fmmv Posted September 24, 2023 Share Posted September 24, 2023 That all looks way too good to actually use. Like large scale jewellery. Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted September 24, 2023 Share Posted September 24, 2023 Epic as usual! Hey Serg, what is the height from top of spring perch (rearmost) to floor? And top of cross member to floor? I'm doing remarkably similar (but 99% more ****!) My pre cut measurements were 11mm different left to right! (straight edge on topside of chassis to croissmember) I ended up with a measurement from floor to centre of crossmember. (a random average....) Would be nice to see what you have (to the nearest 0.01mm!) 😁 Cheers Dave PS can't you use weld through primer for TIG? Quote Link to comment Share on other sites More sharing options...
uninformed Posted September 25, 2023 Author Share Posted September 25, 2023 19 hours ago, fmmv said: That all looks way too good to actually use. Like large scale jewellery. They all look the same painted black lol Quote Link to comment Share on other sites More sharing options...
uninformed Posted September 25, 2023 Author Share Posted September 25, 2023 9 hours ago, TD5toV8110 said: Epic as usual! Hey Serg, what is the height from top of spring perch (rearmost) to floor? And top of cross member to floor? I'm doing remarkably similar (but 99% more ****!) My pre cut measurements were 11mm different left to right! (straight edge on topside of chassis to croissmember) I ended up with a measurement from floor to centre of crossmember. (a random average....) Would be nice to see what you have (to the nearest 0.01mm!) 😁 Cheers Dave PS can't you use weld through primer for TIG? As mine was a cab chassis tray back, I had no floor to reference from. I simply put my straight edge along the load bearing points and measured the gap between it and the top of the old cross member before removing it. I had 48mm left side and 53mm right side. That could be the mounts as much as anything. I just used the left side as my guide and set it level (across) with the chassis. I made the outside vertical face of new cross member square to the straight edge. I also used a layout line laser to make sure it was square to the chassis centreline. All my bodywork etc is referenced off this chassis centreline. None of my local welding suppliers carry weld through primer and I’ve read mixed result’s regarding TIG. 2 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted September 25, 2023 Share Posted September 25, 2023 10 hours ago, TD5toV8110 said: Would be nice to see what you have 😁 Dave...build thread pleeeze.....lol Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted September 25, 2023 Share Posted September 25, 2023 13 hours ago, Stellaghost said: Dave...build thread pleeeze.....lol Regards Stephen Mine is embarrassingly carp compared to the legendary work on here.... I literally had a hip replacement last week, so walking wounded right now! Pelvis/femur fractures due to 1/2 ton ride on mower squashing me 6 months ago... (not old age!)🤪 I will aim to start a thread next week.....Lets say October 1st. Now I'm committed!😬 Cheers Dave 2 1 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted September 25, 2023 Share Posted September 25, 2023 Hey Serg, on mine those load bearing points are all over the place as well; classic LR tolerances. Mine was a 2000 5 door. I'm sticking a chopped up S3 tub on it so who knows what to reference from... Quote Link to comment Share on other sites More sharing options...
uninformed Posted September 26, 2023 Author Share Posted September 26, 2023 7 hours ago, TD5toV8110 said: Hey Serg, on mine those load bearing points are all over the place as well; classic LR tolerances. Mine was a 2000 5 door. I'm sticking a chopped up S3 tub on it so who knows what to reference from... As long as you have a reference from the chassis to the original cross member then you’ve got a starting point. I think I’m lucky in that when I level across the front of the chassis, the rear is within 1mm. So level across is level across. From there it was my distance below the straight edge and square to centreline. I know my front bulkhead mounts are out of square by about 6-7mm and height is a bit out of level across as well. A little fettling and it should be ok. Remember you have height adjustment in the rear cross member mounts, and front of tub mounts. It’s only the front bulkhead that has no height adjustment, only fore/aft lean at top. 1 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted September 26, 2023 Share Posted September 26, 2023 On 9/25/2023 at 6:25 AM, uninformed said: They all look the same painted black lol Black looks smart though, it's when people paint chassis & axles bright primary colours that ruins it... also it's usually folks who should probably not be drawing attention to their mods who paint it all bright yellow. 1 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted September 26, 2023 Author Share Posted September 26, 2023 36 minutes ago, FridgeFreezer said: Black looks smart though, it's when people paint chassis & axles bright primary colours that ruins it... also it's usually folks who should probably not be drawing attention to their mods who paint it all bright yellow. Absolutely 👍, I was more commenting that when painted black it covers sins and efforts the same lol. I’ll be painting mine stock colours throughout, I don’t want attention when it’s on the road Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 26, 2023 Share Posted September 26, 2023 On 9/25/2023 at 10:25 AM, uninformed said: They all look the same painted black lol Only to a very casual glance, but to those who look a bit closer, well… 1 Quote Link to comment Share on other sites More sharing options...
Popular Post uninformed Posted September 28, 2023 Author Popular Post Share Posted September 28, 2023 Press forming the rear cross member chassis extension bottom flanges. … 6 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted September 28, 2023 Share Posted September 28, 2023 Are you using 3mm for that (and the gussets)? 🤔 Quote Link to comment Share on other sites More sharing options...
uninformed Posted September 29, 2023 Author Share Posted September 29, 2023 4 hours ago, TD5toV8110 said: Are you using 3mm for that (and the gussets)? 🤔 Yes, 3mm for the chassis rail doublers , and the top and bottom flanges. I haven’t finalised the gussets yet. There will also be a 3mm formed RHS going from top of rear cross member to top of chassis rail 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted October 2, 2023 Author Share Posted October 2, 2023 Thanks to Chuck we had a 3 day weekend. Doesn’t look like much but these were fiddly 3 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted October 2, 2023 Share Posted October 2, 2023 Lots prettier than mine are going to be! 🤪 Quote Link to comment Share on other sites More sharing options...
uninformed Posted October 8, 2023 Author Share Posted October 8, 2023 To say this was challenging is an understatement…. 50% of the welding was lying on my back (overhead) and 50% of the welding was left handed to keep all weld direction the same (reduce distortion). On top of that we’ve had unfriendly welding weather, I had to add another two walls to the shed (portable fold down camping gazebo). but at least it’s in… 4 Quote Link to comment Share on other sites More sharing options...
fmmv Posted October 8, 2023 Share Posted October 8, 2023 Well, if you can do work like that upside down left handed in bad weather I've no sympathy 😉😉. Looks great 2 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted October 8, 2023 Share Posted October 8, 2023 48 minutes ago, fmmv said: Well, if you can do work like that upside down left handed in bad weather I've no sympathy 😉😉. Looks great Exactly what I thought ! 😂 I mean … come on !! Lol Quote Link to comment Share on other sites More sharing options...
uninformed Posted October 8, 2023 Author Share Posted October 8, 2023 Haha 😆, well the welds didn’t turn out as nice as I would like but they are sound. I still have gussets, rear of tub mounting tabs and chassis ties to complete. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted October 8, 2023 Share Posted October 8, 2023 4 hours ago, uninformed said: Haha 😆, well the welds didn’t turn out as nice as I would like but they are sound Well that's made me feel better..... You are human after all...........lol Quality work as usual Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted October 8, 2023 Share Posted October 8, 2023 You should probably clear coat it rather than black....😍 1 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted October 9, 2023 Author Share Posted October 9, 2023 4 hours ago, TD5toV8110 said: You should probably clear coat it rather than black....😍 If I could weld and fabricate like trophy truck builders I would 😆 Quote Link to comment Share on other sites More sharing options...
TD5toV8110 Posted October 9, 2023 Share Posted October 9, 2023 But you do...🤪 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted October 10, 2023 Author Share Posted October 10, 2023 7 hours ago, TD5toV8110 said: But you do...🤪 Not even close lol. Their welding makes mine look like bird ****, and then things like plumbing and electrical make NASA question themselves 😳 Quote Link to comment Share on other sites More sharing options...
