Paul Wightman Posted March 30, 2008 Share Posted March 30, 2008 I wanted to get away from the conventional 'winch bumper' on the truck I'm not building. As the front of the vehicle will be a 'blank canvas' I can please myself. Design brief, strong enough for a twin motor 8274, lightweight and a fairlead which is kind to rope. I came up with this, two 48mm dia tubes with c/bored inserts for cap head screws to suit long drum 8274 and a 48mm dia stainless steel fairlead which we all know gives a 24mm radius for the rope to run round, this protrudes by 10mm from the steel tubes. Proved a bit time consuming as i had to weld together 4 90 deg short radius chd 40 stainless elbows with some stainless tube. Cut top and bottom to fit into steel tubes and weld. The stainless is shot blasted as I can't get a decent finish graining or polishing it! Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted March 30, 2008 Share Posted March 30, 2008 Now that's really rather nice I had though of doing something similar, no way near as bling as that though, i was just going to use some off cuts from the cage tube. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted March 30, 2008 Share Posted March 30, 2008 Is it going to be water cooled again Paul ? Mo Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted March 30, 2008 Author Share Posted March 30, 2008 Is it going to be water cooled again Paul ? Mo The thought did cross my mind what with it being tube and all! After extensive calculation I have come to the conclusion that with the increased radius and so increased contact area the heat buildup will be reduced by 62.443% and as such will not require additional cooling. Quote Link to comment Share on other sites More sharing options...
Steve 90 Posted March 30, 2008 Share Posted March 30, 2008 Nice. Quote Link to comment Share on other sites More sharing options...
s2hotdog Posted March 31, 2008 Share Posted March 31, 2008 Nice work Paul Interested in your shot blasting not polishing the fairlead - I had a similar problem I got shot blasted by mistake - very harshly SA2.5 but managed to get to a satin finish using scotch bright and loads of elbo grease Of course after a few uses the plasma polishes it anyway Steve Quote Link to comment Share on other sites More sharing options...
Les Henson Posted March 31, 2008 Share Posted March 31, 2008 I didn't know you could weld stainless to mild steel Did you use ordinary mild steel wire Paul? Les. Quote Link to comment Share on other sites More sharing options...
steve b Posted March 31, 2008 Share Posted March 31, 2008 Looks good Paul, Its got to be better as a larger dia, much less stress on the fibres.Very similar to Mr Baskills new G Cheers Steveb Quote Link to comment Share on other sites More sharing options...
dollythelw Posted March 31, 2008 Share Posted March 31, 2008 nice job worked well for us last year Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted March 31, 2008 Author Share Posted March 31, 2008 I didn't know you could weld stainless to mild steel Did you use ordinary mild steel wire Paul?Les. Stainless to mild is not a problem, I used stainless wire but you can use mild. In an emergency I have used mild steel mig to repair stainless, tends to go a bit rusty though. Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted March 31, 2008 Share Posted March 31, 2008 Love it Paul - quick Q: how did you clean up the weld on the inside of the curve (i.e. the two welds at either end on the centreline)? Cheers, Al. Quote Link to comment Share on other sites More sharing options...
Paul Wightman Posted March 31, 2008 Author Share Posted March 31, 2008 Love it Paul - quick Q: how did you clean up the weld on the inside of the curve (i.e. the two welds at either end on the centreline)?Cheers, Al. Al, I welded an elbow to each end of each tube, cleaned them up then welded the two halves together. Cleaning up required a 4 1/2" sander, 1/2" belt sander, air die grinder and flapwheel and about 2 hours! Quote Link to comment Share on other sites More sharing options...
Astro_Al Posted March 31, 2008 Share Posted March 31, 2008 Ah! I see - yeah it was getting into the final welds that puzzled me, on the inside of the bends. Came out great though. Ta. Al. Quote Link to comment Share on other sites More sharing options...
smo Posted March 31, 2008 Share Posted March 31, 2008 Nice, looks good, but you do know you can but stainless fairleads like that for £25!! Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 31, 2008 Share Posted March 31, 2008 After extensive calculation I have come to the conclusion that with the increased radius and so increasedcontact area the heat buildup will be reduced by 62.443% and as such will not require additional cooling. Ah but have you taken global warming trends into account? By the time you finish your build all of your calcs will be out by a good factor. Quote Link to comment Share on other sites More sharing options...
Milemarker Type S Posted March 31, 2008 Share Posted March 31, 2008 Very nice- sorry to say it...but it would have looked nicer polished Anyone know of any commercially available fairleads that use this bigger radius? Seems daft for us all to be bending our plasma around such tight radii on hard side pulls cos they are the only ones anyone sells? I am sure that this is the main reason for me snapping my plasma- not necessarily breaking at the time but on a heavy pull later when the line breaks due to damage that has already been caused... Quote Link to comment Share on other sites More sharing options...
alan kemp Posted March 31, 2008 Share Posted March 31, 2008 Nice, looks good, but you do know you can but stainless fairleads like that for £25!! From where?? Quote Link to comment Share on other sites More sharing options...
smo Posted March 31, 2008 Share Posted March 31, 2008 The guys who sell champion winches - i've got 2 of them, very cheap by comparison to other places and identical product. They are slightly smaller than the one Paul fabbed up, the bar is only approx 25mm dia, but its well made solid stuff! Quote Link to comment Share on other sites More sharing options...
Night Train Posted March 31, 2008 Share Posted March 31, 2008 It looks really great. Would have been good if it was all polished stainless. It does remind me of a claymation mouth though. Wallace. Quote Link to comment Share on other sites More sharing options...
Orgasmic Farmer Posted March 31, 2008 Share Posted March 31, 2008 Nice, looks good, but you do know you can but stainless fairleads like that for £25!! These ones?? http://www.winchsolutions.co.uk/index.asp?...9-EFAF28F6B9AF} Quote Link to comment Share on other sites More sharing options...
smo Posted March 31, 2008 Share Posted March 31, 2008 Yup! Must be a show price when they do them that cheap then, cos ive even got the reciepts here!! Quote Link to comment Share on other sites More sharing options...
newclear Posted April 1, 2008 Share Posted April 1, 2008 That really is a lovely bit of fabrication, Polished or not Matt2 Quote Link to comment Share on other sites More sharing options...
will_warne Posted April 1, 2008 Share Posted April 1, 2008 I like that a lot, Paul. It ticks a lot of boxes even if it’s going to make your truck look like it’s got a trout pout. I take it the not builds getting on quite well... Quote Link to comment Share on other sites More sharing options...
