Not seen this before
FridgeFreezer
they don't look like they would hold up racing but anything that helps a quick steer system can't be bad.
Looking at the pic, what is it about them that makes you think they wouldn't hold up to racing?
If you have a real problem with feedback / self centring, why not look at changing the swivel angle a bit?
Al.
seems to attack the problem from the wrong angle.
If you have an unstable system (non-centering steering after lift) then adding a spring may make it centre but could create other dynamic problems.
I would say stick with castor correction.
I have seen this being used on a portugees landy. The spanish and portugees seem to like this setup. Problem I saw there was that stones and other carp got trapped in the spring and causing headaches. Interesting that the collar is being held on only by friction on the damperbody. I would say it is not solving the real problem, somehow. Anyway, anyone got one and can tell us more?
Daan
When my PAS pump expired the other day and I had to cut the belt off at the roadside and drive home with no power assistance, I am able to confirm that the last thing I would have needed was a spring acting against me too. I can also confirm that despite a 2" lift, the steering is fairly keen on self centering without any extra help.
Chris
Chris
Chris, my box and pump gave up the day before the last Mike Wolfe and I had no chance of changing it. Competing without powersteering has to be very high on the list of things I never want to do again! Likewise, I've never had self centering issues with a lift.
