever tried refurbishing a the whole heater assembly. My old one looks largely riveted together. I am planning on wire brushing mine back to steel and rust priming and repainting but I guess it is also rusting from the inside.
The housings are riveted along several joints, spot welded on others, but you should be able to dismantle it with just drilling out rivets.
I ran caustic soda solution through mine to clear out scale and rust, and it brought out a lot.  I left it soaking in a bucket of hot caustic soda solution to cleanse the outside.  It works well, but give it a good purge with clean water to prevent coolant contamination and water pump damage later.  The big Alisport upgrade matrix is tempting but expensive.  Somebody on here did a great heater upgrade using a matrix that also had an electrical heater, I think from a Peugeot, so they got instant heat electrically and then engine heat once after a few minutes to save alternator load.  I think it may have been Maverick, but I'm not sure.
heater unit overhaul https://www.youtube.com/watch?v=2Fx3ccQg8Wc
fitting a bigger heater matrix https://www.youtube.com/watch?v=0Ii7kw07oMU
Thanks again.
I'm definitely going to restore this one. The matrix is still mint. I'm going to disable the diverter flap - lock it so that air is always flowing through matrix and do away with that control cable altogether. I've just seen a replacement cable controller which has the two way switch in it available as a variable resistor to control the motor (I'll post the link when I get it).
Worst part of the job is getting the old paint and rust off as I see it
Why?  There is n benefit in doing that, and losing temperature control to leave the unit permanently set at full heat seems counter productive.
  • 2 weeks later...
My thinking is with the main flap closed (through bulkhead air-in) and the fan off, even in summer not much warm air will pass through the system. This way whenever I actuate the opening of the main flap it will always immediately be dry air which may help remove the issue I get when switching from hot to cold (the diverter flap) of getting a sudden "insta-steam-up" window effect. Not sure. It all depends on my first assumption that not much hot air will be pouring into the cab with the main flap closed and the fan off.
Far better to ensure the drain mitre valve is clear and fir a snow cowl to prevent debris entering the duct (and most water too) that clogs said mitre valve.  Removing the temperature control won't help any more than leaving it set to hot, and will reduce the hot air anyway - the flap works by blocking whichever side is not needed, and so when you want hot air it blocks the cold air bypass around the matrix; if you remove the flap, the bulk of the air will bypass the matrix and never give you more than tepid air.
The flap also becomes defunct when fitting the Landreizeger variable fan module. There's been no noticeable difference in warm up time, the only downside is on the one warm-ish day we get up here in Scotland it can get a bit sweaty. Opening the bulkhead vents soon overwhelms any residual heat blown through the matrix when driving.
9 hours ago, landroversforever said:
The other issue I see is the car taking longer to warm up all the time if the heater is always open and taking heat from the coolant.
The coolant volume is minimal and the heater matrix small, so it only affects warm up times if the engine is idling (even the old matrix type can bring engine temperature down from normal to fairly cool if the engine is only idling) - as soon as it starts working, the cooling effect of the heater becomes irrelevant.
If the matrix is always being cooled by the air going through it, it's always going make it take longer. As the coolant circuit to the heater is unaffected by the thermostat it will affect the warm-up time.
Friend of mine has recently had a webasto fitted in his T5 VW camper and he said the single biggest difference is how much quicker the engine warms up every morning as the blower is now always off.
Yes agree about the effect of a heater. In my early driving days I seemed to often be struggling with almost overheating engines. I drove a Fiat 850 van and then their 850 Sport Coupé (very grand title I know) which had a 909cc engine. The heater most definitely affected the amount of engine cooling and more often than not it was the difference between boilng over or not.
OK I think you know more than me here! This is what  was planning on fitting (except I saw it on a Norwegian LR site). From what I can see when you use this the diverter flap becomes defunct - by defunct to you mean always held so that air diverts through the matrix.
As far as I know there are only two flaps/mechanical actions - the diverter flap which either pushes air around the matrix or through the matrix. The other flap just controls whether air can flow through the bulkhead and into the cab?
If you want variable speed control, then fine, but I take issue with its claim of higher fan speed - the high setting on the Defender is a plain wire with no resistor, so as long as the switch is in good order, the resistance can't be greater than their electronic unit and the fan speed can't be greater.  If it deletes the function of the blocking flap, it seems a backwards step to me.
simonb on here does a resistor kit to increase the slow speed, the fast speed is unaffected as it doesn't pass through any resistors. to increase the airflow through see the 'supercharging your heater' thread in the defender forum & its linked in the tech archive index too.
  • 1 month later...
I've just gt back from sea....turns out the chap who sells these is 5km frm the Dutch offices I work for in Dordrecht.  A very nice chap I must say.
But yes I agree with the comments - it doesn't make it faster. It just gives a a range rather than: 1 - Off, 2 - pointless fart, 3 - full hammer
  • Like 1
