Question about brakes
landrover598
My landy has a rangy front axle and twin brake pipes, I'm about to replace the flexi pipes and route longer ones allong the radius arms ( in preperation for suspension changes)
It would be a bit easier / neater to run a single pipe down each arm, so can i get rid of one of the two pipes ? Is there any advantage to the twin pipe setup ?
Anyone got any comments ? :unsure:
The two seperate feeds provide redundancy in the front braking system. If you suffer a pipe fracture you still retain working front brakes.
jw
In theory yes
In practice NO.
Unfortunately I don't think you can do that easily.
If you'd like a better system [in my opinoin] swap to Defender callipers and master cylinder.
mike FOAK
Knockers
I can cause trouble in an empty house !!!
Only using one pair of pistons will half the braking effort so front/rear balance will be affected.
It's quite common for Mini owners to fit 4-pot calipers from a Metro to their cars using a T-piece as mentioned above.
You will need a T-piece because the two pots are completely independant of one another.
they do provide redunacy to an extent. on the original fitting there is a front circut & a whole car circut. one side of each front caliper will work if the whole of car circut goes - for a while till you loose more fluid.
just T them together into one line, it'll be fine.
im told some disco/RR owners upgrade to 110 calipers as they & the pads are larger giving you more powerful brakes.
If one circuit leaks, the design of the master cylinder stops the other circuit losing fluid.
Defenders [including all 90/110] have a I/I split system = front/rear on seperate circuits, the front calipers have a through drilled fluid way to both sets of pistons.
RR & Discovery 1 [my also apply to D2] have a I/H split = front only & front/rear at reduced braking power if the front I circuit fails, hence 2 lines into front calipers to seperate pistons
  • 2 months later...
Well i finally got a free, dry day to do this modification. I've replaced the two short hoses going to each caliper with one long one run allong the hockey stick, then into a Tee piece and two short bits of copper pipe
Before
Now
Now i can start work on the front suspension without having to worry about the hoses going tight :D
nice work Dave, pipe might be a bit exposed though dont you think to sticks/branches etc, but then no more exposed than what was there before i guess.
you will have the same braking force running two pipes to the calipers as the calipers are not fed of separate supplies/chambers, so for any foot pressure the same amount of fluid is still displaced
