Jim Mason Posted April 23, 2022 Share Posted April 23, 2022 Looking for help Purchased a winch for my Landrover Discovery 1. But owner had no details on it, he brought it second hand etc So would like to know more about it. Can anyone help me out? Quote Link to comment Share on other sites More sharing options...
Escape Posted April 24, 2022 Share Posted April 24, 2022 That would be hard to identify, with no markings left and painted over... But most of winches are all basically the same, especially the cheaper ones are hard to tell apart: a 3 stage planetary gear, a shaft with a brake inside the drum and a series wound electric motor. So any manual will give you some information to refurbish it. Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 24, 2022 Author Share Posted April 24, 2022 Thank you... Might try a gentle paint remover to see if the extra layer of paint can be renoved. Quote Link to comment Share on other sites More sharing options...
Snagger Posted April 24, 2022 Share Posted April 24, 2022 Looks like the yellow or orange might be the original colour, which may narrow down the manufacturer. TMax like yellow. Quote Link to comment Share on other sites More sharing options...
muddy Posted April 24, 2022 Share Posted April 24, 2022 winchmax are orange I believe Quote Link to comment Share on other sites More sharing options...
western Posted April 24, 2022 Share Posted April 24, 2022 Any stamped in to casings serial or model numbers. Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 24, 2022 Author Share Posted April 24, 2022 Nope Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 24, 2022 Author Share Posted April 24, 2022 Motor Connections - Red - Yellow - Black + Connection underneath Quote Link to comment Share on other sites More sharing options...
Arjan Posted April 24, 2022 Share Posted April 24, 2022 Could be a T-Max.. Quote Link to comment Share on other sites More sharing options...
Escape Posted April 25, 2022 Share Posted April 25, 2022 The freespool lever is the type used by Tmax, but also by Warrior etc. As said, wiring is the same for pretty much all winch motors, so it really doesn't matter what brand it is. Unless you need spare parts... Have you tried running it yet? Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted April 25, 2022 Share Posted April 25, 2022 It's most likely one of the generic chinese copies of the TMax - the easiest way to tell is to take it apart. The Tmax brake design wasn't simple and Chinese makes/copies, like GEW, AEW, etcoften reverted to the cheaper warn copy. It may be an early T max - the EW range was yellow, and it doesn't use the normal splined motor. But there was no EW 12500. The free spool is common on Warn, Magnum, GEW, AEW, Superwinch and a host of others (very similar to the T max EW, but that has an improved mount as this type of freespool is a bit carp at letting water in. James, I probably have a set of tie bars for it - your if you want them. I may have some other bits. Strip it down and send me the pictures and I'll talk you through the re-build 2 Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 25, 2022 Author Share Posted April 25, 2022 Ok todays update... Seals gone - grease emulsified - solid in places Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 25, 2022 Author Share Posted April 25, 2022 Removed and left soaking in diesel to try and remove grease. Tried to move motor - used ground and tapped positive to top red or yellow - went to move but stopped Did i need connection to top black? Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 25, 2022 Author Share Posted April 25, 2022 Fault finding 13500lb Winch - SPADE 2021.pdf Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 25, 2022 Author Share Posted April 25, 2022 Article above gives good details on testing a winch motor Quote Link to comment Share on other sites More sharing options...
Escape Posted April 26, 2022 Share Posted April 26, 2022 12 hours ago, Jim Mason said: Removed and left soaking in diesel to try and remove grease. Tried to move motor - used ground and tapped positive to top red or yellow - went to move but stopped Did i need connection to top black? Yes, you need a third jumper to test the motor, from top red to either yellow or black and an additional 12V to the other one (+ earth on the bottom of course). Switching yellow and black around will change the direction the motor is running, those power the field windings. Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted April 26, 2022 Share Posted April 26, 2022 15 hours ago, Jim Mason said: Removed and left soaking in diesel to try and remove grease. Tried to move motor - used ground and tapped positive to top red or yellow - went to move but stopped Did i need connection to top black? Paraffin and diesel, paraffin and petrol or Jizer are all better than straight diesel. Use an old stiff brush to work the liquid into the teath. It needs to be super clean. Does the free spool lever work? Winch electrics (as Escape mentioned) need a live, earth and switched feed live. The earth is underneath the motor, on it's little ownsome. Live feed is the pole at the point of the triangle (red), the switched feed, directional poles are the two side by side at the base of the triangle (yellow and black) Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 27, 2022 Author Share Posted April 27, 2022 On 4/26/2022 at 6:28 AM, Escape said: Yes, you need a third jumper to test the motor, from top red to either yellow or black and an additional 12V to the other one (+ earth on the bottom of course). Switching yellow and black around will change the direction the motor is running, those power the field windings. Perfect thank you Quote Link to comment Share on other sites More sharing options...
Jim Mason Posted April 27, 2022 Author Share Posted April 27, 2022 Can you still by parafin - wish i had access to a parts washer lol Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 28, 2022 Share Posted April 28, 2022 14 hours ago, Jim Mason said: Can you still by parafin - wish i had access to a parts washer lol Should be able to, I buy it at garden centres for my greenhouse heater regards Stephen Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted May 4, 2022 Share Posted May 4, 2022 On 4/28/2022 at 12:07 PM, Stellaghost said: Should be able to, I buy it at garden centres for my greenhouse heater regards Stephen Or ebay Quote Link to comment Share on other sites More sharing options...
