Oakmaster Posted February 27, 2019 Share Posted February 27, 2019 (edited) Leakin Fluids Mystery This is our MD's 2015 110 Puma Tdci (photo and video below) For the last 2 days it has been leaking a fluid when he drives it in from home, (about 2 miles) Its not oil, and its not water, (it doesnt dry) We have checked Brake, Clutch, steering, Coolant, engine oil,and washer fluids - and all seem fine the aircon hasnt been used (and its the wrong side) - a cursory look (Thats when you look and swear a lot!) reveals nothing obvious. I'm going to revisit the brake fluid, because I dont know enough to diagnose this, but despite no obvious evidence of a leak it is below the brake servo. any suggestions anyone? IMG_1201.MOV Edited February 27, 2019 by Oakmaster poor spelling Quote Link to comment Share on other sites More sharing options...
crwoody Posted February 27, 2019 Share Posted February 27, 2019 (edited) Looks like diesel to me, or maybe screenwash, can you smell it? Edited February 27, 2019 by crwoody Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted February 27, 2019 Author Share Posted February 27, 2019 Its deffo not diesel, and sadly not screenwash (too easy) it doesnt smell (or so we think!) Does modern Brake fluid smell? thanks B Quote Link to comment Share on other sites More sharing options...
crwoody Posted February 27, 2019 Share Posted February 27, 2019 I suppose it smells a bit oily but not strong. Looks far too clean to be engine oil. 1 Quote Link to comment Share on other sites More sharing options...
TSD Posted February 27, 2019 Share Posted February 27, 2019 (edited) 3 hours ago, Oakmaster said: any suggestions anyone? Put down a bowl and collect a clean sample of whatever it is? It'll make it a lot easier to identify if you can't tell where it's falling out of. Edited February 27, 2019 by TSD Quote Link to comment Share on other sites More sharing options...
monkie Posted February 27, 2019 Share Posted February 27, 2019 Put some water on the patch and see what happens. If it is engine oil, gearbox oil or diesel you will see a rainbow film appear on the surface. If it is screenwash, coolant or water then nothing will happen. If it is brake fluid then it will go milky. Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted February 27, 2019 Share Posted February 27, 2019 Most likeley to be diesel and by the position of the puddke would suggest a fractured fuel line, this doesn't mean that the engine would not run quite right, it would have no effect. Get under it and observe any hanging drips and trace the source from there, I had a similar problem where a clear liquid was dripping off the front axle diff, tracing it back found that one of the fuel pipe unions on the back of the injector pump was leaking. Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted February 28, 2019 Author Share Posted February 28, 2019 Gentlemen - thank you for your sound advice - I'll let you know the outcome tomorrow - Cheers Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted February 28, 2019 Share Posted February 28, 2019 It isn’t that adblue stuff is it ? Quote Link to comment Share on other sites More sharing options...
monkie Posted February 28, 2019 Share Posted February 28, 2019 I would expect Adblue to leave white crystals of urea everywhere making it quite easy to detect. Did the 2015 defenders use adblue? Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted February 28, 2019 Share Posted February 28, 2019 I’ve no idea , I thought I’d read somewhere that later Defenders used it but could be wrong , it was just another idea as no one seemed sure . Quote Link to comment Share on other sites More sharing options...
Happyoldgit Posted February 28, 2019 Share Posted February 28, 2019 Puma Defenders don't use Adblue. Fuel lines run along the top of the chassis rails so I would expect to see the chassis wet. Looks like water dripping from the air intake pipe to me. Has it been washed recently? Does it have a snorkel? 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted February 28, 2019 Share Posted February 28, 2019 It's not from the air conditioner, is it? Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted February 28, 2019 Author Share Posted February 28, 2019 2 hours ago, Happyoldgit said: Puma Defenders don't use Adblue. Fuel lines run along the top of the chassis rails so I would expect to see the chassis wet. Looks like water dripping from the air intake pipe to me. Has it been washed recently? Does it have a snorkel? yes has been washed (unlike mine!) - its not diesel for sure - and whatever it is - it isnt drying, doesnt smell, doesnt 'rainbow' or go milky white ! Quote Link to comment Share on other sites More sharing options...
paime Posted March 1, 2019 Share Posted March 1, 2019 Just noticed there was a video attached - weird stuff! Does it only drip when the engine is running or has recently been running? I'm thinking it might be a freon leak. Quote Link to comment Share on other sites More sharing options...
TSD Posted March 1, 2019 Share Posted March 1, 2019 I missed the video too. At least when it's leaking at that rate, if it's important it'll become obvious what it is pretty soon! Quote Link to comment Share on other sites More sharing options...
Oakmaster Posted March 4, 2019 Author Share Posted March 4, 2019 Sorry gentelmen, been away for a day week-end - while I was away it was taken to the nearest L-Rover garage who happended to be the local main dealer, and they could not find anything wrong with it. We know it wasnt diesel, and it had been washed recently - so maybe its that? Interesting thanks for your input Quote Link to comment Share on other sites More sharing options...
monkie Posted March 4, 2019 Share Posted March 4, 2019 One more suggestion for you to check. Have you been carrying anything in the back of the truck that could have spilt and found its way out? I once had diesel dripping on the floor from a similar area, it took me a lot of work to realise it wasn't the tank or fuel lines but a leaking can of diesel in the back. Quote Link to comment Share on other sites More sharing options...
